HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
On 10/25/2024 at 6:15 AM, Dr PR said:
Mustafa,
Isn't it interesting how we get started on seemingly endless processes, like making all those angled spar deck beams, tying endless knots for ratlines or rigging all the lines to cannons, and when it is finished we are so happy when it is finally done!
It's like beating your head against the wall, because it is so nice when it stops!
You are so right, Phil. I actually experience that happiness at the end of every working day. Sitting in front of the model for a while and watching what I did makes me so happy every day. That is the best part of this hobby.
Edited by mtbediz
I have started planking the spar deck bulwark and adding the pin racks and other detail. I drilled 0,6 mm diameter holes into the planks to represent the bolts and was happy with the result.
For the bolts, I didn't feel the need to struggle for a more realistic look at this scale.
Edited by mtbediz
It's a nice optical illusion. I used the same method for the bolts on those big wooden cleats on the spar deck.
2 hours ago, mtbediz said:
I started planking the spar deck bulwark and adding the pin racks and other detail. I drilled 0,6 mm diameter holes into the planks to represent the bolts and was happy with the result.
I was wondering if you were going to bother with those rivets. Frankly I think you've stumbled on a more elegant and nicer looking solution. More detail than I'm prepared to go through, but as usual, you've added the Masters touch.
Kudos.
11 minutes ago, Der Alte Rentner said:
Frankly I think you've stumbled on a more elegant and nicer looking solution... ...as usual, you've added the Masters touch.
Another example of how I continue to learn from all three of you!  Can't wait to start on my Constitution after seeing your collective works... 👍🏆
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
Friends, thank you for your nice feedback. I use this method often in deck planking of my models. It's a bit of a lazy job, but it's an effective method. In this case, I drilled all the planks which are going to be laid in the same space by stacking them on top of each other, which ensured regularity.
By the way, Jon's bolts are much more realistic. Even if I could find the material he used, I'm not sure if I would have the patience to make it. :)
Below is an example for the deck. I did this on my Alert model.
Edited by mtbediz
Yes, I agree, my method of making the pseudo bolts was tedious, but I feel in some ways easier than other methods I've seen including the Mr. Hunt's in his practicum. Making and applying the "bolts" was just a matter of punching out tiny "rivets heads" out of thin copper plate. The tedious part was applying a couple of thousands of them to the model. My method was to make a bunch "rivets" then apply them with Wipe-on Poly. That gave to time to position them where they needed to go. You get into a rhythm and it gets done. The illusion method works too, but you can't make mistakes, because once the holes are dilled, you hide them, but you can't remove them. Either method takes time.
Jon
Outstanding, Mustafa!  Your work continues to impress.
Gregg
On 11/10/2024 at 12:40 AM, Javelin said:
Very impressive! Both the ship, and primarily, your skills!
I totally agree!! Your sharing of your progress and process is invaluable to those of us just learning how to do these models with integrity. Thanks
Somehow, your photos make your model seem so much larger than scale.  Perhaps it's the realism that you've achieved making me think I'm seeing a full sized construction.  I'm in total agreement with those who've chimed in above.  Excellent, beautiful and impressive workmanship.
Thank you so much Peter. As I mentioned before, my model is actually 1:70 scale, so it is slightly larger than yours. The reason is that I could not fully match the scale of the kit plan. But I'm glad it happened, it gave me some relief while working. :)
Edited by mtbediz
Friends who follow will remember. The distance between the spar deck aft windows and the gun deck aft windows was not in accordance with the plans (was my mistake). For this reason, when the spar deck construction was completed, these window sills remained under the spar deck. By adding to the sills of these windows, I raised these windows to the spar deck level. That's why the moldings had to be redone as well.
https://ussconstitutionmuseum.org/discover-learn/modeler-resources/
Edited by mtbediz
If you are willing to wait a week, I would tell you the exact US Navy plan for the catheads. I am visiting my sister for the Thanksgiving holiday and am not able to access my computer. I am using hers to communicate.
Jon
5 hours ago, mtbediz said:
I started making the catheads.
Having read Gregg's comment on my build log, and then seeing that you're just making the catheads, I'm asking myself:
Self, where did you put the catheads you made oh so many months ago?
As always, it's a pleasure watching the master at his craft.
Jon
Thanks Jon. Yes I can wait for the plans.
