Very nice planking job Sir.
Do you use small pieces of carton to prevent the nails marring the wood when holding the planks down (picture Amarante646.jpg)?
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
thank you, friends, for your appreciation!
@Remco: yes, it's just like you said: in this way, I have the necessary space, after having removed the small cardboard,  to cut off the head of the nail
@uss frolick: for my work I'm using pear wood for carpentry and planking, ebony wood for everything that is black and boxwood for the moldings. Probably I will use maple wood for the planking of the bridge but I'm not sure yet....!  :)
  • 4 months later...
Very nice metal work, Giampieroricci.
I tried an idea to remedy the problem of nailing garlands that does not conform to the drawings of the monograph, which some friends I have pointed out:
Then I had a strange idea that in the end I think it has given the desired results:
I tried to build the pins with washer using brass wire of 0.6 mm and thin brass sheet from which I got the tiny washers
Found your log this morning. Really wonderful. I'll follow your log with great interest
Regards Christian
grande Giampiero
ti trovo anche qua, che bello  :D  :D  :D
lavoro stupendo da certosino
big Giampiero
I find you even here, how nice
wonderful job cobbler
Giorgio
Edited by rekon54
If a day will be reproached you that your job has not been done with professionalism, you answer that the ark of Noè has been built by dilettantes and the Titanic by professionals. ;)
