On 2/11/2024 at 7:08 PM, ships carpenter said:
OHi Kiwiron looking instesting your victory hope my one looks as good I am just doing the canons theys a lot off them.  ships carpenter
Thanks mine is o.k. from a distance. There are real amazing builders on this site. If it wasn't for them I would have lost with the instructions.
Current builds: HMS Victory - Caldercraft 1:72
Completed builds: HMB Endeavour - OcCre 1:54   HMS Supply - Caldercraft 1:64. Fishing boats, Bremen,  Palamos.
Thanks for the likes folks. Thanks a lot Dave, as good as I can do it but always something I could have done better. I was just getting better at the cannons when I got to the last one.
Ron.
Start of the Lantern brackets. I thought the 0.7 wire was a bit flimsy but the choice of bigger wire was forced on me anyway by breaking off the 0.7 drill bit right in the centre of the lantern base. I had to use the 1.5 wire as the 1mm has gone walking. Trying to get the trophy of arms looking reasonable. One of the Lance heads broke off but the sheet under my work bench caught it.
Quarter galleries nearly finished. Just more brass profile to go, not my favourite so far. I gave up on masking tape for the black panels for between the windows so used some 0.5 x 3mm I had from a previous model.
Nice and relaxing getting onto something easy. Side entry port and steps. Tape to stop any rogue steps disappearing inside the hull. The elm tree pump lining flew off across the room but I was amazed to find it again. Fenders and chesstrees next.
Port side profiles done, more painting to do yet plus parts 180 and 194 to fit. Profiles did'nt line up the same way as the plans so I just did what looked alright. The plan measurements were different in reality to my Victory.  I'll make the lids under the channels I need too before gluing the channels in properly and adding their supports. Avoided a few mistakes doing these, If I added my miss adventures to this build log I would be up to page 100 by now. Lots of exercise today bending down under the table, I have'nt dropped the knife on my foot yet but there's always tomorrow.
Impressive work Ron, and I too have had to make a few compromises along the way when trying to get things to line up and work out (approximately) as shown on the plans.....if only to preserve my sanity🤪. Sometimes you just have to accept things and move on. More often or not we, the builder, are the only ones who know....🤫😆
Thanks Graham, I'm well short of your skill level, I love how you did your scrolls. I have had to accept and move on from quite a lot. I have still got the starboard side to try and make a bit better. I'm lucky people who see it think it's an aeroplane anyway.
Start of the lids. No thin wall brass the size I want for the lid ropes available in N.Z. postage from cmb to N.Z. expensive. Found some left over rudder chain for my lid rings the right size. I'm going to add the lids I need under the channels then fit those and the supports. Then the rest of the lid work.
Chain plates done on the Starboard side and lids just under the channels before fixing channels permanently. My channels were a touch too high, it's a bit of a compromise anyway. I covered all cannon port holes as I went. If you haven't done so already put a sheet under your work table makes it easier to find the dropped parts.
