I'll just stand in the back and watch
Current Build: Fair American - Model Shipways
Awaiting Parts - Rattlesnake
On the Shelf - English Pinnace
                        18Th Century Longboat
I stand firmly against piracy!
2 hours ago, ECK said:
With this many people watching I might get stage fright !
We're not a mouthy, nasty bunch.
So after putting on my N95 mask (seem to have a lot of those around these days) started sanding. I used an orbital sander with 120 grit paper.  It has an edge that flexes and can shape the contours nicely. Also have a vacume next to it to get the dust.
IMG_5443.thumb.jpeg.ed9f2b177e2d0b880cccf0c60a9576f7.jpegIMG_5446.thumb.jpeg.564ebd7d0897c7b2642a097fa2360d4e.jpeg
Although I over did it on the fist side I tried.
Did better on the bow
Much easier to work with than plywood, no splinters, less dust. So far parts fitting together very nicely compared to other kits.
You're doing a great job of Sphinx. You'll notice some design similarities to Indefatigable.
Ongoing:
I know, Anxiously await its release. Hope to make Indy my Christmas present while awaiting the Victory. Have to really be careful with the tops of the bulkheads. Also sanding the hatches has to be done very lightly as tend to brake easily. Find putting in the gratings gives a bit more stiffness for sanding. Funny the shield symbol next to your name is very similar to Duke University's
1 hour ago, ECK said:
As you can see the top of the ribs have taken some combat damage
I suspect most of us have had the same damage.   I know I have.
I'd fair those filler blocks in a little more between the bulkheads. They shouldn't be standing proud of the bulkheads as they do.
Ongoing:
Second planking done.Using crazy glue leaves a lot of skin to be sanded off the hull. One thing in the instructions is , although it says to draw the waterline, there is no mention of where it should go, what height from the table in the cradle.
IMG_5501.thumb.jpeg.4cd132cd63a00a5379a687e2d0ad06f1.jpegIMG_5500.thumb.jpeg.c4984f83a29db2172a0d43b473746f09.jpegIMG_5502.thumb.jpeg.99e8e4a306f6c19d2a1ef0e24091b984.jpeg
The plan sheets should show the waterline, take the measurement for its location from there. I'd indicate it in a few different places, say the stem , amid ship and on the rudder. This will make it easier to see if you have the water line level with the marks .
The water line is clearly shown on one of the plan sheets. The reference points on the stem and stern posts also help which can seen on the plan sheets.
Hope this helps.
Glenn (UK)
I find a good place to start is measuring the distance from bench top to keel underside, at both both and stern. Make sure they are the same so you know the hull is parallel to the worktop. Set your waterline tool at the stern waterline position shown on the plan and then touch this at the bow to confirm the plan position.
Ongoing:
