I bought this kit online a few weeks ago, and I’m ready to start building it now.  This is the biggest kit that I’ve done so far, and it was relatively expensive, so I want to get it right.  I would like to try to add some chipping effects on the hull, and I have some chipping fluid from AK interactive, but I’m not sure about what colour to do the base coat in.  Any help or advice would be greatly appreciated, and I’ll add some pictures once I have something worth taking a picture of.
You may want to look at the work done by RGL (Greg). He's a master of this kind of work.  CDW is another gentleman to review his work. Have fun and welcome to MSW.
Ken
Started: MS Bounty Longboat,
i will be following, what tools do you have?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
I would think that a hobby knife or scalpel would also be useful, along with a strong carpet blade or metal ruler to help fold and shape the PE.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
I've assembled and primed the hull now, but I'll be renting a cottage for the next week, so I'll have to put the model on hold for now.  Also, does anyone have a good technique for painting all those tiny details on ship decks, especially for 1/700 scale?  I've tried using tiny pieces of tape, but that never seems to work for e, and I always resort to doing it by hand.
13 hours ago, RGL said:
Tape or blue tack, as pretty much everything has to be airbrushed
Are there any YouTube videos explaining this technique?  Every time I try, a lot of paint ends up bleeding through, and I end up having to do it with a brush
Thanks
  • 3 months later...
I’ve sorted out my airbrush, and have finally gotten around to base coating the hull.  I decided to paint it black, and then add some rust effects with oil paints.  Next, I’ll put on a few layers of chipping fluid, and then the hull color.  I got a little carried away with the rust, but it won’t be all that visible once the hull color is on.
15 hours ago, RGL said:
What are you using? Airbrush and what type of paint?
I'm using an aztek a470 airbrush with tamiya acrylic paint.  After several hours, I managed to get it working again, but the airbrush is very difficult to put back together again once disassembled.  I do not believe that the airbrush was meant to be disassembled, as doing so voids the warranty, but I got it second-hand, so I figured that I might as well try.
Tamiya acrylic paints have to be diluted with their thinner.
I use 50% paint, 50% thinner in the summer time.
In the winter, you may want to go more 70% paint and 30% thinner. Otherwise, it will run way too much.
But you probably know all the above, already.
Yves
I’m constantly stripping and cleaning my airbrush, and I do like their paints, which I think with Tamiya lacquer thinner. Acrylics dry the top very quickly so I also have a cotton bud dipped in clean thinner to while the tip regularly.
Greg
I should probably start doing that regularly
