1 hour ago, BANYAN said:
Nope, not yet; you could make it look like one for me ;):)  I am sure the Admiral won't mind too much ;)
cheers
Pat
We could put up an 80ft main mast in your garden    but I bet your admiral would end up using the spars for washing.:D:D
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
11 minutes ago, NMBROOK said:
Great work OC and a very clean sharp paintjob
Kind Regards
Nigel
Thank you  sincerley.:cheers:
OC.
Current builds
Completed works.
Evening everyone!    I decided to have a go at the transom,  I had another look at the kit molded metal affair - and decided to have a go at tarting it up a bit,     I started by filing off the top detailing - this took some time gentle filing till it was smooth.
I then decided to paint the transom corresponding colors to the hull - French Blue, Light Yellow Ocre and Red and Black details,  I finished it off by painting the edge Black.
Here are a couple of pics.
OC.
Current builds
Completed works.
This was how the transom looked before I attacked it with a file and some paint.
OC.
Current builds
Completed works.
OC.
Hi their OC,
Build coming along very nice.
Transom, you made it look pretty dam good considering it is metal.
Dave R
Measure twice, cut once.
Current Build: HMB Sirius 1786 - Flagship of the First Fleet to Australia (Scratch Build in the Shipyard)
Finished Build: HMB Endeavour 1768
18 minutes ago, DaveRow said:
Hi their OC,
Thanks dave,   it was  trial and error  I thought "go with it"  as the unicorn and lion do not look to bad, so just clearing the top engraving did seem to make a fair amount of difference, just needs a couple of coats of semi satin top coat to take some of the shine from the blue, and blend it all together(sam will be on the hull)
OC.
Current builds
Completed works.
nice job OC  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
5 minutes ago, popeye the sailor said:
nice job OC  :)
Thanks mate:)
OC.
Current builds
Completed works.
1 hour ago, Oliver24 said:
Nicely done! I am looking forward for more :)
Many thanks.:)
OC.
Current builds
Completed works.
More progress today, I decided to attack the metal bits from my peregrine kit as there was some quite good bits, I started by attaching a rope design on the top of the transom, next I found some figures that are fixed between the edge of the transom and the rear  quarter window, these where attached with a general purpose glue(carefuly)  then touched up with some brass paint.
Here are the pics.
OC.
Current builds
Completed works.
Just a follow up folks - next step with the transom will be to paint the back (thats planked) in the middle top - red ocre and either side (outside overhanging the hull behind the brass figures) black, then when dry I will give all the paintwork (except the brasswork) a couple of semi flat top coats to calm the sheen down a bit (the french blue has come out as a semi gloss),  I will apply some gloss top coat to the inside window frames /glass though.
OC.
Current builds
Completed works.
Evening all,   After painting the back of the transom dull black, I decided to attach it to the hull - nothing much to say about that just I used some general purpose glue for it.
OC.
Current builds
Completed works.
Evening all,  right next stage was a bit of a punt as I wanted to construct the rear quarter windows, but to be honest I didn't want to build them from scratch, I went searching through all my stuff to look for the kit parts, but alas I could only find the one side - so Into my other box of lovely bits (corel HMS Peregrine) and I found the two rear quarter window assemblies,  these are more flat in profile but have some quite nice decoration around them.
First thing I had to do was construct the window pain frames - luckly I had these small wood fittings, so after a little sanding to make them fit, They were dropped into the cast fittings, and after I added a couple of coats of dull black.
I then decided to give the windows a false glass look using some painted (shiny blue) card, this was painted first then cut to fit the shape inside the rear recess,  then placed and glued in.
Here is the result -  with one of the pics just showing a dry fit.
Also shows the size of it compared to my fingeres its 1/100 scale.
OC.
Edited by Old Collingwood
extra info
Current builds
Completed works.
I managed to fix the one side in place, first I had to mark the shape showing where I needed to cut out the raised hull details, then with a sharp knife I removed these and when it was all flat and after a few dry runs  - I glued it in place.
There is a small amount of touch-up to do, then I will attack the other side.
No picture as the one above basically illustrates what I have done.
OC.
Current builds
Completed works.
31 minutes ago, BANYAN said:
Turned out great OC.  She is looking good indeed.
cheers
Pat
Thank you pat,     she is startting take some shape and develop an identity.
OC.
Current builds
Completed works.
OC i love the way she painted up, you have done a remarkable job on her, it was enjoyable to catch up on your build log
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thank you so much kevin  its great having you come along for the journey, its only taken me 3 years and probably another 3, wait till I get to the rigging :o:o.
I was on my other build "After - in between this"  build   HMS Warspite in 350 scale, but I have had a break on that one due to the tiny parts playing my hand condition up, I was getting locked fingers from holding the PE parts, and going cockeyed,  so I decided to have a bash on me frigate instead.
She is a bit of a mish-mash to be honest kind of a captains interpretation of how his 20 gun sixth rate should look.
Keep up the great work with your County Class as you know it is a very special part of my childhood, going over Devonshire at Pompy Navy Days.
All the best  OC.:cheers:
Current builds
Completed works.
look'in really nice OC..........your doing a great job!  ;)    hands are still OK......no problems?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Sorry for delay in replying, I foregot to check my own thread:huh:
Hand is not to bad I have good and bad days  depends if I am using my left hand much - holding stuff thats when it starts to play up and my fingers lock,  however on good days it gives me less trouble.
Im doing some gentle light work at the moment - building the bits and fitting them through the forecastle deck down into the front of the gundeck.
Not really any pics as I am waiting to progress a little further.
OC.
Current builds
Completed works.
Ok everyone I give in here are some pics  - the bits show the glue waiting to dry.
Oh  foregot to mention - the captains cabin facia was made up form oddments I had, then put together and painted.
OC.
extra added
Current builds
Completed works.
Evening everyone,   after fitting my forecastle bits  I came across an "upss moment"  - I had the bits to close to the edge of the forecastle deck, not leaving much room for the ships bell/frame, so I decided to re fit it on the other side of the mast, and instead fitted two single bit frames without the cross piece.
I then turned my attention to the rear poop deck - this has a ladder running up from the quarter deck, up through the poop deck,  I had to cut this out with my sharp knife then a little sanding, next I constructed a frame for the opening and glued the four pieces in place, it will need filing to make the edges square and smooth.
Here are a few pics.
OC.
Current builds
Completed works.
nice job OC........decks look great!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks mate.
OC.
Current builds
Completed works.
35 minutes ago, BANYAN said:
Looking good OC; great progress despite the oops moment :)
cheers
Pat
Thanks pat,  I kind of noticed it after I had fitted it and thought "damn silly thing to do"  It dd fall appart whe I moved it, but luckily it just needed re gluimg when the posts were positioned.
OC.
spilling mastakes buy may.
Current builds
Completed works.
I was kinda wondering what was stuck under the fore deck.   looked like it didn't belong there.   glad you got things sorted out  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
well recovered OC
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
