First Class Sloop of War Constellation by Jerry Todd - 1:36 scale - Radio
Baltimore's PortFest is May 18th - I'm going just to see that "six-foot sailing model of USS Constellation!"
Jerry Todd
Click to go to that build log
Constellation ~ RC sloop of war c.1856 in 1:36 scale
Macedonian ~ RC British frigate c.1812 in 1:36 scale
Pride of Baltimore ~ RC Baltimore Clipper c.1981 in 1:20 scale
Gazela Primeiro ~ RC Barkentine c.1979 in 1:36 scale
Naval Guns 1850s~1870s ~ 3D Modeling & Printing
My Web Site
My Thingiverse stuff
Link to comment
Share on other sites
Link to comment
You may have been late with the cat-heads but you made it fit very well.
Bob
Current build:  SS_ Mariefred
Link to comment
I'm pretty good with cats actually, Bob. We'll see how I do with dogs when I get to the capstan.   That's a-pawling isn't it?  ;)
Pat, there will be pictures, and probably some video too.
This morning was spent making the starboard cathead.  Seven layers were cut from 1/16" bass sheet, three of those cut short to allow for the sheave slots.  The short layers were glued to long layers as well as walnut dowel sheaves, and the bass end pieces from the cut-off portions.
post-961-0-73794100-1430851534_thumb.jpg  post-961-0-13576500-1430851535_thumb.jpg
Again the hull was pierced to make a socket for a cathead.  The position marked; precut with a knife to keep the glass from tearing out; then successively larger holes drilled.  The final hole was squared by roto-tool with a burr on a flex-extension and a lot of knife and file work.  There's about 1-1/2 inches inside the hull and a little over 2 inches exposed.
post-961-0-48161300-1430851535_thumb.jpg  post-961-0-80913200-1430851535_thumb.jpg
Knees were made from oak and glued to the cathead, though the cathead isn't attached to the hull as yet.  Everything will be epoxied in place and pinned with brass rod; any gaps filled, and all painted black and white.
Jerry Todd
My Web Site
Link to comment
Yesterday I did some filling and paint touch-up, and began bending sails.  Today I began jury rigging.  So far the two tops'ls are up.
Last time I did this event the sails were lifting the coarse yards, this time I ran the tops'l sheets down to deck to act as a down-haul and prevent that from happening this time.
The fore-topmast-stays'l and the jib are up minus their sheets.  I'll probably set the outer or flying jib as well.  Because of the added sails, I'll be rigging rudimentary shrouds and stays especially for the t'gallant poles.
The top masts are lowered so the garage door won't hit them - just in case.  Once the sails are on I'll take a few pics outside
Jerry Todd
My Web Site
Link to comment
Link to comment
That is one impressive model, Jerry.   I'm wishing I could come to Baltimore to see her sail.
Link to comment
What are you using for your sails and are you going to tint them any?
David B
See: This Post in this thread
Jerry Todd
My Web Site
Link to comment
Not the best image, but the first of her with t'gallants up.  This is pretty much what she'll be wearing to the ball next weekend.
Jerry Todd
My Web Site
Link to comment
Worked a bit on getting the mechanics and electronics into her.  Mounted the on/off switch under the skylight.  The wires that ran from the switch charging lead harness to the servo try and Rx were cut to make the harness separate from the servo rig using a two prong plug, but the "crimp-on" connectors slipped right off as soon as I tried to separate the plug - so some time was spent trying to find the soldering iron.
Tomorrow will be a drag everything in the shop out onto the driveway day and get this feces sorted or die trying.  If that's the case, BTW, I won't be posting pictures.
post-961-0-11436600-1431316604_thumb.jpg  post-961-0-68124500-1431316604_thumb.jpg
Jerry Todd
My Web Site
Link to comment
Let us hope that no builder gets hurt or killed in the sorting out of the "stuff".... I shudder to think about the amount of paperwork that would need to be filled out.   You're tougher than she is... :)
Link to comment
Well, saying out loud that I intended to do something outside was a mistake.  The entity that always ensures it will be cloudy whenever there's an astronomical event I want to see, apparently made sure it would rain today, so I couldn't move the garage/shop contents outside to bring some order to my chaos.
