I lost all of the day yesterday dealing with one tiny part and got very close to binning the whole thing. There is a support structure for the mast that sits towards the top of the tripod. There is a five part photo etch assembly or a plastic piece. I built up the PE item but utterly failed to get it into position. There was just not enough room between the tripod legs. During the struggles I damaged the PE railings on the tops deck and broke apart the tripod legs. I decided that the only way forward was to lower the position of the support to get more space between the legs. This meant making some cuts in the forward leg to receive the support. I did this and tried to assemble the support in its new place. As a final insult, during the last attempt of the evening the PE support pinged off the tweezers and disappeared. I spent an hour searching with no success and decided that the plastic part would be easier to modify anyway and it’s really not too bad looking but I was seriously considering giving up the whole build thinking it was just beyond my skill level. This morning I thought I would try one last time and curiously the first thing I saw when I sat down was a glint of brass and the PE support was sat on the cutting mat in plain view. I have no idea what dimension it spent the night in. However I had pretty much committed to the plastic bit so I filed it down to accept the pylon and placed it in the lower place and everything fell together. So, the build continues. The ships boats have been given the first coat of light gray and a few small pieces have been added to the forward structure, the damaged railings have also been repaired.
IMG_1852.thumb.jpeg.be6cb23f652c7789bbce6f450d305d9e.jpegIMG_1851.thumb.jpeg.84303f8c43dcf86135e814c87c9e4434.jpeg
Thanks for looking in and for the likes and comments
alan
It is hard to replicate metal and wood surfaces on plastic, but this looks really nice.
Respectfully
Thats an excellent recovery there Alan  - these kits at this scale are such a challenge  and a Bad language tester.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
Thank you very much OC, it’s great seeing the model come together but it is very challenging at times and the PE / base kit instructions take a lot of puzzling out. Getting there though.
alan
Moving forward again I’m in easier country. I’ve been painting and weathering the ships boats. I’ve lost a bit of the bottom boards wood color with the washes but there wasn’t a lot of contrast between the Tamiya light grey XF20 and the deck tan. The oil wash did improve the detail on the steam launches though.
The major achievement was assembling and installing the boat deck derricks without getting the PE cables damaged.
I’ve started on the deck detailing with the capstans and ventilators. I also assembled and added the two QF 3 inch guns. I didn’t plan on using the brass barrels but one of the plastic barrels was badly damaged so I had to try.
IMG_1860.thumb.jpeg.475ea74ec9dffc128f89d746fc135905.jpegIMG_1859.thumb.jpeg.3a7de1002c98d8f791a781a31035a66a.jpegIMG_1858.thumb.jpeg.99eca348034d6c75ca1e75ccbca5600e.jpeg
Amazingly there suddenly seems to be only minor parts to be added, mostly David’s and the remaining boats. Lots of PE railings still of course.
im trying to ignore the large elephant sat in the corner. There is a large multi yard mast to go on the top of the tripod and I am not looking forward to placing that.
Thanks for looking in, for the likes and kind comments.
alan
Excellent work Alan  - its all coming  together  now  - and  dont them boats  look  adorable  with all that fine detail.
OC.
Current builds
Completed works.
Looking good...
Personally, I find most folks overweather their decks.  My Graf Spee won't look like some dude stained each plank with whatever was in the closet at the time.  I think they would be a bit pickier.  I think your deck job is fantastic.
My Graf Spee will incorporate my first PE railing.  Looking at how they are installed via YouTube, I don't think it will be a horrid process.  Just measure twice, and install/glue stanchion by stanchion.  At least that's the plan!!!
Thank you very much. I think it’s very easy to over weather on 1/700 models and it’s easy to get the deck looking a little excessively scruffy. I’m moving away from the precut wood decks in favor of painting them. The painted deck looks good to me and avoids the issues of the deck lifting later or if the wood deck is not perfectly lined up it can cause problems adding the superstructure because it won’t sit down flat.
