I was using my chopper to cut 56-11mm x 4mm x 4mm Ramen strips.  I didn't realize after cutting the first 8 pieces that my guide was moving slightly so now I have about 20 pieces of varying lengths.  The lesson learned is don't try to cut 4mm x 4mm pieces of wood with the chopper.
I've learned to cut things a little long and sand down to final length when using a chopper, especially when they are on the thicker side. That said, yea 4mm wood is a little thick at least for my DIY chopper.
regardless how I cut my pieces, I always cut them a bit long and then sneak up on them with the table top disk sander to get the finished length
Alan O'Neill
7 hours ago, bigcreekdad said:
I threw my chopper away years ago. Couldn't get a straight vertical cut out of it. Wish there was something else to get perfectly straight vertical cuts.
You could look at this tool. I have one and it works very well.
https://www.micromark.com/Miter-Rite
Cheers
Richard
Current builds:
Completed builds:
SBLim-2A, MiG 15 variant, WAK card
Harpy by Vanguard
AL's Endeavour,  Corel's BellonaAmati's Xebec,  Billing's Roar Ege, Panart's Armed Launch
Ships' Boats - Vanguard 1:64 and Master Korabel 1:72
 Alexander Arbuthnot,  Christiaan Brunings,  Pevenseall by World of Paperships, card
HMS Pegasus by Victory
Captain John Smith's Shallop by Pavel Nitikin
Rumpler "Taube" 1911 by HMV, card
Cheers
Or this one that I have works great, but it's limited on size and flexibility for angles:
https://www.micromark.com/Extra-Long-Micro-Miter-Box
Rick
Current Build: MS Mayflower II
Completed: MS USF EssexMS USS Constitution Cross SectionMS 18th Century Armed Longboat
17 hours ago, bigcreekdad said:
Thanks Richard....looks pretty sturdy.
I fastened mine to a board, then fashioned a moveable stop from aluminium (aluminum 😁) angle so that I could cut multiple pieces all the same length.
Cheers
Richard
Current builds:
Completed builds:
Harpy by Vanguard
It all depends on the 'chopper' you have. When I was a student, during vacations I worked in a DIY store and one of my tasks was to cut picture frames to order. The foot-operated 'chopper' would cut mitre notches for frames as much as 50 mm thick ...
Edited by wefalck
  Having a very sharp steel blade is key.  I'm talking about 'razor sharp', which really needs a sharpening jig to get the right angle on the water stones used ... and also a final 2 degree finer bevel at the very edge - then stropped.  The process starts with being sure the back face is truly FLAT.
I have an original version of the Dobson   J never found a way to get satisfactory work out of it.
The whole unit wants to move and rock when the blade is being used.  After your comment, I can see that it being fixed to a large enough base solves that problem. It does greatly increase the real estate occupied by the device though.
The blade is inside a sleeve and held vertical by two plastic screws - and I have not been successful in finding the sweet spot between a wobble and too much friction for the blade to slide easily.  The grab helps cause the sliding and rocking.
The stock wants to  move back and forth with the blade.  The brass wires for a hold down are too flimsy.
It requires four hands.   If fixed to a base, it is then down to three hands.
I am not sure that razor saws models that allow for just the steel blade to be replaced are thin enough to fit the sleeve.  This important because I have come to prefer a cut being on the pull stroke instead of the push stroke.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
... but this thing is just a miniaturised mitre-saw, not a 'chopper', i.e. there is a saw-blade with teeth.
From an engineering perspective, this thing is not a terribly intelligent design, as it lacks a proper adjustable guidance for the saw-blade. If anything, there should be a gib-strip to control the clearance with which the saw moves.
I am a little late with this info, but I think bigcreekdad’s issue of straight vertical cuts may be solved with a single bevel blade.  See my review of the Ultimation Slicer.  It isn’t inexpensive, so some modelers will stay away.  If you can justify the price it is very well made.
I have seen YouTube videos of people using it on material that looks to be about 4 mm thick, but I don’t think go any bigger though.
Aon’s solution works also.
Hi Jaager,
The screws are now metal, but it is fiddly trying to get that sweet spot. I had no trouble with stock moving around, but I was only ever cutting small sectioned wood. It's not perfect, but it worked for me.
Cheers
Richard
Current builds:
Completed builds:
Harpy by Vanguard
