Nice progress Christian.
On the subject of the Qtr deck Capstan, it actually sat on a platform called the step. This rose around 1.5mm (at scale) above the Qtr deck. The step was angled  slightly to bring the capstan vertical to the spindle running between the two capstans.
The expediency of  bevelling the base of the capstan achieves the same effect, but does it look ok from a side on view?
Regards,
B.E.
Thanks for the info and showing interest. B.E.
Well, it is hardly noticeable. The moreover I've painted the edge of the captstans base in flat black color ( kind of a camouflage ).
From stern  to bow view the capstan is isolated between stairs and gratings and from port to starboard and the other way around...well ratlines and shrouds and probably other rigging will cover this issue completely.
I've painted the capstain axe also in black as I was anxious to avoid the red flashy color overall this item.
A calculated risk ?
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
Hello master shipwright.  Your model looks amazing.  I can see a big difference already from stock, unless I am mistaken.  The side windows to the aft compartment look like real windows on your model, whereas the stock windows simply look like a glued on plate. You have fabricated a molding that gives it a "real" appearance.   As an introduction, I long ago I built the Mamoli Constitution, the Corel Wasa, and the HMS Swift (not the current Mamoli kit.  It was purchased in 1989 and I don't recall the manufacturer).  I came out of retirement, and plan to build my fleet (I have 15 planned so far....what can I say, I obsess....don't we all?).  I just purchased the Pegasus kit and learned that the cannons, long boat and rigging blocks should be replaced for authentic scale considerations.  I am not, perhaps, as picky as some and may not replace the blocks (unless they really look bad), but the cannon choice seems to be an egregious error.  The most I can figure is 1/64 cannon for a Swan class ship should be either .3 or .32, both of which I can get.  But is there a recommended item? And what about the cannon carriages?  Do they come prefabricated? If so, they will have to be replaced as well.  If I must build them, I can probably work with the parts that come with the model and reduce their size a bit.  The long boat I hear is a metal shell. I would like to make a planked boat but am not up to the challenge of a scratch build.  I haven't been able to find a scale replacement.  I would prefer making the longboat from a kit if possible-to scale, of course.
So, the simple question is what cannons should I get to replace the stock ones?  That I can easily do.  The long boat might be possible if I can find a scale kit.  The item that bothers me the most, the non-functional look of the aft compartment windows, is probably beyond me.  But we shall see.
Thanks for listening and I apologize if this is not the correct place to pose such questions.  They are specific to this kit, however, so I figured it would be the best place.
Rodd
Thanks for your high praise, Rod.
This is certainly the correct place to ask your question, you are very welcome
Although imho the real shipwrigts are more likely to be found in the scratch-build section, I'm afraid.
Also built Corel Vasa, so we have this in common.
The gun carriages are not prefabricated,  they are an assemblyprocess of different parts ( see pic below, you can still distinguish the different parts ). I understand that this problem of prefabricated carriages might occur with (early ? ) versions of the HMS Fly Amati kit. Unfortunately, this is also the case with my next project ( Sciabecco Amati 1/60 )
You are quite right to question the size ( and perhaps also the quality )of the guns. I haven't figured out yet how to tackle this issue.
The concern of the guns ( wether or not with carriages) and longboat....., well if there's no problem of availability, I can only tell you : go for it !  ( e.g. Vanguard Models,... ).
Certainly the metal longboat is indeed asking for alternatives, or at least different approaches.
However, I used the photoetched windowframes  supplied by the kit. Only the grey paper I fixed behind the plastic provided the effect I was seeking for.
Hope this helps.
I not, feel free to ask further questions
Kind regards
Christian
Another item you may want to replace is the tiller. It's quite visible and fragile. There's eyebolts to be attached, which is a risky business.
I'not that enthousiastic about the kit's version : it's rather flat. Besides, research demonstrated this item was way bigger.
This attempt was made of a 4mm. ramin dowel .
However, and accordingly to internet research,  I flattened the "knot" at the end a bit.
If availability is no concern, you may want to use ramin dowels instead of walnut.
I intend to use ramin dowels also for the masts as it requires no yellow painting. Just my personal taste.
How to connect this part with the rudder ?  I'll figure something out....
Oh yes,...the swivel guns provided in the kit..... But that's for later
Kind regards
Christian
The rudder : almost there.....
But also I must admit an avoidable error.
As I had the "coppering process"  still in mind, I thought  it would make sense to fix the irons in the rudder area later on.
But  at present I could have simplified things if I took hold of this previously to the white painting under the waterline.
While using masking tape overdye the irons in black grey this would have prevented some trouble, especially when cyanoglue is involved.
It took me a while to obtain a result by  whereby I can settle although the rudder is still dry  fit
Also a few pics from previous builds about the matter.
