HMS Victory by AntonyUK - FINISHED - Scale 1:36 - cross-section
Hello shipmates.
Thanks for the replys. :)
I will do a update tomorow after I have taken a few more photos of the progress over the Christmas and new year.
Thanks for looking in.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Link to comment
Share on other sites
Hello Shipmates.
A long due update on progress.
Have completed the pumps.
Photos from many different angles.
Have spent some time looking at the cannons and how too produce 16 of them.
The cannon barrels..  I decided to cast my own using black resin.
A silicon mould was made first using the master.
First part (not yet finished.)
Second cast.
note the vents . had air bubbles in so carved vents in to release air bubble.
Cast with the master/Plug.
Carriages are made. I used 2 types of timber for this as they will look pretty.
The large piece in the middle is the jig that will hold all the parts together while drying.
Should hold then at the correct angles.
This will be my next job assembling the carriages.
Regards Antony.
Edited by AntonyUK
Completed Mayflower
Link to comment
How did you get your master?
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Link to comment
Hi shipmates.
Floyd.
The plug or original is Acetel bar turned using a lathe to get the correct profile.
The trunnions hole is then drilled and a brass rod inserted.
Paddy.
The cannon barrels are cast using black resin.
I made a two part mould out of silicon and added the vents after by cutting a small "V" in the mould.
Found lots of examples on Utube :)
I have been experimenting with the excess resin on casting very small bits. Turns out to be very easy.
Regards Antony.
Completed Mayflower
Link to comment
Antony,
Thanks very much for the reply. Those cannon are going to look top drawer mounted on those smart looking carriages. All Cracker Jack components.
Edited by Paddy
1st Year Apprentice :mellow:
A new member of the NRG as of 8/28/13
Work in Progress -
 Triton 28 Gun Frigate Cross Section
Link to comment
Super nice pump and guns, Antony.
Link to comment
Hello Shipmates.
Another update for you.
My first attempt at a companion way.
Starting the deck fittings.
Opps.. the dam companionway slipped..
Tables and benches ready to go.
Another on of the benches.
Cannon carriages and tools made up.
cannon carriages close up.
Home made rope is a little stiff for my liking.
More deck fittings
Middle deck taking shape.
Another view of middle deck.
Carving wood for the entrances. Core timber is Lime with 2 types of veneer laminated on top. Pear being the top one.
Image put onto carving surface. Used Acetone on paper printed with a laser printer.
Found out that the surface timber has to be really smooth to do this.
This is my sixth attempt at carving this piece of door...
That’s about it for now.
Regards Antony.
Completed Mayflower
Link to comment
Hi Nigel.
It was cast in while making the mould.
Thinking after seeing someone else's cannons I am seriously considering casting then in pewter.
I have found buttons on with the cypher GvR and crown. Only 10 mm across. Might remake my master with the cypher in and other small details added.
Regards Antony.
Completed Mayflower
Link to comment
Hi Nigel.
I have used this for my resin casting RTV Silicone rubber with a shore hardness of A40.
Have ordered some pewter from EBay .
I will have a go at casting them next week if everything goes to plan.
Regards Antony.
Completed Mayflower
Link to comment
Hi Nigel.
Yes I am aware that some will not withstand pewter. But the type I have is ok for 20 to 30 casting before mould starts to degrade.
I chose this one because it's a harder silicon rubber and more stable.
Regards Antony.
Completed Mayflower
Link to comment
Hi Isalbert.
Had a look at your build and in preticular the entrance's. Very nicely done.
A little more detail on how you acheaved this would be very helpfull.
Regards Antony.
Completed Mayflower
Link to comment
Hi Islabert.
Que dois je faire pour finaliser si j'ai bien compris votre phrase?
Isalbert
Translated into english -: What should I do to finalize if I understand your sentence?
I not sure how you did the carvings . More detail please.
Regards Antony.
Edited by AntonyUK
Completed Mayflower
Link to comment
Hi.
This time its a question on the opening mechanism for the gun ports.
Drawing attached is what I think it is..
Can anyone confirm or show me the correct Method.
The photo below comes from :- http://modelshipworld.com/index.php?/topic/985-amati-and-chris-watton/page-3
Thanks in advance.
regards Antony.
Completed Mayflower
Link to comment
Hi Rob.
Thanks for the photo links.
Yes I think I have it right.
I will make up the tackle today.
Regards Antony.
Completed Mayflower
Link to comment
Hi Antony.
 Good job on the midsection sir and will be watching how you lay out all the equipment  for the cannons. Will give me some ideals for Alfred. On a different note , can any one tell me what that odd looking stove is in the second picture please? It looks like a up to date smoker and have not run across this untill now and was wondering if it was around in their time.
Gary.
Link to comment
Hello all.
Not a update today but response to Gary's question below.
Hi Antony.
Gary.
It's a portable forge used by the ships armourer. According to Haynes workshop manual of the Victory.
It's got a hand operated bellows on the underside.
Have decided against casting the guns in pewter. Will continue using the black resin casting.
Will post a update over the weekend.
Regards Antony.
Completed Mayflower
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
