I have been asked to make a model of a specific yacht, the yacht is a recent build of a 1930s Sydney design. My previous build logs are both of designs by Cliff Gale, & somewhat inevitably, this is a Cliff Gale design also. Actually, I'm thrilled, & it is a version of his most famous design, or at least his best known design.
The yacht herself was built around 2000, & built strip-planked. The original yacht built to this design was called Ranger, & Cliff had her built for himself & his family. They are 24' (7.3m) long & 9'6" (2.9m) beam, so very beamy for a short boat. But they are excellent for their purpose: day sailing in Sydney Harbour, overnighting & near coastal sailing. This one has sailed as far as Tasmania, but with good preparation & picking the suitable weather windows.
Since 1933, when the original was launched, around 9 or 10 have been built, some not especially close to the original design. But there's one completed a couple of years ago & another nearing completion, being built by retired shipwright & general legend Ian Smith.
I'll let the photos do the talking, & if I think of more things to say I'll add them in following posts. I'll also try to find a couple more good photos of the yacht herself.
Launch day, or close to it, I think around 2002.
They are great day boats, & sail well with all that sail area. Quite a lot of usable room, for a small boat.
Happily, I have the original lines drawings from the build. That's something you don't see very often in this forum....1:1 lines drawings from the actual build. These yachts vary a bit, the original one - Ranger - was adjusted during her build, to increase her load carrying capacity. This yacht, built 65 odd years later, is actually closer to the original designed lines than the first yacht built to the design.
There's 3 main lines drawings, here's the first, taped to the dining room floor:
The second, sitting on that:
And the third:
The lines are to the outside of the ribs / inside of planking. Fortunately, there is this doodle on one corner, in the top left side of the 2nd lines drawing:
I have traced over these in a series of A1 tracing paper sheets, & they are getting scanned & I will assemble a digital compilation of the lines.
Thanks,
I’m looking forward to this Mark.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi Jim, Keith
This photo is a good one, a displacement hull trying to exceed her hull speed. I was out on the day, motoring our boat with my heavily pregnant wife & watching the start of a race. It was 5-10 knots 5 minutes before this photo was taken. Best reminder ever to always check the weather forecast. This is the boat I'm doing a model of, & the benefits of her higher ballast ratio are showing - the hull is lighter because in strip planking the hull is lighter as timber never soaks up any water, so the boat needs more lead to pull her down to the waterline.Image1.jpeg.ccbb7282c1c540334bd21b5dc4c1f035.jpeg
Below are the traced lines. The A1 sized tracings were scanned & loaded them into a draughting programme, then scaled & assembled. There doesn't seem to be enough lines though. The photo looks to show 11 frames plus tuck (transom - but it's called tuck on the drawings, so I'm following that, I believe it's what the older shipwrights in Sydney used), & the drawings shows 9 frames plus transom. I'll start by checking the lines drawings again, see if I missed anything.
20230413_Vanity.thumb.jpg.df457d9565a6bc432fcb991ebe26cb36.jpgIMG_7194.thumb.JPG.7536f1fbc837f7d4ffdc1143a884f249.JPG
Well I decided to have a look to see if anyone I know had another build going and I found this.
Having seen the last one in the flesh I know the owner ill be well pleased with your efforts. I'm tagging along.
I found the missing lines on one of the drawings, & will attach below the scans of my full size tracings, so 6x A1 sized sheets. Then my first go at the lines off them. I will next have a go at putting these lines with keel profiles, stem details, gunwale line, etc.
The double lines on the lower drawing is because the original drawings I had to work off were to the inside of planking. The double lines therefore are the inside & outside of the planking.
On 4/17/2023 at 1:13 PM, Mark Pearse said:
Hi Steve
Good to hear from you. Do you mean Marcus Cranney's Ranger build? Tweed River, I think is where he lives...
I was referring to the Ranger model you took into SASC
In my sailing days we used to call it "surfing". Very exciting in a short keel light displacement boat.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
  • 3 months later...