Edited by JerryTodd
Jerry Todd
My Web Site
Link to comment
Cut some 1/2" by 1" strips from a plank of balsa I have kicking about and began capping off the port side hammock rails.
post-961-0-89182000-1431474467_thumb.jpg  post-961-0-38336400-1431474468_thumb.jpg  post-961-0-75293400-1431474468_thumb.jpg  post-961-0-10930100-1431474469_thumb.jpg  post-961-0-55376500-1431474469_thumb.jpg
Jerry Todd
My Web Site
Link to comment
Got the port hammock rail caps in place with a first coat of paint.  Getting the electronics in order and took a few "glamor" pics
post-961-0-89966000-1431571670_thumb.jpg  post-961-0-50188400-1431571671_thumb.jpg
post-961-0-90659500-1431571671_thumb.jpg  post-961-0-33732900-1431571672_thumb.jpg
Jerry Todd
My Web Site
Link to comment
Looking sharp, Jerry.  I got my fingers crossed that all goes well with weather and ship this weekend.
Link to comment
Last year it was gusting and the wind was bouncing off everything, including the Savannah, which we were right along side of.  Everything on Constellation seemed to work itself loose.  A few weeks later at St Michaels, everything went much better, though the wind was still fluky and variable.
So this year, I'm not too worried with "at the event" as much as getting TO the event in good order.  If it's to strong, too shallow, etc, then she'll sit on the table or get "anchored" for folks to look at.
post-961-0-33443400-1431580364_thumb.jpg  post-961-0-84566500-1431580364_thumb.jpg
Jerry Todd
My Web Site
Link to comment
Wise man... very wise.
Link to comment
Hope everything goes well, we all want to see pictures of her in the water with sails full.
Bob
Link to comment
Worked long and hard on getting her rigged with stays, braces, and sheets.  Tomorrow is adjusting it all, touching up paint, and rebuilding her cradle to allow the ballast tube to sit on it - making attaching and unattaching it much easier.
post-961-0-99225500-1431738312_thumb.jpg  post-961-0-39699900-1431738313_thumb.jpg  post-961-0-73054200-1431738313_thumb.jpg  post-961-0-09219900-1431738314_thumb.jpg
Jerry Todd
My Web Site
Link to comment
Here's some pics from Baltimore's Port Expo for National Maritime Day.  Constellation and Pride of Baltimore both went.  Most of the pics show Costellation with no more ballast than her bolt on torpedo because the pool was still too shallow.  Later I added about 12 pounds of lead shot in baggies inside which brought her down to within 1/2 inch of her LWL.  Not a lot of sailing done - she needs and likes room to stretch out - especially under her keel.
post-961-0-41499200-1431922631_thumb.jpg  Gratuitous stuffed into the van shot.
Set up on the table.  We were in the main tent with the other exhibitors this year.
The pool was at the end of the pier, more clear of Savannah and her interference with the wind.  The pools not very big, or really deep enough for a model like Constellation, but she looked nice on the water anyway.
post-961-0-77722500-1431922471_thumb.jpg  post-961-0-24053600-1431922472_thumb.jpg  post-961-0-60256000-1431922472_thumb.jpg  post-961-0-02269000-1431922473_thumb.jpg  post-961-0-63396100-1431922473_thumb.jpg  post-961-0-21783000-1431922516_thumb.jpg  post-961-0-00200800-1431922474_thumb.jpg  post-961-0-44982300-1431922474_thumb.jpg
Even Pride got a little swim.
I combined all the "sailing" video from the event:
  Edited by JerryTodd
Jerry Todd
My Web Site
Link to comment
Last year and this year :)
post-961-0-02346200-1431923095_thumb.jpg  post-961-0-24417700-1431923151_thumb.jpg
Jerry Todd
My Web Site
Link to comment
She looks very much at home in the water, Jerry.
Link to comment
Looks like a good time was had by all.
Bob
Link to comment
I had a couple of people ask if I took commissions - whatever that means.  I took some Damn Yankee Workshop cards along - we'll see if something comes of it.  Last year someone was bubbling over wanting to write an article for some local magazine - never heard from them either.
Jerry Todd
My Web Site
Link to comment
Hi Jerry
That's a very nice before and after pic which clearly shows the progress made over the past year.
I have to say that wow, she looks nice on the water. If I were you, I'd have been very tempted to take her out of the pool and set her free on the harbour. Now, that'd be a real sight to see!
Well done
Cheers
Patrick
Edited by Omega1234
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