All that happens at a stage when things are getting delicate and recover is difficult. I’m still learning to get the railings to as good as I would like. I use MiG Ultra or Gators Grip PVA glues which gives time to fiddle with the positioning and is easy to excessive with water. I left it sit for a few minutes before installing it. That way there is a better initial grip. For long lengths I will get one end down and then work along. Sometimes it’s easier to cut into shorter pieces if the length is unwieldy.
Alan
Lots of small bits and fiddly PE Davies and winches added today. The sprue are starting to look a bit bare.
The breakwater has been added but needs the braces turning into position. It will be interesting to see how many survive the process. Luckily there are spares.
We now approach a ticklish element of the build, adding the boats to the davits. The kit davits have thick vertical sections on the davits which the boat is glued to. It looks a bit clumsy and the PE solution is to use a bar between the davits which has a number of suspension points for the boat. The tricky bit is deciding whether to add the PE to the boat first or to the davits.
Ive added the PE to the boat first or.
I’m thinking I may have to switch to CA glue to attach the assembly to the davits but I’m anticipating a fight. I may be digging out some more davits from the spares box but we’ll see how it goes.
Thanks for looking in and for the likes and helpful comments.
Alan
Looking excellent Alan.
OC.
Current builds
Completed works.
Well, I was right, it was a fight. I used Gators Grip PVA glues which to attach the falls to the boats and then ca glue to attach the assembly to the davits. It was still a hassle, the gold ca glue is quite slow setting so trying to hold everything in position while it cured was tricky. Of course a third hand would have allowed me to use accelerator for the glue. Anyway all but one boat is in place and (possibly) worth the effort. The last boat was a problem to place and I was getting too much glue building up so I used acetone to disassemble everything and try again. The acetone ruined the paintwork so I’m cleaning and repainting it all.
Meanwhile I will be adding some ventilators and repairing some of the hoists that got damaged during the boat work.
Thanks for looking in and for the likes and comments.
alan
This is amazing,  the fine detail on your 700:1 model is unbelievable
Slowhand,
Current build Apostle Felipe - OcCre
Polacca scratch build from Amati plan - on hold
San Martin - OcCre
HMS Resolution - Corel
Half Moon - Corel
Dragon keel boat - Billings
I’m moving along slowly. The forward railings are proving to be a bit of a challenge. The railing section is long and the shape is a complicated set of bends and curves.
I got the shape but mounting the railings was extremely difficult and took two days ( and walking away from it a number of times). I eventually got it started this morning and worked my way along to get the rest done.
 two sections working towards the stern were much simpler and faster but curiously the sections seem shorter than the guide would suggest. I just have the stern section to go and we will see what happens then.
IMG_1884.thumb.jpeg.3af4a606b53a24b76bcb3ee03c5adb41.jpegIMG_1886.thumb.jpeg.fe46f67eaaa9dcf4867aea639597dba6.jpeg
And look, we now have boarding ladder for the boats on davits.
IMG_1887.thumb.jpeg.497100ad9ce6e6459e03867821962488.jpegIMG_1882.thumb.jpeg.a28943a1942b66cebb4a19ff9badb41a.jpeg
I’ve realized that the railings are going run under the boat and I’m going to be interested to see if I can get them installed without damaging the boat. I haven’t added the boat on the starboard side after discovering that.
The pile of foam squares is my secret weapon for installing the boat falls and ladders. It makes a great hand rest next to the model for placing small bits without any uncertainty.
Ive also worked a black wash over the hull and superstructure to add some visual interest.
Thanks for looking in , the likes and kind comments.
alan
Alan, pe parts can be hassle to deal with.
But you are doing so much better than I.
Looking good!
Respectfully
That is a good feeling. I love it when I am discarding empty sprues or laser cut wooden plates, devoid of any parts. It means two things: 1) You are making great progress and 2) It is time to think about your next project.
Yves
Yves
I’m definitely counting down the number of PE railings left😁
Alan
I swallowed my pride and cut the forward port railing section into shorter pieces and things went rather better. I was able to sneak the railings under the boat and davits without damaging anything and with a reasonably low swear count.