Kind regards
Christian
  • 2 months later...
Chainplates and channels ( post 1/2 )
It's been a while, but I must admit I struggled a bit regarding this stage and came,to the conclusion to copy paste the approach of my previous build ( HMS Diana ). Thus I replaced the deadeye chainplate with blackened ironthread and part n° 174 with Gütterman thread. Regarding this latter part, I was not very fond of the gap.
The thread : had to make sure the knots were tightened enough to compensate the tension exercised by the shrouds .
Secondly, the knots are hardly visible : under the channel and behind the loop of my deadeye chainplate alternative.
Another issue I encountered : while proceeding, the paint of the chainplates was peeling off regardless my efforts to use a proper primer coat. Nothing we cannot fix, so no harm done.
The edges on the channels were covered by a 1 x 2 mm walnut strip, later on I fixed a small strip of black paper just for aesthetical reasons.
The last pic shows the port side that still needs to be done. You may notice I went for a different chimney upon the forecastle.
Kind regards
Christian
At last : chainplates & channels done on both sides.
At present and not provided by the kit an addition to the gallion. I admit it's a simplified version but I'm working with 1.5 mm plywood. Thus I can't take any chances.
Although, I have no clue regarding the purpose of this item.
Kind regards
Christian
Et voilà.
next update : next of the deck stuff especially swivel guns.
This might take a while, I'm not very enthousiatic about what the kit provides regarding the matter.
Kind regards
Christian
Hi Folks,
Regarding the swivel guns, I think we may have a breakthrough.
1) The guns : purchased them in the aftermarket, I believe the brand is Mantua
2) The handle : I made it eassy on myself. Open an eyelet ( gently ) put the loop around the cascable and gently close and fix the loop. Bend 90°.
On the tail I glued a sort of a "mini-donut". The latter is available in handcraft-hobby stores.
3) The fitting : as I'm not going to install the hammocks, I used the PE parts for this purpose.
4) Wooden support : made out of 4x4mm birch. Not the ideal material but imho better than walnut. The availability of e.g. boxwood in the neighourhood is a bit questionable. Accordingly to instructions drill a 1mm hole in a 3x3mm walnut piece....as this particular piece has a slot in that area....well, good luck with that.
Some extra sanding and painting will do the job.
After some research, I noticed other , probably better solutions but often they involved soldering, etc...I was not into that.
Not the ideal, but I can live with it.
Any thoughts on this are welcome.
Kind regards
Christian
Upper rail, Quarter deck ( starboard side )
As a deviated a bit from building instructions as well as the supplied parts, quite happy with the result after all.
A previous build, San Felipe ( few decades ago ) was a source of inspiration for the extra decoration strip.
Next post will be realted to the port side and I'll get more into details ( kind a step by step )
Kind regards
Christian
Referring to my previuos post, first of all a sincere word of gratitude towards the kind and very encouraging words and immensly interesting builds on this forum ( finished and ongoing ) which are for me a true source of inspiration.
Concerning the color scheme for HMS Pegasus, compared with  HMS Fly , I always preferred HMS Fly as I came across a few examples of red, black and white (beneath the waterline ) during my research.
Let's overlook a few items.
Lamp.
I'm fond of the gaffsail arrangement without the boom ( e.g. see Blue Ensign's log ). If not, the lamp would clearly obstruct with the boom. The moreover, I intend to place a flagpole.
The lamp itself was purchased through the aftermarket ( Caldercraft, If my memory serves me well ) and was part of a kit of 3 lamps ( the biggest embellished the stern of my Diana )
Paint : AV 70.877 Gold Brown.
Rudderhead housing
For the same reason, thus the flagpole, I had to customize this part a bit. Concerning the rigging part, I sticked to the building instructions but for the sake of visibility, I omitted the 3mm blocks under the ship's wheel.
The Breastwork
Quite delicate assembling it was ( says Yoda🙂) and the extremities did not fit properly upon the stanchions ( Pegasus builders part n° 13 is the subject ) so I had to be creative to solve this by adding a small part of wood in the shape of a half moon.  Neither did I use the stanchions provided in the kit, instead I went for spare stanchions which were more to my taste.
( to be continued )
Kind regards
Christian
Continuation
Bulwark open rail.
I went for another approach as I felt insecure about the alignment of the swivel gun supports that contained a slot in which the rail initially belonged. A vertical misalignment would obviously put myself into trouble so I went the opposite way and did not use the original rails ( parts 81)  and creatd my own swivel gun supports and rails. The latter received a small slot.
Color swivel gun supports : also AV 70.877.
The curve at the end of the rail was made out of several layers of thick paper of light card ( if you like )
Another point : I had to bend the rail in a self made jig ( after warming and soaking ).
