Hello everyone,
Well, I'll give it a try and start my construction protocol for the Le Coureur 1776 kit from CAF. It is my second model as I beg your indulgence if it is not perfect. However, I ask for constructive criticism as well as tips and tricks.
I deliberately chose this model because it comes very close to a POF and I plan to deal with a scratch construction later.
You can choose from the HMS Beagel, the frigate Naiad, La Renommee or the La Jacinthe. However, I still need some time to practice.
Tobi
Greetings Tobias
Member of the:  http://www.arbeitskreis-historischer-schiffbau.de/
On the workbench:
Corvette La Palme (L'Amarante) from 1744 POF based on plans by G.Delacroix
https://modelshipworld.com/topic/32046-la-palme-by-tobias-136-pof/
LE ROCHEFORT - Harbor yacht from 1787 1:36 by Tobias (monograph by G.Delacroix)
https://modelshipworld.com/topic/34810-le-rochefort-1787-by-tobias-136-harbor-yacht-from-ancre-monograph/
Le Coureur - Kit from CAF with the plans from Ancre
https://modelshipworld.com/topic/29843-le-coureur-1776-by-tobias-caf-148/
First, I built a small platform with storage space.  And in addition Ancre's monograph worried about comparing the plans with one another.754C1219-A5C5-42BE-83B3-9D0F618E7A56.thumb.jpeg.b4649d5bf4a447d7fb9772ebedb6641a.jpeg
Greetings Tobias
On the workbench:
I ordered the kit from Tom in China on July 14th, 2021 and already on July 19th it was almost with me there was a number rotated in my postal code - so it was with me in Bavaria / Germany on July 21st 😉.  First of all, I checked the content and had to find out that two plates were missing.  I got in touch with Tom and thanks to the great aftersail Tom sent me the missing parts immediately.
1Y and 1YF not in the Kit
Greetings Tobias
On the workbench:
A few pictures of the first assembly work now follow
Greetings Tobias
On the workbench:
In the next few days I was busy filing the individual frames.  Removal of the laser carbon, beveling the individual teeth and grinding.  See for yourself 😉.
Greetings Tobias
On the workbench:
A few days later, first dry assembly
Greetings Tobias
On the workbench:
The day came when I dared to go to the rear, very tricky, a constant removal and installation, adjustment, etc. In the end I was very satisfied with the result, even if it took two days to adjust the whole thing.
Greetings Tobias
On the workbench:
When all of this was done I could start with the interior planking.  I would like to say that it is not perfect, both in terms of my work but also in terms of the kit because the pages are not complete and you have to fill in gaps.
Greetings Tobias
On the workbench:
In the next step I started with the load compartment construction and decided to continue with the exterior planking.
Greetings Tobias
On the workbench:
I need about a week for the planking.  In the next step I started to provide the planks with copper nails and then blackened them.
It's crazy work 🤪
Greetings Tobias
On the workbench:
So it's September now and I've started with the second page, but I'm not going to plank this completely.
This is the status from the weekend, new updates will be available in the next few days.
Greetings Tobias
On the workbench:
Thank You Yves 👍
Greetings Tobias
On the workbench:
Thanks for the likes and the nice comments.  Filing the clinker is not that bad at all.  Now I would like to show you a little update about the second page.  I hope that I will be finished in the next few days and can start with the inside.  Wishing a nice evening.
Greetings Tobias
On the workbench:
Hello and have a nice good evening, today the second page was finished and is ready to get its first coat of paint and for the next few days I will be busy with nailing.
Greetings Tobias
On the workbench:
Hello everyone, a little update on what has happened in my little shipyard in the last few days.
Greetings Tobias
On the workbench:
The first work on the interior construction.
Greetings Tobias
On the workbench:
Greetings Tobias
On the workbench:
Hello everyone, thank you very much for your interest and your likes. In the last few days I have constructed the loading area in the middle of the ship.  In doing so, I deviated a little from the plans and brought in some personal inspiration.  I also put in support walls below the loading platform.  I filled one side with ballast stones.  Between decks and bulkheads were made.  At the front bulkhead there is a hatch to keep it moving. I aligned the frame of the hatch on double-sided adhesive tape and then milled a groove with the milling machine.  I also milled the sliding door.  I am happy that everything works.
thanks for watching
Tobias
Greetings Tobias
On the workbench:
Good morning  guys.  In the last few days I couldn't do too much at Le Coureur, but I would like to show you a little update.
Greetings Tobias
On the workbench:
So first of all thanks for the likes.
Hello and have a nice Sunday evening.  I haven't been able to build too much on Le Coureur in the last week.  Now it was time to construct the partition wall with the doors, but I had to find out that everything didn't fit somehow.  The wall and the doors were about 2-3mm too high so I started to reduce the size of the floor and grind down the bulkhead of the ammunition chamber that brought about 1mm.  Next I put in the beam and the walls on the left and right.  Then I built a door frame because I really wanted movable doors.  I was able to implement everything and I am happy that everything worked out.
Oh yeah, the stove and the dresser were the smaller projects this week.
Greetings Tobias
On the workbench:
Hello everyone, what has happened in the last few days, well, I provided the doors with liquid glass and continued with the interior decoration.  Sheets and pillows sewn as well as 5 sacks, 11 barrels made as good as possible.  Unfortunately, I don't own a lathe or turning machine, so a mandrel and the drill had to do its humble job, I'm not yet satisfied with the result.  Fittings (barrel rings) as well as frames and lids still have to be made.  I wish everyone a nice evening.
Greetings Tobias
On the workbench:
Good evening folks, it's done, the lights are on.
Greetings Tobias
On the workbench:
Hi everyone, in the past few days I've been finishing boxes and barrels and filling the hold and installing the beams for the ship deck.
Greetings Tobias
On the workbench:
Hello everyone, what's new: make a new rudder because I didn't like the original, and finish the stern.
Greetings Tobias
On the workbench:
