Half Hull Project by LyleK1 - FINISHED - NRG
So, I was forced to deviate from the plans a little due to my not taking good measurements and keep the planks on a parallel with the wales.
I chose not to start over or go back several planks because I got some good practice making dropped or stealer planks! Additionally, this is a teaching tool and I have learned a lot... and I'm not done.
The last rows in the middle belt had to be modified to meet the wale properly:
IMG_3728.jpg.50071be38face51ce509882c50cb2bf1.jpgIMG_3729.jpg.5ddb2fa14480cf7965d4b7308a35471b.jpg
Last couple planks below the wale.
IMG_3730.jpg.012f960aba5ad0cdc3ae49bd51095179.jpgIMG_3731.jpg.e062f4d36c689955d794e59303d3db33.jpg
Lower portion of the hull is done except for lots of sanding and finishing:
On to the next part!
Lyle
"The only thing that stays the same is the constant state of change"
Completed Builds:
Occre HMS Terror - https://modelshipworld.com/gallery/album/2065-hms-terror-occre/
NRG Half Hull Project - https://modelshipworld.com/topic/23546-half-hull-project-by-lylek1-nrg/
1:130 1847 Harvey - https://modelshipworld.com/gallery/album/2125-1847-baltimore-clipper-harvey-1130-scale/
Scott Miller's Sea of Galilee Boat https://modelshipworld.com/topic/29007-sea-of-galilee-boat-by-se-miller-120-scale-lylek1/
In progress:
Artesania Latina HMS Bounty - https://modelshipworld.com/topic/26817-hms-bounty-by-lylek1-artesania-latina-148-scale/
Waiting for dry-dock space:
Model Shipways - USS Constitution
Master Korbel - Cannon Jolle 1801
A Scratch build -TBD
Link to comment
Share on other sites
Down to the last 3 planks and planking the counter and transom. Some decorative trim installed... more of that to come.
Decided to change the color of the wale too:
Should finish this weekend... depends on the sanding and finish. Planning to use Boiled Linseed Oil, 2-3 coats with a little steel wool sanding between coats.
More pictures later in the weekend!
Lyle
Completed Builds:
In progress:
Link to comment
Finishing the final planks...
6F98A2EE-A6C8-4FB3-AFF6-A911128F6DB2.jpeg.7f26ec5a5afbcc47bdc4ac47aecf5b78.jpegAD5FDB36-8CE2-4EE9-A74A-136F85F593C3.jpeg.0da79b676981d3c4f2f51e2ce6b55fa9.jpeg
Trim and rail caps... I decided to do something a little different but with similar results. Using some wood leftover from a previous build, I made the rail caps and the trim:
All done except the linseed oil!
Oh... and the mount. That will be a few days.
Linseed oil and off the board coming up!
Lyle
Completed Builds:
In progress:
Link to comment
Two coats of linseed oil with a light buff with steel wool between the coats.
I've removed it from the board and have a plan for mounting it. I'll post the final product in the next few days!
I have thoroughly enjoyed doing this little project and I learned a lot... primarily through my mistakes!! They are easy to see for the trained eye but am happy with final product and of what I learned.
Lyle
Completed Builds:
In progress:
Link to comment
12 hours ago, Cleat said:
I'm glad I came across this log.  I was frustrated with planking during my first build.  I found a reference to the kit and I'm considering it for my second build.  I'll be referencing your build.
I highly recommend it! But keep in mind, if you are building from a kit, the planks come pre-cut. You can still use many of the techniques but unless you purchase some matching material, it will be difficult to do some of the things you'll learn... For example the wider planks at the keel...
I'm planning to start the HMS Bounty and I will be using many of the things I learned.
Good luck and let me know how it goes!
Lyle
Completed Builds:
In progress:
Link to comment
Very nice job.  That linseed oil makes the basswood glow.  Thanks for sharing.
Toni
Chairman Nautical Research Guild
Current Builds:     NRG Rigging Project
Completed Builds: Longboat - 1:48 scale       HMS Atalanta-1775 - 1:48 scale       Half Hull Planking Project      Capstan Project     Swallow 1779 - 1:48 scale               Echo Cross Section
Link to comment
  • 4 months later...
I finally got it mounted! Couple of screws in the plate and it's ready for display!
Lyle
Completed Builds:
In progress:
Link to comment
The instructions plus the photos should give you a good guide but below are a couple of on-line dictionaries that should help.  If you want a good print book The Oxford Companion to Ships and the Sea edited by Peter Kemp is what sits on my shelf.
I am not usually a fan of Wikipedia but this reference is pretty good.
https://en.wikipedia.org/wiki/Glossary_of_nautical_terms
http://phrontistery.info/nautical.html
https://officerofthewatch.com/tools/maritime-dictionary/
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
North Shore Deadeyes
Butch O'Hare - IPMS
Link to comment
  • 1 year later...
6 minutes ago, MaryG said:
Thanks so much for your half hull planking log.  I received my model a few weeks ago.  I am so nervous to start but need to dive in.  I know your blog will help me along the way.  You did an excellent job!  Beautiful!
Thank you!
Good luck.
Let me know if I can help!
Lyle
Completed Builds:
In progress:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
