Happy New Year ALL :cheers:
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
  • 2 years later...
:piratebo5:One day I will have to get round to carrying on with this build, I have her sat on the shelf, and all the parts to finnish her in the box,  I was put off a bit by the plank bending errors and snapping - splintering planks, from just normal boiled water heating method(left in a tall glass with boiling water)
OC.:dancetl6:
Current builds
Completed works.
Hello again folks  I decided to give my Warsite a little rest and do some more work on my wood build,  first off I had to dust her down as I have not done anything to her for many years,  all was still intact so I got my bits together and decided to continue with the deck planking.
I first finished off the edge planks that are a slightly darker shade than what I was using before, but that wont matter to much,  after a bit of measuring they were fitted both sides and held in place while the PA set.   I also decided to carry on with the planking.
So sofar I have done another length of planking and the edge planks.
Well its a start and different medium from my warspite build.
Here is a few pictures folks  including one that shows the rear cabin bulkhead not fitted just dry fitted.
OC.
Current builds
Completed works.
7 minutes ago, Robin Lous said:
Nice OC. And don't forget to take it easy. :)
Thanks mate,   I thought working on wood planks would be easier than PE parts at silly scale,  kind of  theraputeic and give my hands a bit of a rest, while still doing something.
OC.
Current builds
Completed works.
Hi folks,  I had a good day on the build today - spent most of the afternoon continuing with the deck planking,  this involved some quite intricate cuts and shaping,  I think it has gone quite well just a few small gaps that should fill when I do some sanding to bring it all nice and level.
OC.
Current builds
Completed works.
Nice to see you picking this up again Collingwood! She's looking very fine indeed
hamilton
hamilton
Thank you so much for the compliment and having a look over my build,  its been a while since we last spoke,   any ideas how I can fill a few of the gaps yet still retain the caulking look.
OC.
Current builds
Completed works.
On 09/11/2013 at 6:30 AM, mtaylor said:
Looks like you're off to a great start.  Hope you don't mind if I pull up a chair and watch? post-76-0-03652800-1383978618.gif
I should have commented way back then mark  - but yes its my pleasure  having you follow my work   back then and still now.:cheers:
OC.
Current builds
Completed works.
Right folks a bit more work on the deck today,  above I asked about filling any gaps between the deck boards,    well I tried the idea of diluted PVA and wood dust, first I sanded down a couple of scrap deck strips onto rough sand paper, and collected the dust in a cup, then I mixed some PVA with a little water to make a milk thikness, then I used a small paintbrush and brushed into the gaps (one at a time)  the pva then with the same brush I dipped it into the dust and rubbed it into the gaps.
I did this into each gap then re applied to make sure the gaps were filled, I then put the hull aside to dry till tomorrow.
Next will be to sand the deck again and check that the gaps have filled.
OC.
Current builds
Completed works.
More work on the main deck today, I decided against ageing the planks - instead I just sanded them to blend them together, then after blowing of any dust, I mixed up some flat top coat  diluted about 40% and applied a few coats.
I think this is ok for the deck.
OC.
Current builds
Completed works.
Evening all,  next on my building plan is the centre deck area including - gratings, boarded area and stair frames,  after observing some internet plans and drawings I decided on my work plan.
I started off by constructing the gratings next after they had dried I started work on the outer frame around the gratings.
This is the state of them so far including a small repair done to one of them.
OC.
Current builds
Completed works.
More progress folks still working on the center deck area, I continued with the main frame around the grating/ladder section, this was sanded down to make it less deep and even thickness over all, I did the same thing with the other grating, when the sanding was done I decided to fit some boards to represent an area for more accsess down to the lower decks.
I have also started work buiding another block decked area, that has been glued and secured together.
Here's the photos -
OC.
Edited by Old Collingwood
Current builds
Completed works.
More work constructing the frames for the center area, this is time consuming as I have to measure and cut lengths of timber, then I glue them and leave them to dry jiged up in a make shift device, here are four sections from completed to work in process.
OC.
Current builds
Completed works.
More gratings/ boards and step frames put in place - starting to look a little better I think.
OC.
Current builds
Completed works.
Hi folks,    I got round to doing somemore work on the center section with the gratings etc,  I managed to finish them  with the exception of the three ladders that I will need to construct myself out of stock wood.
She is starting to look like a frigate bit by bit.
OC.
Current builds
Completed works.
Indeed...indeed. :)
Looks lovely and so nice you found your mojo again.
WIP: No ships atm...sorry!🙄
Completed: Greek bireme - Dusek - scale 1:72
 Louie da fly: "I think it requires a special kind of insanity to choose a galley to build a model of."
42 minutes ago, Robin Lous said:
Indeed...indeed. :)
Thank you so much for your kind reply,     my next move  will be to scratch build three ladders, to fit down to the lower deck through the frames I constructed, to be honest she is going to need a lot of scratch building  as I lost a lot of the fittings including  - gun barrels/carriages,  bitts,  belay pins,  bollards, capstan, cathead, deadeys's,  figurehead,  helm wheel   etc.
OC.
Current builds
Completed works.
More work folks today continuing on the main deck area by fitting the two bulwark lower board supports, these will be painted Red Ochre when I get some more.
This completed my inner deck work till I get or build the ladders,  I then decided to work on marking out and drilling through for the oar ports on the  side still left to be done, I followed the drilling up with a small sqare box file - the exact diameter of the oar ports, carefully filing till they were all correct.
Next is the hull planking following from my last work - as I write I have a piece of hull timber in soak with boiling water, I intend to leave it there till tomorrow, before I attempt to fit it.
OC.
Current builds
Completed works.
33 minutes ago, Bill Morrison said:
Collingwood,
That is excellent deck planking!  I love what you are doing with this kit!
Bill
Thank you so much Bill:)
OC.
Current builds
Completed works.
Hiya folks,  I started work on the lower hull planking from the wale location - downwards, I recovered the plank that was sitting a  tub of water since yersterday, I also got hold of some pins,   so after placing a layer of pva I placed the plank and worked my way along pressing the pins underneath to hold the plank in place.
I will have to do one plank a day due to time drying and affect on my hands.
Here is just the one picture of the current status.
OC.
Current builds
Completed works.
Not much to say really  just another row - this time second planking,  soaked it  then glued and pinned,  now put a side to dry.
OC.
Current builds
Completed works.
After the last strip was set,  I began sanding it back level with the other second planking,  it then occured to me that I would need to mark a line and cut into the last planking, this is to allow for the profile of the wale,  this was done by measuring the line from  bow to stern from the top of the bulwark rails down to the already  fitted wale on the other side, then after marking a line I placed a plank against the line and used my sharp blade to cut a line all the way along, then I cut the sections out.
After a clean up the line looked ok so I started cutting and fitting the first narrow section of wale, in sections as I did not have a full length  just off cuts,  these were glued and pinned in position.
Here are the pics folks -
OC.
Current builds
Completed works.
I couldn't resist  doing some more work at the bench(living room table)  I have decided to increase the apparent width of the wale by painting a strip ontop of the (Insatlled  wale side),     first I ran a line and then taped an even line with blue decorators tape, then I applied a few flat black coats of acrylic paint, this I will do on the side where I am constructing the wale sections also.
OC.
Current builds
Completed works.
34 minutes ago, cog said:
Nice build, I especially like the wooly underneath ;)
Thats the wifes department knitting from days past.
OC.
Current builds
Completed works.
I've not seen this build.   though your missing a few pictures,  I can see the good work your putting into her  ;)    very nice progress so far!......love the colors!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you for your kind words and all the masses of likes  my friend.
OC.
Current builds
Completed works.