Hi everyone
It's been a while, but it's been quite difficult to pin down some of the details & shapes. The builders never recorded the keel profile or the shape of the stem. But she was on the hard last week & I took some measurements & I'm now close to the next step.
Just to recap, I'm going to cut an egg-cate style frame in plywood. My brother has a laser cutter so I can do them from 3mm plywood.
The shape is the boat is done, or nearly done:
I'll sort out spars etc later, for now it's just the hull. The pale blue shape in the drawing below is the lengthwise ply piece, which will also help support the stem. The drawing is assuming the stem is 10mm. You can see that mould #4 slides in from the top, the others slide in from the bottom. The ochre coloured lines are really reminders on how I will fabricate the cockpit area, using 2mm ply for that. The cockpit well is surprisingly steeply sloped, but the duckboard is packed up more at the stern end.
There will be some lateral strips inserted in the forwards sections, narrower at the bow & then a wider one.
Moulds half & 1 below. The red lines are not cut lines, they are burn lines to help an accurate setup:
Moulds 1.5, 2, 2.5, 3:
3.5, 4, 4.5, 5, 5.5 & transom:
There is a 28' version of the design, modified for ocean sailing, that just completed the Fastnet race. Below is the difficult conditions of the first day; the happy team approaching the rock. You can see the deeper keel & fuller shape in the first shot.
I nearly forgot about this one Mark. Glad to see some progress!
I'd heard Maluka did the Fastnet, he's keen shipping her all the way over there for a race!
Edited by Bedford
Thank you,
I should be able to cut next week, below are the cutting plans. There's something I need to check on the weekend.
Black lines are cuts & red are scored lines. The perimeter boxes are the bed size of the cutter. The glued up moulds should be quite rigid, but I think there's still going to be good reasons to build it on a frame, so I put legs on the moulds & more setout lines.
Good progress, I've cut the moulds & have started assembling them. It's always exciting when the model starts to go from 2D to 3D...
But first I have to make some comments that may assist others who choose to cut their own moulds from laser cut drawings they do themselves: the assembly was more difficult because when I worked out the shapes to have cut, I didn't include the building frame in my thinking. Assembling them was more complex then it needed to be. Anyway, it worked out ok.
I originally planned to screw the moulds to timber strips to hold them, but it's now quite obvious that if the moulds interlock in the way that these do, then screwing them together wasn't possible. So they were all glued to the main building frame beams with PVA.
The photo below includes a detail of the bow extension - the laser cutting bed was only 600mm long, so there were some extra pieces at the bow. This gave an opportunity to make the bow thick enough for the inner stem to land on & sit against. you can see how the front moulds include a cutout for the 8 x 8mm inner stem. You can also see the lateral pieces to give rigidity in the planking stage.
The inner stem will be glue laminated by the jigs I cut, also by laser. 3 thicknesses of 3mm plywood. The pale lines will help to position the final piece.
The transom piece has just been temporarily tacked on with hot-melt glue. The plywood is still loose, although I pinned it with dogs of hot-melt glue to stabilise it. In the next few days I'll glue them with epoxy glue.....once I've had a good long look at the frames to see if I need to tweak anything.
The uneven spacing of the moulds has a reason - the lines drawings I got were the actual moulds from the boat's build. The moulds were used to shape a series of glue laminated frames that were not evenly spaced. The hull was strip-planked (timber/epoxy composite construction) & there are only 10 or 11 frames (or ribs) instead of the 60 or 70 needed for traditional construction. So, because they were the only lines drawings I had to use that same spacing, which was to locate the frames in relation to hatches, mast etc.
thanks,
Great to see another one taking shape Mark.
michael
  • 2 months later...
Since my lost post I have been preparing for planking & adding a keel.
I have made the front inner part of the stem; put solid blocking between the moulds (mainly to give the keel something solid to be fixed to); some solid blocking around the propellor cutaway (the final shape is best made from solid timber, so again the blocking gives something good to fix to); plus some timber next to the transom, just so the glueing surface is greater.
