HMS Flirt 1772 by drumgerry - Vanguard Models - 1:64 Scale.
29 minutes ago, drumgerry said:
First planking finished!  I feel like there should be an award or something for getting to this point 😁
I agree! Congratulations getting through it, that’s quite the milestone in my opinion and you did a great job!
Link to comment
Share on other sites
Well done Gerry!
That’s a great job on the first planking. I wouldn’t say you are slow - you clearly work steadily and carefully and the results show. You’ve produced a  perfect base for the second planking.
Derek
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
Link to comment
When doing the first layer of planking I miscalculated how many planks had to fit into the space particularly at the stern where I had to use stealers to make up the gaps.  As a newbie it was my lack of understanding of the process.  Actually getting some practical planking experience it's a little clearer now in my feeble mind.
So in anticipation of doing the second planking I feel I need a proper sense of the space I'm dealing with and how many planks need to go into it.   To that end I've measured the distance from the master plank down to the keel and marked a midpoint at various points along the hull.    I've used this as a guide to divide the hull into two approximate bands with tape (the lower edge of the tape marks the bottom of the top band).  The line that the planks will follow looks OK to me I think.
I'll make up tick strips next for each band for 10 planks for the top band and 11 for the bottom.  Hopefully I'll end up with a neat and relatively even result.  Most of it's getting painted anyway so it doesn't really matter that much.  It's all part of the learning process for me though.
Cheers, Gerry
Link to comment
  • 10 months later...
  • 2 months later...
Hi Glenn
Gerry decided to sell the part-finished project and i was able to grab a myself a bargain!
Not sure how to proceed with this as it was his build diary. Also not sure i can keep up his high standards lol
So, do i continue the build from here, or start a new diary linked to this one?
Any thoughts anyone?
Link to comment
Glad to see you will continue this build on a new build log. Good luck!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
