Spartacus by Javelin - 1/2000
7 hours ago, Javelin said:
Unfortunately it's not possible to make a recognizable scale-penguin in 1/2000.
@Keith Black tried to get me to do that at 1/500 on my Aurora build, but I could not pull it off!  1/2000??  Whoa!
Link to comment
Share on other sites
Now, now Glen, do I hear a challenge there? 1/500 is definitely doable 😁
In any case, time to continue on this one as I want it finished by next week.
I started with the acrylic sea on top of the epoxy. Normally I'd add some acrylic paint with the gel, but I don't want to lose too much light to the bottom and since the epoxy is already colored, I just went for regular gel.
First was to determine something of a swell. Considering the scale, I need to keep it low. I mixed the acrylic gel with some water, as the heavy medium is otherwise very difficult to handle. I made some raised edges that would be the tops of the swell, they'll help to hold the rest of the gel in the next phase.
Once those "lines" were dry, I started filling the area in between with pure gel. At first I made strokes in the opposite direction from the assumed wind, to fill up the "shadow" zone of the swell. Afterwards, I reversed. Due to the raised edges, the shadow zone stayed nicely filled while the top of the next wave could be raised a bit. Once that was done, I made small raised ridges representing the wind waves.
Due to the thin layer of acrylic, you can already see that the starting point was drying quite well by the time I reached the other side. I also made a slightly different pattern in the lee of the vessel and floating line.
And by this afternoon it was nearly fully dry
Still some opaque areas that are drying, but the general idea is there. The streaks are a bit too deep, but I can live with it for now. I only need to add the neuring buoy near the anchor of the floating line and perhaps some "dirt" on the floating line as well.
In the meanwhile I've also made the rescue boat and lifeboats. I will still try to add some windows to break the even orange. They'll be a nice contrast on the ship as well. I've been adding some masts as well. We'll see how far I'll go with the detailing, but after the cutter platform and crane, I think I'll consider it finished.
Link to comment
From @Keith Black on my Aurora log - "As close as I can figure......According to Mr Google, Antarctic penguins are 24 to 30 inches in height.  A foot at 1:500 scale is .024 inches, correct? That would make 30 inches = to .060 inches."   I wave the white flag on that one!!
Regardless of penguins or no penguins, your water effects turned out really nice!  Well done, Javelin!
Link to comment
 He who thinks they be cowards all, raise your right hand.
Link to comment
Hmm.... emperor penguins can be a tall as 5 feet so double the size of a "normal" one.   But they'd still be tiny on the model.  I'll go stand in the corner now and penance for that.
Link to comment
Well Mark those were exactly the ones I had in mind. I'm sure Glen can build them in 1/500, but I'm just starting to think he doesn't like penguins... Pretty sure if you asked him to model longhorns in that scale, he'd do it! Wait a second, didn't he have longhorns in one of his projects??? :dancetl6:
I noticed it's been a while since the last update.
I'm actually at a stage where I consider the build complete. I've installed the lifeboats and fast rescue boat as well some masts (left off some detailing as it would be overscale and clutter the build), and eventually the yellow buoy that marks the anchor position of the floating line, and which holds the line that they use to retrieve and move such anchors.
Here is a close-up of the lifeboat. I first made the davits, with their boarding platform attached, then attached the lifeboat to the platform and eventually used the davits to anchor the thing onto the vessel.
For the rescue boat I used a more conventional approach and I first built the cradle with davit, and then mounted the boat inside of it.
Here is a top view of the result. You can make out the small yellow buoy on the edge of the diorama near the floating line. The acrylic gel still allows you to see the side wires from the top, but the thinner anchor handling wires have become nearly invisible due to the distortion.
This whole diorama measures 14cm x 14cm (around 5.5 inch x 5.5 inch).
I just need to make a case for it, as I really don't want to dust this off too many times...
Time for the Chaconia tanker to take center stage again in my workshop. Although I have some bottle-projects in mind, I don't think I'll do any side projects as I'm likely to get caught up in those by curiosity with the likely result of me abandoning the big ship again...
