8 hours ago, iMustBeCrazy said:
Greg, do you have any evidence of a rudder? I can see what may be a rudder in the middle of the rear foil in the early version and perhaps aft of the hull in the later.
If I'm right about the early version the entire foil must rotate to turn.
I don't think the wheel was used for steering at least in the early version, I think the lever on the right was. It's too big for a throttle lever and a lever was how he steered his aircraft.
I think the speed was controlled by 'blipping' the engine with a kill switch on top of the lever, this would be consistent with aircraft through WW1.
I believe that there is a small rudder in the middle of the rear foil. The first picture you have in your post had made me believe so, as well as pictures taken in SD's workshop where the rear hydrofoil is propped up in a way to keep the rudder from touching the ground. But perhaps most convincingly is the film showing the hydroplane being placed in the water at 54:15 in this video:
Also notice that as the hydroplane is carried their doesn't appear to be rotational motion of the rear foil structure. This footage, together with the bracing geometry is what has prevented me from thinking the rear hydrofoil moved as a unit for steering. If the hydrofoil rotated the bracing wires (fore and aft) would need to change length - first and third drawings below. The other issue I can't rectify is that the lever on right - which based on Craig's wonderful enhancement - always is pictured at the same angle and has just one wire / cable leaving it (to the front). If the lever was to be used for steering, it could be pushed forward to pull back on the cable and steer to one side; however, there doesn't appear to be a mechanism to turn in the opposite direction. I did consider the possibility of a spring / bungie return, but again this goes against the bracing geometry questions I have.
Craig's last picture, in some ways, increases the mystery - here it appears that the rudder post is rectangular and this makes me infer that the rudder could not turn independent of the hydrofoil.
Santos-Dumont was known for his simple / purpose only designs. It seems strange to me that our collective analysis of a potential steering mechanism is not providing an obvious and clear understanding.
Right now, I wonder about the possibility that there was not a steering mechanism at this point - simply a point and shoot set-up. Maybe it was only used when the hydroplane was towed and/or short test runs. Perhaps, the structure in behind SD in the later modified version of the hydroplane is a rudder box that made the boat steerable.
3 hours ago, druxey said:
This may sound bizarre, but in the first photo it appears that the seat and wheel, as well as the foil/rudder, is rotated. Was steering literally by the 'seat of the pants'?
Maybe it was worse that 'seat of the pants' and was not steering at all!
I do really appreciate the additional input / discussion!
Greg
 In the last photo of post #178 that Craig posted, the steering wheel tube appears to be just mounted to the seat board with no internal linksge out the forward end through the body to the rear or an external link for that matter. IMHO, the wheel was nothing more that something to hang on to
Current Builds:  1870's Sternwheeler, Lula
Completed: 1880s Floating Steam Donkey Pile Driver
As I see it at the moment:
The rear bracing convinces me that the foil does not rotate, therefore the 'rudder' is just a fin.
The wheel is, in this version, non functional. Perhaps steering was done by leaning, that could work.
I still think the lever is massive for a throttle but at this stage I can conceive no other plausible function.
The video shows that the front foil is inadequate, probably the rear foil is too big and pops up first changing the angle on the front foil and preventing it from lifting leading to the changes aft.
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
 There is a thumb button on top of the lever.....starter button? Also, the steering wheel did turn because of the different wheel positions in the array of photos which is curious if all it's meant for is to hold onto?
15 minutes ago, Keith Black said:
starter button?
Possibly, but realistically a bit early. I suspect it was to cut the spark to the engine, a kill switch, or probably a dead man switch, if he lets go (or falls off) the engine stops.
Craig.
How they got the engine started is a great question - I have not seen a picture where the engine is running / propeller is spinning. I have seen a picture of how the SD 14bis was started:
Can't imagine getting something like this out on the water and stabilized enough to crank it. Also don't see how anyone would be willing to stand in front of this beast and turn the prop by hand - just imagine the problem of not getting trapped between the pontoon and a nacelle and all of the bracing wires! A quick Google search indicates that electric starters were not used (commonly) on planes until after WWI, and that Charles Kettering received the first US pattern for an electric car engine starter in 1911 - the starting being used on Cadillacs starting in 1912. So the chances of an electronic starter on this engine / hydroplane seems unlikely.
All very fascinating and enjoyable.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Ugh, just a bit frustrated today; now at trial some number much > 3 to make a radiator (2 are needed)!
This one has vertical cooling fins made from 1/16" x 1/64" brass strip. It is reasonably rigid, but there is a bit more space between each than I would really like. I count 15 cooling fins in each radiator on the actual craft - this has only 6. I might be able to get the fins a little closer, but not by too much more. A couple of days ago, one of my many failed attempts was made by binding 15 strips of 0.3mm C. Boxwood (left over from making the hoops) together with thread. In this way I had the correct number of fins together with the very fine space between each; however, the structure was incredibly flexible and would not hold its shape well. Also, I wasn't able to paint it a satisfactory color.
Maybe one (?) more try to get the fins closer and maybe make the radiator just a little wider. Best case may be 10 brass fins - we'll soon see.
I would probably try the brass as both the fins and spacers.
Building in a jig is probably easiest, clean all the brass first, tack the first piece in place with tiny spots of glue, glue the spacers to the next piece then glue that to the previous piece, rinse and repeat.
