The next task as to square away the lines.  After cleating off the jib sheets, I wanted to coil the remaining line in a Flemish coil.  I knew I'd have to glue the coil into a round, but didn't want to try that right on the deck.  I clamped a small piece of glass from a small picture frame into a hobby vice and positioned that next to the cockpit.  I then carefully coiled the line using tweezers to coil the line and my finger to hold the coiled line down.  Once I got the coil to the size I wanted, I used a drop of CA to hold the coil together.  I used some accelerant to speed up the CA cure, then slid the coil onto the deck.  I had to glue the coil down to it laid flat.  After repeating the process on the other side I cleated off the main halyard and coiled the remaining line and hung it on the pin at the mast.  I coiled the mainsheet and left it on the cockpit grate.  All that's left to do is place the anchor on the fore deck and coil the anchor rode.
The next task was to square away the lines.  After cleating off the jib sheets, I wanted to coil the remaining line in a Flemish coil.  I knew I'd have to glue the coil into a round, but didn't want to try that right on the deck.  I clamped a small piece of glass from a small picture frame into a hobby vice and positioned that next to the cockpit.  I then carefully coiled the line using tweezers to coil the line and my finger to hold the coiled line down.  Once I got the coil to the size I wanted, I used a drop of CA to hold the coil together.  I used some accelerant to speed up the CA cure, then slid the coil onto the deck.  I had to glue the coil down for to lay flat.  After repeating the process on the other side, I cleated off the main halyard and coiled the remaining line and hung it on the pin at the mast.  I coiled the mainsheet and left it on the cockpit grate.  All that's left to do, I think, is place the anchor on the fore deck and coil the anchor rode.
Edited by MichaelW
Using some skills from placing model railroad ballast, I soaked the anchor rode in a 1/3 rubbing alcohol - 2/3 water solution.  That made the line very pliable.  I then used the handle of an Xacto knife to prepare the coil - it was the right size.  I carefully looped the line into a normal looking rope pile.  I then used very dilute white glue with a dropper to soak the line with white glue.  Let dry overnight.  I then seized a loop for the anchor shackle.  To make it easier to tie off the rode on the Samson post, I used a dropper and re-wetted the line with the alcohol/water solution.  Done.
Edited by MichaelW
Corrected my math on the alcohol-water mixture.
Beautiful model.  Congratulations on finishing this kit and thanks for sharing your build with us.
Ryland
               - Nautical Research Guild
Very nice, display with pride!
Cheers,
Bill T.
Take care folks, always appreciative of everyone's support!
Bill T.
Finished Builds:
Revell:  Cutty Sark 1980 (1/96 Plastic); Thermopylae 1981 (1/96 Plastic); USS Constitution 1983 (1/96 Plastic), USS United States 1985 (1/96 Plastic)
Midwest Products: Chesapeake Bay Skipjack Success Series (2001 Wood), Booths Bay Lobster Boat Working R/C Success Series (1"-1' 2002-2019)
Blue Jacket Shipcrafters: Yankee Hero (3/8-1 2020 on MSW), Revenue Cutter 1/48 11.03.2024
Congratulations and nicely done. I enjoyed following your log.
  • 11 months later...
Hello Michael, I realize you finished this project one year ago but I have a question. I'm building the Yankee Hero right now and I'm at the point of installing the toe rails. I noticed you glued the rails to the hull just below the deck. It was my understanding that they are to be installed on the deck at the very edge. Was this personal preference on your part or am I reading the manual incorrectly?
