Richard,
Am considering building this to replace a similar sized "store bought" model of Endeavour. Are there instructions provided in English with the kit?
Best
Gary
Thanks,
Gary
Current Build - Rainbow 1934
Prior Builds:  Lucia A. Simpson (Great Lakes Schooner 1875)
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Hi Michael,
It's been a while since I checked in on your build, "Looking Good"....   :D
I have a quick question for you!  I wos wondering if there is any reason you ended all the planks on the same bulkhead?
Cheers,
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Hi
I was extremely happy to find this log, thank you so much for sharing. I built the 1:80 Amati Endeavour a year ago, it was my first build. I had no clue how to plank the keel in a nice way, now I know how it should be done :). Have to admit that I smiled when I read about you using super-glue at the stern, been there done that.
I have just ordered the 1:64 1893 Britannia. Cornwall model boats Ltd advised me to go for the Mamoli one over the Mantua one. Would be interesting to know why you thought Mamoli kits are bad.
Back to Endeavour, any idea how you're going to paint the ultra-thin line just below the deck (don't know what that line is called in English)?
Cheers
Edited by malmoerik
Hi Tim, the reason is, the kit provided stripes are not long enough to plank the hull from bow to stern. ;)
Hi malmoerik, your model looks very nice. At this time I don't worry about the thin line. But I think, I'll use the good old Tamiya tape for marking and painting.
Please don't get me wrong, Mamoli kits are not bad, I just don't like the huge number of metal parts. That's the only reason why I'm not happy with those kits.
Edited by The Sailor
Cheers, Richard.
Current build: Mercury, Russian brigAmerica's Cup Yacht Endeavour (1934), Amati
Completed build: HM Schooner Pickle, JoTiKa
Next:
Beautifull Model Richard,
I like these classic lines so much that I decided many years ago to scratchbuild the Endeavor and make her raedy for RC control. So into the lowest keelportion was integrated appr. 3KG lead (non removeable)as deadweight. The model was very Long and although it was a lightweight hull contruction, Balsa diagonal stripes on ply Frames, and coated with glass rowing Cloth and sealed with epoxy Raison it was very heavy because of the lead. Halfway completed and with lateral-testing in water, I found it would take even more lead to compensate and withstand the windpressure on the high mast ans sail. The model was too heavy now to have fun in handling the whole Thing, so it went into the dark Basement and out of the mind. After moving homes for 2 or 3 times I decided to sell the hull, and so someone else may complete it or not.
As you are building a stand model, that sure should have been my decision as well in the beginning. Wish you very much pleasure in finalizing your wonderfull model, and shall follow your further build with pleasure
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Richard.
Looking great!
Do you think you could walk me through how you planked the keel?
If I understand your pictures correctly you started with the A-planks (see my picture). Why did you use 2x2 planks here?
Did you then do the B-part? Why did you use separate strips here instead of just letting the A-strips continue?
When you planked the rest of the keel, did you then start by doing the C-plank and continued with the D-part or vice verse?
Are you going to apply the same "methodology" for the second layer?
Cheers
Erik
Thank you very much for your kind comments, guys. :)
Nils, i can imagine it's not easy to scratch build a RC sailingboat. But I'm not familar with RC.
Hi Erik, thanks for your interest. Yes, I started with the A-planks because I followed the instruction. It's very much easier planking such an area with small stripes and the 2x2mm stripes are kit supplied. Next were the C-planks. For closing the gap I used the B-planks. At last I planked the rest by using the D-planks. Well, that was my method planking the keel but I think, there are some other ways to get the same result.
The second planking should be a lot easier because the vaneer stripes can be bend around the radius very well.
Cheers, Richard.
Next:
Thanks for your explanation Richard.
In the 1:80 kit there were no special A-planks, nor any instructions what so ever about how to plank the keel, hence my curiosity. Please keep the photos coming, especially close-ups!
The A-planks look very curved, did you use steam or anything like that to shape them or were they thin enough to bend just with some force?