Link to comment
Yes, for my Archimedes' claw project.  Actually, historians were undecided on whether Archimedes used longhorns or penguins to pull the ropes on the mechanism.  I ended up going with longhorns.
Really impressive work all around, Javelin!  The main ship, the multicat, the water, everything!!  Well done.
Link to comment
The rare Sicilian longhorini hornusmaximus. 😁
Ken
Started: MS Bounty Longboat,
Link to comment
Amazing miniature model. Fantastic work.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Thanks for the comments and likes.
This one is running to an end.
Although it started as a bottle build, which, in retrospect would probably have ended in complete failure, it is still a project for my son. I therefore needed to make something solid as a base and protect it, you know what boys rooms can be like...
I'm not necessarily happy with this base, but I kind of took what I had available, taking into account that it needed to be sturdy and heavy, capable of taking a hit of I-don't-know-what-he-can-throw-around without immediately flying off the shelf.
It's not the first case I made of the transparent Vivak plate, but it will be the last one... I probably don't have the right tools to handle this, but all in all it's a very tough material to work with. Cutting is extremely hard, scouring it with a blade, pressing it and snapping it over an edge certainly results in cracks and it's difficult to glue (only MEK seems to work). In the end it will serve its purpose of keeping dust away on top of some shelf. It's also not a top model, as I'm still heavily annoyed by the air bubbles.
I was also thinking of making a small cutterhead model to place in a corner outside the casing, but I'll first see if he would want that or not.
Additionally you can see the base of the dio was bent. I'm still not sure what caused it, I'm pretty sure it was still straight after the application of the sand-acrylic mixture, but I'm not sure whether it was still flat after application of the pure acrylic gel over the sand. Could also have been caused by the epoxy I guess.
Another lesson learned, take a sturdier base (for example a glass bottle) if you want to use epoxy.
That said, I've painted the edges ochre and will put panels outside the casing, following the contour of the diorama inside and then work up to those plates with acrylic-sand mixture to make it look like the bottom continues outside the casing. This will then also hide the bent base plate. While I'm at it, I might also drop some of that sand over the black sides of that base plate, again following a curved pattern, but I don't consider that strictly necessary.  SP96.jpg.8b671f84db107b2508bc306722a6bf91.jpg
It'll also get a nameplate, still considering making it flat on the base, following the curves, or screw in a flat, sturdier name plate, some distance off, just touching the curved forward side of the dio.
Here you have a better view of the neuring buoy of the floating line. Unfortunately one of the air/gas bubbles attached itself to the line, completely screwing up the effect 😭 You also see the bent base plate.
Link to comment
I like your choice of base, Javelin.  Very unique and the colors work well with the build.
Link to comment
From where I sit, it looks great and your son will hopefully be very happy with it.
Link to comment
Javelin, this is a neat little model and I'm sure your son will treasure it forever. Happy Holidays.
Link to comment
  • 2 months later...
On 6/5/2023 at 12:44 AM, Javelin said:
That depends. Preferably a floating pipeline is used, this ranges from a few 100m till several miles. Occasionally, when distances get long and traffic needs to pass, the floating line is connected ho a sinker line on the bottom, so traffic can pass over it. You do still need a floating line to give flexibility to the dredger. The pipeline is connected to a swiveling connection on the stern of the vessel.
In cases where this not possible, the dredger can either load barges using 1 or 2 barge loading pipes, T shaped on PS on Spartacus, or pump it in trailing suction hopper dredgers using the stern connection and a pontoon.
On Spartacus, the pipes are 1.2m diameter and she can pump between 14 and 19km depending on material density and pipeline diameter.
I still need to build the barge loading towers, I'll have to hinge the inwards to pass the bottle neck.
Hi, is it possible for you to share images of barge loading T-shape pipes on Spartacus, I am working on a similar project and it would be of great reference
Link to comment
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