I did some fairing of the moulds, it's not yet 100% completed but the lower parts of the hull, towards the gunwales, are pretty accurate now. The hull is a raised decker, so the topmost full length plank is from the top of the transom, which is lower than the main deck line. I decided to do this plank first then plank up & down from it. The process was influenced by the fact that it won't be traditionally planked, because this actual yacht was built strip planked (ie: wood epoxy composite). I've realised it does give more flexibility on planking. Anyway, the do the first plank without pinholes in it, I pinned a temporary plank on each side, but 2 planks distant....2 planks so that I didn't glue the pinned plank to the moulds. Subsequent planks can be clamped to the ones already installed.
You can see it below, the glued plank is not pinned. Spacers offset so they didn't glue to the hull.
First plank done, some slight imperfections, but within 0.5mm sanding depth. Planks are 2mm thick, replicating the actual strip planks of 25 x 50mm approx.
I used epoxy for these two planks. I hoping that I can use it for all the planking, including the edges (ie: plank/plank). I'm hoping that it will give a more monocoque hull so the planking lines won't be visible. Strip planks don't run in the natural way, so seeing the trace of them will be off-putting, & given the hull colour is black detail issues will probably be more visible.
all the best
Edited by Mark Pearse
Hey Mark, nice to see some progress.
What epoxy are you using and do you know the tricks of how to easily work with the stuff?
If not feel free to ask
Hi John, Steve
Thanks for the offer Steve, I have used quite a lot of epoxy. I built a small open gaff sailing boat some years ago (strip planked), helped my wife build a lovely plywood kayak, & myriad repairs on our boat Cherub. I'm using Araldite Super Strength for the model. Per ml it's expensive, but the tubes make it easy to proportion a serving, & the quantities will be small. Also, it is far tougher than it used to be. I have tried West System, Bote Cote, Norglass, Epiglue, Aradite & the SS Aradite is almost the equal of Epiglue. The 5-minute is good for some uses, but that doesn't include planking this model.
For a model, I would only consider an epoxy that was pre-mixed with fibres, that is a 1:1 ratio, & available in a convenient form in small quantities - other ratios wouldn't be practical for the quantities we typically mix. So that cuts out most of the above, & I'm not a fan of Norglass epoxy. Lastly, it is widely available.
Previous models I mainly used PVA, especially Titebond.
Do you use epoxy for models?
I use PVA and a little C.A. where applicable unless it's going to get wet in which case I use epoxy. Used WEST on the first RC one I did and it's a nightmare, the stuff goes off while you're mixing it!
I now swear by Bote Cote. No nasty chemicals and no hardening anxiety, it gives plenty of work time to get a good job.
That's what we used for the kayak, it came with the kit (kayak was a Chesapeake Light Craft LT17). It went well. Do you use this on any models or just on your lovely small boat?
Good to find I haven't missed much during my absence. I'm looking forward to seeing her develop.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
  • 2 months later...
The model has been progressing, but the planking is pretty slow, but it is getting there. The simpler nature of a 'strip plank' style hull does reduce the technical difficulties a lot, but balanced by the relatively narrow planks. And the previous planked model was using Huan Pine, which is very supple, this is Basswood / Limewood & it's much stiffer.
The lovely lines are appearing, although it's not so visible in the model yet - the scallops from the gunwale line around the cockpit hasn't been cut yet .... & it's probably normal anyway.
This one shows the technique: bulldog clip clamps to hold the planks to the moulds & rubber bands to assist pull the planks down to the previous plank. The gunwale scallop at the stern is marked approximately in pencil & will be cut after the model is fully planked & removed from the building frame.
I'm starting to use the heat gun to put some pre-twist into the planks.
03.thumb.jpeg.cf6566a12d95de9956fd41ce2cab1e73.jpeg05.thumb.jpeg.ed5329bd07f658855f5dcb19e8b0d11c.jpeg
The epoxy is messy, but all will be forgotten once the sanding starts, but for now another few weeks of a plank or two per day.
thanks
All looking very neat Mark. I like the idea of the rubber bands pulling the planks together.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