How long are the 2nd planking strips? are they longer than the 1st layer. What pattern do you intend to use for the 2nd layer? and when will you plank the deck?
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Thanks Erik and Floyd. :)
Erik, the 2x2mm stripes are quite soft, so no soaking was required.
Floyd, the stripes for the second planking are slightly longer than the stripes I used for the first planking. I don't worry about the pattern because the hull will be painted later. That means, you don't see any planks after the hull is being painted. I will plank the deck when the hull planking is done, but before painting the hull.
Cheers, Richard.
Next:
What a gorgeous hull! I turned my laptop upside down to take a good look!
hamilton
Shes looking great Richard, the Hull looks Fantastic
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Thank you very much, guys. :)
Alfons, the area is to big for painting so I'll use my airbrush.
Well, time for a little update. Some more rows on and time for planking the keel.
Again I started with the bulb area covering using 3mm stripes
The rest was planked with the 5mm stripes
Cheers, Richard.
Next:
Richard - It doesn't look like you used any filler. Did you just sand the first layer and then lay on the 2nd? Also did you cover over the slot for the drop keel? And finally since you plan to paint her do you really need the 2nd layer of planking? Last question, can you offer some feedback on the difference between planking at 1:48 or 1:64 and 1:35. Is it easier to taper the planks?
By the way she look beautiful. You are tempting me very much.
Richard - Wow, I must say what a beautiful job.  Can't wait to see her when she's finished!  You should be very proud up to this point.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Thank you very much Floyd and Timothy. :)
Floyd,
I used some filler but not very much. Don't worry about the slot - it's still open. The reason of the second planking is I just want to paint her above the waterline and leaving the bottom covered with the mahogany planking. I know, it's nonsense because the Endeavour have a steel hull but it's an option of the kit. And it looks nice.
The scale makes no different in planking or tapering the planks.
Cheers, Richard.
Next:
Hi Richard:
Beautiful work! It seems to me that (unless my eyes are failing - which is always possible - the image on the box shows the hull finished as you describe, no? After such a beautiful planking job it'll be good to show it off a bit! And the mahogany presents a nice contrast with the painted hull above the waterline. Can't wait to see more
hamilton
Richard, really nice work. Impressed with how you manage to plank so tightly despite curvature.
Floyd, the 1:35 Endeavour is rated as 4 out of 5 by Amati (in difficulty). The 1:80 Amati Endeavour that I built is rated as 2 out of 5. I asked Cornwall boats about why the bigger one is so much more difficult to build but didn't get any answer that made any sense. Regarding difficulty of planking I'd actually expect the opposite, that it's slightly easier to plank a bigger model because the curvature is not that extreme in relation to the plank size.
Richard, did you find any particular section of the hull tricky to plank?
I agree, that is why I asked. The larger model should be easier to plank. I would also expect that larger scale planks would be easier to taper correctly.
Richard,
I'm fairly new to this forum and have just come across your fabulous build log - Endeavour is arguably one of the most beautiful yachts ever built and is most definitely a firm favourite of mine. I had the privilege of going aboard her sometime in the late '70's (before her purchase by Elizabeth Meyer and subsequent initial restoration) when she was owned by some friends of my father. Their dream had been to restore her but unfortunately money was the determining factor with progress. If memory serves, the hull plating and frames had been repaired but she was unballasted (other than temporary concrete) and even back then the lead was just too prohibitively expensive.
Having scratch built a J class plug in the past (to produce a GRP hull for fitting out with r/c) I am well aware how difficult these hull forms are to plank and you really have made a superb job of it so many congratulations!
As and when time permits I'll definitely be logging on to follow your progress - many thanks for sharing this build.
Regards,
Row
1:28 Scale J class yacht 'Enterprise' (R/C)
Build log currently at: http://www.rcsailing.net/forum1/showthread.php?6264-1-28-J-Class-Enterprise-build-log
