Thx Denis...I believe you are correct. the culprit appears to be the main spine/keel assy.  Has a really bad twist to the center, I've got the 9-5 glued in so far and it seems ok, wont know for sure till it comes out of the clamps though...fingers crossed
All's well that ends well...the technique I used to straighten the frame and deck worked well, she is dead flat...maybe too flat, but better that then warped and twisted...IMG_0307.JPG.df84a06ded97c36c32ecf09d95aee6ba.JPGIMG_0308.JPG.66ed4fa8034ff54fedd5cc45ac728e65.JPG
only problem I see is that somewhere along the way I lost frame #10...no idea where, searched high and low and nojoy...might have joined all the single socks in the black hole!   Oh well a new one is easily made.
Thanks for the likes and comments
Afew odds and ends...started making the new transom support, curving the stock
and cut and pinned the faux timberheads
Looks like in spite of the setbacks you are still moving right along J. Congratulations on getting it fixed.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
good fix!   happy to see you got her back together :)   ....and your deck is no worse for wear!  good save! ;)
oh.......I got the first of the two books today.......Lennarth Petersson's fore and aft craft :)
Edited by popeye the sailor
extra text
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
That's a good book, relied on it alot when I was rigging the Hannah, I think there is a companion book too
Gonna try to lay some planks today
Edited by jct
yess.........plank that hull!   quickly now...........before something else happens!  it looked like you might need to take a bit more off the #4 starboard side.......check your faring.   this is why I'm planking the hull before doing the deck........if there are any gaps,  I can get rid of them with the deck planking.  do like in 'cool hand Luke'.....get mad at dem damn eggs!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Yea you’re correct, got at least one ugly spot there... spent the morning cutting planks.   I normally would as well but the twist throw me off a bit, so I’m working bass ackwards
From the looks of it the garboard on Andy and Jumbo may lay right out front to back
Edited by jct
I'm hoping they fall that way.  I'm using 5 mm plank strips.  I may need to do further cleaning up in this area........I'm sure I will find out how much as I get closer to it.  since you've adjusted all of the bulkheads,  some extra faring will be needed.   I had a couple on mine too that required extra so they would be flush with the deck platform...even had to shim one side of bulkhead #9.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Ya not surprised...mine come in at about 4.7 mm close enough to call 5, leaving the garboard at 10 though
if you run into that situation,  you can always fit in the difference below the waterline.  this way it is either painted or coppered.  put it as close to the garboard as possible .
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
This one is going to have a fully painted hull...probably black, very light ochre wales and dark green trim...white stuff for the bottom, typical merchantman colors, based on Ship Modelers Shop Notes.  Least ways that's my current thought, I'll probably fill the entire hull and then sand it all off of course:P
Started on planking, garboard is on
and started on the 1st course
Sneak peak at the colors
Edited by jct
I got the garboard and one plank per side and then started back at the deck edge...establishing a foundation for my faux timberheads to attach to, may get to that tomorrow...so planking progresses IMG_0323.JPG.9e6636483e3a6043de8e98c3e591b463.JPG
So while waiting for the glue to set I been going little odds and ends...
IMG_0320.JPG.317be2a056e52f4d7bdbf88498862c8b.JPGfinished the deckhouse
and started working on guard bars for the skylight IMG_0322.JPG.bdec914b4f5962fedec3543acc477ac0.JPG
drilled holes in thin wood strips and inserted pins, gonna ca them then cut to size
Well that's it for today, thanks for the likes and looking in
called for supper and got pulled away........   but look at cho.......your ahead of me in other places  ;)    the cabin and skylight looks great..........nice color choices.     you've also made progress with planking...defining the edge for the bulwark posts.   you may need to get rid of some of that keel though,  if there's too much.  the one thing I noticed with the frame,  is that the pointy parts are little to none......after faring,  it's even more.  good to see you plank'in though.......it will stiffen the hull.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Planking continues...still have about 14 strakes per side to do...stalled one the stern runs...just gotta wrap my head around it.
Ok next morning and the planking continues...gonna do my damndest to finish today, there is gonna be a lot of sanding and fill required
Edited by jct
Yes, that is it, thanks for sharing this picture, it will help with my deck layout, as the plans are pretty vague.
i hope you continue to follow along, and take a look at Popeye’s too, we’re doing simultaneous builds and going in different directions
Sure thing! If you want any other pictures of anything, please let me know! This gentleman had models all over his house, some small and some very large. He is dying now and it was very kind of him to gift it to my teenaged son.
He bought it new in the 60s or 70s, he said, and tinkered with it off an on for 50 years. Not because it took that long, he said, but because he didn’t like the ship, itself, and couldnt bring himself to finish it straight away. LOL.
Heres another shot.
hi there..........I agree ....it's a nice looking model :)   I see he did use the mast as complete lengths....I've been thinking to myself that the dowels are too long.  I too appreciate your showing us your model......will make for a great study ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
the planking is done...and it is hideous, this is by far my worst planking job EVER,
stock market tip...buy Plastic Wood stock
I'll be using enough to support the economy of most third world countries!!   no pics until it is sanded and filled...well ok just one
and this is the good side :blush:
Edited by jct
so now your ahead of me.......so what the heck......a good sanding and there you go!  ;)   no holes or gaps........right?!?!?!     great job keeping that bow line....ohhhh,  that's right,  you have a rabbit in place there :D   no,  but really......sand it down and paint like ya said,  and you should get a good looking hull.   did you at least taper around the transom?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Well not really considering your building two and working on your car and building airplanes all at the same time, sheess:D
Things do look a little better today in the bright sunshine 🌞 and after about two pounds of wood filler :P
So after sanding and sanding and then sanding some more I moved on to marking out for the faux timberheads...they spaced out a 33mm, one thing about this technique it allows you to space the timberheads evenly
IMG_0327.JPG.2c65d58dcfae7408b7b3cf04c9b7a351.JPGmarked edge
before the timberheads were mounted I made and installed waterways, this is just split basswood glued on edge
IMG_0329.JPG.9406a71ad533fba3357c3860fb4a0bd6.JPGIMG_0328.JPG.6ccf26aee3f1ee08b3951716c90ec019.JPG
from there the timberheads were mounted using pins and gel ca in predrilled holes
after all these set the wales were mounted
IMG_0333.JPG.014d460ef40af41626eb8ea6f2609e26.JPGIMG_0334.JPG.de42ad6ab52a0ee4ac3c2c5f0548e65a.JPGIMG_0335.JPG.198ced5fffc0eb7b731c3b9b53da4405.JPGIMG_0336.JPG.8c7c7e328648333a3e4c5ffe92731383.JPG
three runs up each side and they were complete, turned my attention to the stern and mounted the kit supplied stern part...this will serve as the foundation for the stern fashion pieces...once I make them
IMG_0338.JPG.1400795a1b5191040a3f6771f11ce715.JPGIMG_0339.JPG.064c7e78b5176d31a17fb9bbb4d38238.JPGIMG_0340.JPG.e870492c0d39dbb22cfe7fc0643d04b2.JPG
while waiting for glue to set I mounted the ladder in the fwd hatchwayIMG_0332.JPG.321f81630cd0ad177326254b04fa3a36.JPG
and started building up the capstan
well that's it for today next will be the addition of the rub strakes...I  still have not decided if the hull bottom will be white stuff or copper plates, I liked the way the copper turned out on my Harriet Lane build...but I also remember what a pita it was...time will tell
Thanks for all the likes and the words of support
the hull came out very nice :)   nice job on the bulwarks too.   your deck still looks good...and you thought you'd ruin it ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