Added some extra pics, hope they tell ore than words.
The pumps, the supports adjecent to the gratings  (parts 177 )  were a bit to tiny for my taste so I glued a small piece of wood .
So what is to come ?
The swivel guns = there's a plan A, B and C
Plan A : the aftermarket guns in combination with  the hammock cranes ( see pic )
Plan B : using the ones provided in HMS Speedy
Plan C : use the ones provided in the kit
....haven't figured this out yet...
The masts
Definitely use ramin dowels as I'm not very enthousiastic painting these items in any yellow color
Kind regards
Christian
Started with the masts
I did not use the provided walnut dowels and went for ramin.
I prefer the natural color especially after a varnish coat. A matter of personal taste, I guess.
The bowsprit
As I want to avoid bulky and clumsy knots, it is recommendable to consult other buildlogs.
5 blocks at the top of the bowsprit jibboom? A bit crowdy....thus I copy/pasted ( more or less ) the BE and Moonbug approach. By luck I've found a spare triple block and fored a 0,8 mm hole where I inserted a piece of brass wire and created 2 loops on each side
The bowspritcap was another concern
I replaced piece n° 50 with a scratch built item
To compensate the angle of the bowsprit, I fored holes that described the same angle.
Kind regards
Christian
The wooldings.
You may notice the grey rings on each side of the wooldings. They're made out of paper that was bended twice around the ramin dowel.
The Fore and maintops
adding extra planking, be it 0,5 mm strips would make these parts way to thick so I tried something different.
made a sort of an imitation using a pencil ( code 3 of H ) upon the black painted surface. For the latter an airbrush is recommendable.
Kind regards
Christian
A question about the burton pendants.
A slice of this small plastic tube is perhaps an option, any thoughts on this ?
All feedback  is welcome
Kind regards
Christian
I assume you want to use this for the thimble.
I did do this for the pendants that the topgallant sheets ran through on my Alert build. You can shape them to work as a thimble, but they are not particularly strong and in the end were pretty fiddly. You also have to keep in mind that when you push your tool into each end to bend the sides outwards it stretches the whole thing and so you need to start from a tube smaller than the inner diameter of your thimble. If I had my time back I would just go get brass tube of and bend that outwards or get some 3d printed (they would be really easy to make a 3d model of in CAD).
Your model is looking great :)
Edited by Thukydides
Thukydides,
Thanks for the sound advice. I think I'll settle for the brass tube.
Nearby ( at least to Belgium standards 😉 ) 2 km, there is a Iarge DIY store. I'll take a look.
To simulate the weight, the idea is to fix them to a 0.5 mm brass wire and bend some Güterman thread around the brass wire. We'll see how this works....
Kind regards
Christian
Foring holes for the crowsfeet A (little ?) setback. 😒
Drilling holes (close to one another) into walnut : I had already an unpleasant feeling about it but proceeded anyway against better judgement.....
In a effort to avoid the inevitable I reinforced these items with a 0,5 strip but this did not work. (see last pic )
A possible explanation : increasing considerably the (rpm) speed with an appropriate drilling machine, which I don't have at my disposal
As I'm out of options, I'll stick to the approach related to my previuos build, drilling the holes just behind the edges as you may notice on the second pic in attachment.
Later on : filling up the homes with some  putty and paint.
Kind regards
Christian
I have also experienced this.
Drilling by hand sometimes gives problems and small drill bits break more easily.
I am really happy with the purchase of a Proxxon machine and the flexible drill head.
Always annoying when that happens Christian.  I've found that the quality of the drill bit also makes a pretty big difference. I've taken the plunge and purchased some Carbide drill bits. They're not cheap by any stretch, but they definitely make much, much smoother holes even by hand.
The company I used is called McMaster-Carr
The general rule for metal is 5000 divided by the diameter of the drill in mm.
Source: Mechanics lesson in the 2nd year of technical education... (in 1978) 😉
Wood may have a higher speed, but the 5000 rule is also quite ok in this case.
Nostalgia
Thanks for the info, Patrick.
Good news and following your advice : the HBM cobalt set and the Proxxon 110BF 28622 are on their way....
Bad news : along with this purchase, I could not resist the temptation of this amazing bird ....https://www.italeri.com/en/product/3145
Kind regards
Christian
Following Bakers and Moonbugs sound advice : here's the latest purchase.
A set of 150 quality drills ( diameters 0,4 till 3,2 mm ) and the Proxxon Flexishaft 110 BF.
A try out using some wooden leftovers ( same material frames from the kit ) is perhaps recommendable.
I'll keep you posted.
Thanks guys 👍
Kind regards
Christian