I completed the full run of the starboard railings and inserted a small section into the gap from a (possibly) spare piece in the fret. It is a numbered piece but it’s not referenced anywhere and I don’t see any more places to add railings. Possibly I will regret this later.
To celebrate a fairly positive day I added the boat to the starboard davits and quit while I was ahead.
Four sections of railings remain and I need to think about the mast and upper structure.
Thanks for looking in and the likes and comments.
Alan
That's an incredible amount of very fine detail in your model Alan.  You're doing a really great job!
I've tried Gator's Grip glue, and for me, it's fine for some things but others where you need a quicker set time, I just seem to get along better with CA.  I typically use medium CA (thin i find too runny and uncontrollable) applied with a pin, and if I need a quick set, I'll use an accelerator that comes in a pump bottle as opposed to the aerosol can.  I just unscrew the top, dip the head of a toothpick to get a small drop of the accelerant at the tip, and then touch the glued pieces.  Of course all this sounds a lot easier than it is in actual practice.  I used to really hate using CA, but we've come to an understanding and I've gotten a little better with it.  But there are just times that are so frustrating when the glue doesn't seem to want to hold the parts, or on the flip side, will grab immediately before I've had a chance to finalize the position (or somehow immediately glue my fingers).  Some of these guys on YouTube seem to have no problems at all but maybe they have similar moments at times which end up on the cutting room floor and aren't included in the final video.
Oh, and don't get me started on railings.  They are my nemesis!!  I'm not sure I've totally figured out a way to do them, but pre-bending is definitely a helpful step.  On my first 1/700 I tried using Gator's Grip but I think the cure time was just too long and I couldn't get it to work.  So now after pre-bending - even for slight curves in the hull - I add a little CA in the first section, then slowly work my way down and add CA down the line.  Even then, I'll sometimes get gaps, portions of the railings will pop off, etc. and it ends up taking me much longer than one would expect to finish them.  Now that you reminded me about Gator's Grip, what I might try is to start a section of railing with CA to get a firm anchor point, then use Gator's Grip for the rest since it probably has a little more flex to it and won't pop off as easily as can happen with CA.
Edited by Landlubber Mike
15 hours ago, Landlubber Mike said:
'Ive tried Gator's Grip glue, and for me, it's fine for some things but others where you need a quicker set time, I just seem to get along better with CA
Thank you very much Mike. I think railings are one of the best upgrades to a ship kit and really set the finished model off well but they can be a miserable experience especially when there are complicated shapes.
i try to avoid CA glue, I seem to have become sensitive to the stuff and get cold like symptoms after using it. I now use Bob Smith Gold CA which is a medium thickness low odor glue and is not super fast setting. Gators Grip and MiG Ultra give me a bit more flexibility when placing the railings. I apply the glue with an pin and then give it a few minutes to tack up and then place the part. It usually has enough grip to hold then. I’ll work by placing one part of the section and let it set up before positioning the next part. I find it easier to get the railings to follow curves that way. I definitely like the fact that the PVA type glues have a bit of a flexible bond and parts doing break away from accidental contact. Some days seem to go well and others are a fight.
Alan
Alan, I have also tried out the Bob Smith Gold medium, and find it easier to use than regular medium CA.
Respectfully
Thanks for the tip on Bob Smith Gold medium.  I’ll try it out.  So far I’ve been fine, but might as well take more precautions.
As a side hobby, I turn pens and when using wood blanks, I like applying a CA finish.  When sanded and polished, the CA turns into an ultra durable glass-like finish which is really spectacular looking for woods like burls and spalts.  The process involves having the blank spin on the lathe, add a drop or two of CA onto a small piece of paper towel, and then quickly run the paper towel across the blank while it’s spinning.  I’ll add anywhere from 10-20 coats like that, so the fumes get very intense.  I usually run my shop vac near the lathe to pull in most of the fumes while also wearing a respirator.  Otherwise, I could definitely feel the effects from the fumes.  Nasty stuff!
Thanks Per, I find it has a bit of time for adjustment and so far Ive had no adverse effects using it.
alan
