Yes, these pliable beech strips they sell in Germany come very handy. I have used them for the same purpose.
I suppose they (pre)treated the beech in a similar way Thonet did to create their bent-wood chairs, but I don't know.
Yes Eberhard,
I bought those beech strips some time ago already for one of my other models. Now they come handy and find their destination. Are they only available in Germany, I trust they certainly will be of international use for modelers.
Nils
Current builds
-Lightship Elbe 1
Completed
Update
Am starting with the masting and the rigging. The tackles for the boats was the first to start up with
Nils
Current builds
-Lightship Elbe 1
Completed
Update
bot masts ready for the standing rigging.....
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you John,
I`m trying to plan in all the leftover blocks of my former models, so it may turn out a mix of block colors (dark and pearwood ones).
Nils
Current builds
-Lightship Elbe 1
Completed
Update
Standing rigging and shroud wires now done with tin galvanized flexible steel wire (19 x 0,1mm thick )
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you John,
yes those are working bottlescrews (M1,4 )
Nils
Current builds
-Lightship Elbe 1
Completed
thank you Igor,
your fleet of mini scale- and bottle ships is amazing and very nice to see. At least you should not have problems with the places for display. When I was young I also built a few bottle ships for the family members as a christmas present as I  had limited financial playground at that time....
Nils
Current builds
-Lightship Elbe 1
Completed
Update
fitted the skylight, the mainsail sheet and the two uncompleted companionway hatches....
I`m trying to get the aft name sign and the port name reduced to the right size. The windows / excel tool allows to get the display in a rounded, bent shape, but only in a too large size. This is to compensate the tapered aft-section. I intend to print them on transparent self-adhesive foil and cut out the text for bringing it on to the hull surface. It looks like my printer has no built in decline functionDSCI8582.thumb.JPG.5eb467c7e056f6f8da8275b3edd18ab4.JPG
Nils
Current builds
-Lightship Elbe 1
Completed
Nils
I am coasting along between builds and catching up on some of these logs.  I love some of the techniques you have shared to make things like the boat davits work.    I too have struggled with copper tape and look to find a better solution and think the copper sheets look great. I found the self adhesive tape never lasted. After weeks it would curl up on me.  I  ended up using contact cement on it too.  I truly engoyed may read.
thanks for sharing
jon
Hi Jon
Hi John
I thank you both for your kind comments. I`m at the time of installing some details, before I start making the six sails. Finaly I`ve found a way to decline the lettering for the tail name and home port.
For the companion ways I decided to show one (open hatches) and the other one (closed hatches). The two gaff spars and their rigging will be next in the pipe.
The anchor attachment is also done as well as the two main sheets with tripple sheet blocks, so all is coming on quite well....
There was the question in the beginning, why the odd scale 1:51, but now the model turns out 740 mm length over all, which turns out to 37000 mm for the actual ship, who`s rating is 37 meters and therefore the scale is now corrected to 1:50
Nils
I onls put one admirals typ anchor with rigging at the stb side. A smaller one (emergency) will be placed at the inboard front bulwark later on
the forward placed companion way with closed hatches and doors. The formast boomtackle differs to the mainmast boom tackle, probably to hook it out more easily when opperating the boats
aft companionway and skylight. I chose an 8-window typ in order to allow more light down into the ship
there is a slight problem with the forward sail sheet when the boats are in place on deck. I trust this must have been the same situation as with the actual boat. The boat tackles rest (hooked in) at the davits when not in use
tail lettering and attached tail lightDSCI8588.thumb.JPG.0f0e3f40546f8ef9e59f37d87a5089ce.JPG
the upper rudder shaft will be shortend later on
Current builds
-Lightship Elbe 1
Completed
Thank you John,
I`m pleased that you like it
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Jim,
many thanks for your words, I also had a look at your models, starting with the excellent built Pinky Schooner.
I congratulate you to your skill on this behalf....
Nils
Current builds
-Lightship Elbe 1
Completed
Update
made the sprit spar netting and the belaying rail for the 3 for-/spritsail downhaulers....
I ran out of rigging rope in the moment and expect the delivery for this week. It looks like all my leftover blocks were just in the required quantity to suit the needs
Nils
a piece of leftover mesh from my Pamir netting
the wooden strip is to prevent too much glue on the netting inside. The outer will be cut off after curing
belaying rack for the sprit sail setting lines
Current builds
-Lightship Elbe 1
Completed
Thank you John
Nils
Current builds
-Lightship Elbe 1
Completed
Update
progress with the rigging, beams and gaffs, nav. lights...
Nils
nav. light brackets made from 0,8mm ply
fastening rails for clipping to the shrouds
rigging will go on when the sails are made
Current builds
-Lightship Elbe 1
Completed
She is coming along really well Nils. Are you planning to model the full set of sails?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Many thanks Keith,
yes. she will be carrying all 6 sails set....
I have`nt sewn sails for a long time and hope that it will work out OK, depending also on the condition of my wife`s sewing machine
Nils
Current builds
-Lightship Elbe 1
Completed
Nils - Maybe she deserves a new one😀
With 6 sails I suspect she will look magnificent.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Do you really want to spoil your model with sewn sails ? I would think twice about this, because they never look right. I would rather go for something like silk-span (Japanseide), glue and paint. There are various examples for such sails her on the forum. They look much more to scale.
Eberhard,
I`ll try with one sewn sail first and see what it looks like....
Nils
Current builds
-Lightship Elbe 1
Completed
Update
when looking at the boats bow-and sternposts I always had the relating coment, some mails ago, by Wefalck nagging at my mind. So I decided to overwork the boats model for casting accordingly. Now the "clinker planking" ties up with the rear side of the thinned out posts, I provided  a cast  rope-fender (tawling ?) all around, and reinforced the visable frame ends inside the bulwarks. My casting tool was adjusted and a new silicone mold was made....The first results are pleasing for myself
Nils
the overworked model
fender rope attached
first cast results
Current builds
-Lightship Elbe 1
Completed
Update
finished, the new set of boats. I wo`nt give them an underwater painting like the former ones, plain white hulls I think look better
Maybe I`ll put the former obsolete ones on sale at Ebay
Nils
Current builds
-Lightship Elbe 1
Completed