Slide a knife blade between the first piece and the jig to release.
Blacken the whole thing then fit end caps.
Yes, I drew it with the spacers glued to the previous piece, I think the other would be easier.
EDIT, I really need to post faster.
Edited by iMustBeCrazy
Craig.
Here is what 9 fins look like as compared with 6. I think this will do!
Still a bit of solder clean-up on the top two sets of joints. I have some smaller dimensioned brass square tube on order for the top and bottom caps. I had used 1/8" on the 6 fin attempt. It looks like I might be able to get 2mm square tubing which would give a nicer fit.
Currently there are small brass strips soldered on the backside to hold the fins, but your glue and spacer idea would most likely yield a nice result - one that might get the fins even closer together than my slotted jig can achieve!
Sorry about posting so often tonight, but this subassembly has just been getting to me and I the venting is helping!
That's never a problem, sometimes the venting helps the thought processes.
Doing anything Santos-Dumont can be painful. With the Demoiselle there are so many variations and copies with their own variations it's really hard to tell what's going on. (there, my own little vent ;) )
Craig.
 I wonder how those radiators would have affected the aerodynamics? I think the nine fin arrangement looks great, Greg.
Edited by Keith Black
Craig -
Are building one? I would love to see that!
Greg
Maybe. I have to move in the next few months so I'm not starting anything non digital.
If/when I do it would probably be in 1:8 to match Camel and SE5a kits I have.
Craig.
Greg, I hadn't noticed this before:
Anything look familiar?
Craig.
That's a real nice look at the radiators!
He first used these radiators on the No 15 airplane:
Santos-Dumont-on-board-aeroplane-No.-15-Saint-Cyr-March-1907.jpg.b913b97628dc28a19fe9449061734449.jpg
I don't know what was used on the dirigible No 16 for cooling, nor on the No 17 airplane (which had the V16 and the three bladed propeller that made it to the No 18 Hydroplane).
I don't think I noticed the radiators on the No 19 before, the belt drive always catches my attention!
Greg
5 minutes ago, Greg Davis said:
on the No 19 before
This was the first version of the '20' with the V8 between his legs (well almost) I think I'm doing the last version of the '20' with the water cooled twin (which I'm just starting drawing, luckily there's a patent with drawings).
He re-used everything. It makes it really hard to work out if a photo is earlier or later.
Craig.
32 minutes ago, Greg Davis said:
Which one is the Popular Mechanics plans?
That's a very good question, somewhere in the 20's.
Craig.
Those look super, Greg.
16 hours ago, Greg Davis said:
First propeller mock-up. This has some resemblance to the real one, but I think I'll probably need one or two more tries to really hit the shape. I think the blades need to be lengthened just a little bit ...
Greg, I think you're pretty close. My estimation is that the shaft should come out to about the cylinder heads and that the blades are two and a bit (two and a half?) longer.
The diameter is most probably a nice round metric number. Actually most of the measurements would be.
Craig.
6 hours ago, TBlack said:
Greg, Just looking at the photo of the propeller at your entry #200, it looks like the shaft is as long as the paddle. Interesting design, but I guess it worked.
Tom
I found similar results when I made measurements on a number of photos.
Tom - I think the shaft is proportionally longer on the 2-bladed propeller that is mounted to the No15 airplane, than on the 3-bladed used on No18 (and17). I agree that it looks much like 1:1
Craig - Generally, I'm getting close to a 2:1 ratio for the 3-bladed prop. Although it looked similar to a 3:2 ratio in at least one picture. I have a reference that claimed the prop diameter was 2.1 meters (~7 feet) and the first mock-up matched that figure, but it looks a bit too small to me.
This is another try, with a larger diameter- closer to 2.5 meters (~8 feet) - and with a prop to shaft ratio approximately a 2:1. This one looks a bit to big to me!
I've wondered about the prop diameter dimension; it was accompanied with length and width measurements of 10 meters and 6 meters, respectively. These three numbers were published in a document prepared for a Santos-Dumont exhibition - I don't have a primary reference for the propeller diameter. The same length and width were reported in an article published in Scientific American. (On the other hand, in one Scientific American article the nacelle length was reported as 1 meter which is clearly not true.) Also, the length (10m) and width (6m) are the nice round numbers one expects from Santos-Dumont. But 2.1 meters seems not to match! I can't seem to rectify the choice. I considered the possibility that the blade and shaft were each 1 meter and the .1 meter reflected a measurement associated with the spinner. But 10 cm (~4") is too big for the radius of the cone - diameter perhaps.
So the decision will be between the semi-documented 13cm diameter (2.1 meter) or a larger 14cm diameter (2.25m), but certainly not 15.6cm diameter (2.5m). Going to need to sleep on this one -
It would have been much easier to figure out measurements and shapes if the people taking the pictures in 1907 had squared up with the hydroplane - what were these photographers thinking?!
Ok, I've averaged 4 photos:
They come out as:
2.1:1
2.0:1
2.0:1
2.1:1
So I'm guessing 2:1.
These photos are not to scale so don't read anything else in the numbers.
Greg, note the clearance between the prop and the hull in the last shot when considering the diameter.
Craig.
