Bob,
Just found your build...great job. Very inspiring. Plan on following if ya don't mind?
Enjoying the banter with Nenad as much as the build!
Keep up the good work
John   B)
Current Build: MSW 18 Century Longboat 1:48
Next Build:    MSW Bluenose 1:64
Thanks, Redbeard;  pull up a chair!  My friend Nenad always keeps things interesting... :D
After coppering the rudder, I knew there would be a "patina mismatch" with the hull.  The rudder almost looks pink from a distance....  I'm going to say that the rudder was lost in heavy seas, and replaced with a new one...  (That's my story, and I'm sticking with it :10_1_10: )
Seriously;  It will probably take another 2 to 3 years to complete the ship, at which time the oxidized copper on the rudder and the hull should match.  (This copper tape was all from the same roll, BTW.)
Edited by rfolsom
Some riveting on gudgeons?
Very nice work. Think forward how to mount them. It is not easy !
CA might be messy option, and some tests how cooper and accetone live together may be usefull. Also in such a scale Alu gudgeons are too hard to stay in place you need them.
Do not worry about color difference. Some kind if monkey live whole their life with red back
Edited by Nenad M
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
very nice rudder..........well thought out  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks for the kind words, gentlemen.  Nenad;  I am in the process of determining the rivet/bolts for the gudgeons, but they will be present.
I would like them to serve a structural purpose, (i.e. actually holding the gudgeons on) so I don't have to use any CA.
Keith;  The topgallant rail is here to stay, for better or worse, and I'm ok with how it looks. :)
Bob i have used peco model railway track fixing pins for the bolts on the pintles and gudgeons on some builds- they even come ready blackened! For my cutty i used billings panel pins left au natural.
Keith
Edited by clearway
Keith;   I'm not sure if they're the same, but I have a bunch of pins that came with my Billings kit.   I'll have to do some testing soon, I believe...
FB friend of mine, Roland Vlahovic, who is a world champion in modellship this year Bulgaria ( Naviga 2014), his tip for structural connection is - a small pegs of CA on the top of nail before nailing. Add to that my personal experience that still should be prepared (drilled) hole through the hinge and the copper and the wood slightly smaller diameter than that of a nail. I hope it helps
Nenad
In progress:
Content of log :
Past build:
Thanks, Nenad.  I'm still thinking about the nails.  In the meantime I'm testing CA to hold the pintles to the gudgeons.  I think it will work out ok.
Picture shows my prototype hinge assembly, before drilling and trimming.  (Admiral asks: "What are you making, a fan?" :P )
Four "fans"...  I know it looks weird, but the hinging areas are consistent;  everything else was left long and wide, to be trimmed to size individually later.  I'm going to let the CA cure overnight before trimming and drilling....
it can be a bit messier but epoxy resin provides a really strong bond as well and i always use this if possible for glueing eyes/ pins etc.especially if they are going to be slightly load bearing.
Keith
Keith;  I was originally planning on epoxy for these, but since I didn't have any on hand, and these hinges do not actually support the rudder in my build, I tried CA and found it to be adequate.
Lawrence, thanks for the kind words.  I plan on using brass to fabricate all the yard and mast hardware, but that's a ways down the road, and my brass inventory is very limited.  Also, my soldering equipment is not up to structural soldering;  new toys must be purchased in the future...
A little bit more work..  I have trimmed, drilled, and filed the rudder side of the hinges..  The ship-side gudgeons have yet to be finished.  They are shown taped to the scrap piece of wood that I used for a drilling back.  It also keeps them together and somewhat protected.  I will simulate bolts with small lengths of 24 gauge wire. (0.51 mm).  The holes are drilled with a 0.55 mm bit, which broke, so I'll be stalled until I pick up some more bits. :(
Bob
look at this tutorial - how to make nails with little heads, it can be useful
In progress:
Content of log :
Past build:
Wow.
Thanks, Nenad!  I couldn't tell if it worked or not until I took these macro photos...  (One nail is in hole above toothpick, top center)
Edited by rfolsom
Try the thinest paintbrush you can find and magnifier. Then go forward slow and precise as you can. Results will be above you expect. First test color - will it cover Alu.
Nice work my friend.
Edited by Nenad M
In progress:
Content of log :
Past build:
Thanks, Nenad;  I'm doing paint testing...
Marc, thanks for checking in, and it's great to hear from you again!  Hope the new job is going well, and I hope to see some new posts in the near future...
BTW, the Pig is well trained, and will be paying a visit to you in Virginia to inspect your progress... :P
All the best,
~Bob
Ok.  I started initial installment of hinges (semi-painted) to the rudder, using CA at the hinge points, but letting the ends free.  Once dried, I will drill into the rudder through the pre-drilled gudgeon holes and affix the loose ends with small nails (hopfully NO CA).  The sternpost gudgeons remain unfinished, as I decided to make the whole rudder/hinge assembly first, then fine tune how it meets with the ship.  These will be evened up and trimmed to approx. 7mm, and drilled with 3 or 4 holes, for accepting the nails.
This will be OK Bob. Just step by step
In progress:
Content of log :
Past build:
Hi Bob,
Don't know if your hinges are already glued, but you might want to bend them back the other way toward the rudder and then intall.  I see that they are bowed out away from the rudder.  I don't know how thick your hinges are, but I had trouble with mine (which were also curved out) wanting to pull away and had gaps between the hinge and the rudder even when nailed.  I ended up removing them and bending them so that they bent toward the rudder and had to be wedged on.  They ended up staying in place with no issues. I added epoxy as I slid them into place.  I then nailed into place.
by the way spent the evening catching up on Nenad's and your builds.  Nice work!
Take care,
marc
Edited by keelhauled
Hey, Bob, we are inpatient !!!!!
In progress:
Content of log :
Past build:
Thanks Keith, I will definitely put a dab of ca into the holes...
Thanks for the advice Marc..  hinges are already glued, but the material they are made from is very flimsy aluminum from a can, so I think they will lay ok when I finally get the courage to affix them.  (I may be wrong, hence the "courage" part)  :D
I did a little work tonight, but I'm coming off a mild case of stomach flu (about three days worth) so I've been out of the shipyard.  Hopefully tomorrow will be producing results....
Take care my friend. There is a good receipt from alternative medicine I could send you (hot brandy) if you wish
Natural domestic selfmade Serbian brandy of plum (Shljivovica) is esential if you can find it. You are brand new in next 24h
en.m.wikipedia.org/wiki/Slivovitz
When I was in Army, realy hard Fly get me down with 41,5℃ body temperature, and I didnt know who I am and where I am. And, as in every army, there was smuggled alchocol Shljivovica, friend made this medicine, and I was brand new in the morning. From that time, there is always Shlhivovica in my home, even I do not drink it (rather good wine or beer or little whiskey with many of ice) for "medical" purpose
Or just a hot tea therapy - min 2-3 lit every day. Yes, you will go often ... but it helps a lot
Edited by Nenad M
In progress:
Content of log :
Past build:
Thanks, Nenad and Marc.
I feel much better indeed...
After three days of eating hardly anything,  I made pork and cabbage eggrolls last night.  Admiral ate one, I finished the other eight.  I then cooked the remaining pork (close to a pound) and ate that as well (!)  Also had breakfast this morning;  I never eat breakfast!
...the runaway pig has been outdone... :P:D
Nenad;  even though I'm pretty much over this bout, I'd be interested to see your recipe.
~Bob
Edited by rfolsom
glad to hear your doing better ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
