Looks great Kevin! Those gantries really turned out nice.
I wonder if you might get a good effect by lighting your crosses indirectly. Say for  example making them out of acrylic and gluing a red LED externally at the base, or behind, and letting the internal refraction do the work.
It’s just a thought, I’m sure you’ll figure it out and it will be as spectacular as the rest of your build so far.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Andy
kevinaris3 minutes ago
Thank you Andy for your comments, very much appreciated
i have spent the day reworking the lighted red crosses, after posting last night i looked around and found a pile of poo where the cross had been, the heat from the lamp melted the plastic, so using a low heat led i have kept the size the same but thinned out the side frames accommodate the different lamps
i now have four units, and will post photos tomorrow
providing i can get power from the after stack where i left some power lines for this purpose i think i will get a reasonable result
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
On 12/1/2022 at 1:29 PM, Canute said:
This build keeps getting better and better. 👍
thank you, Ken,
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good evening everyone
thank you for comments and likes
this build keeps getting ideas way above my skill levels, i now seem to have a representation of the Britannic, as a steppingstone for someone to come along and show how it should be done, perhaps thats the way the hobby is but if someone was to spend a few more coins than i wish to they could make it look quite nice
things that i should have done
planned electrics before the build started
obtained at least one extra full deck set
found a better source for the deck machinery (pumps, vents fans etc
after working out how to wire the after red cross i moved midships and looked at the floodlighting of the midships cross, yet again the first attempt melted, even though the lamp had more room
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
i have now moved to the front end working around the bridge and the forward stack, but even at this stage i am moving bits of titanic as they dont appear on this hull
most of the lighting is now done, i will try and get nav light to work, but doubt i will be doing any mast lights
IMG_5329.thumb.JPG.77dc5bce2612ccb4140c4b765551105f.JPGIMG_5332.thumb.JPG.248a02513b5bbdc42996162d7c12ff71.JPGIMG_5333.thumb.JPG.4f3d1d6c46b5cecbf6cfda5e14012b3c.JPGIMG_5334.thumb.JPG.d9ada3b2869bc3fc76d95dfd31a515d4.JPGIMG_5337.thumb.JPG.14688b63cb87aaac80ef499f95620fe7.JPGIMG_5339.thumb.JPG.006da9453cbb50746d8475a33d8d151c.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
9 minutes ago, chris watton said:
Looks fantastic, well done, Kevin!
Thank you
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
build progress is going to slow down for a while now (not stop), the cold weather is making it more difficult to handle very small PE, meanwhile i am going back to wood in preparation for my next big build in Feb,
took her out into the winter sunshine and tried to get a few better  photos
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Loooking  superb  Kevin   -    you  are   a  braver  man than me  taking pics  outdoors   during  our   cold  snap.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
i would like to wish everyone Merry Christmas, and hope everyone has a safe new year
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
And to  you  Kevin,     hope  you  and  the family  have a  lovely  Chrsitmas.
OC.
Current builds
Completed works.
