looks really nice OC.......are you gonna go black on the wales again?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Yep   Black on the wale then dull white on the hull below that,  also the stem will be half black and white with a demarcation line level with the wale, and the lower transom will be white level with the lower hull,  and either red ocre or french blue where the head of the rudder enter's the hull.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Just more painting folks - I masked off the wale top and bottom and added a couple of coats of dull black.
OC.
Current builds
Completed works.
2 minutes ago, BANYAN said:
Looking good OC
cheers
Pat
Thanks pat.
OC.
Current builds
Completed works.
1 hour ago, rafine said:
Very, very nice OC.
Bob
Thank you so much bob.
OC.
Current builds
Completed works.
wale watching at it's best  ;)    looks much better !
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi folks,    I have painted the lower hull on the one side flat white,   I have put a couple of coats on her but she needs a little bit of very light sanding and a few more coats, then a little bit of re touch up of the wale.
I wont put any pics up yet till she looks a little more tidy.
OC.
Current builds
Completed works.
Managed to put about 5 coats on the hull  it hasn't come up to bad.
OC.
Current builds
Completed works.
Question folks  - does my wale look a little to narrow?
OC.
Current builds
Completed works.
After doing a laptop change and transfering over all my files and 1000s of photos files,  I am done now and all  eyes to see folks postings.
OC.
Current builds
Completed works.
OC.
Depends if you like a skinny or a fat wale ...
I would keep it the way it is ...
Carl
Thanks carl,  I just thought it looked a little narrow  not thickness wise but width.
OC.
Current builds
Completed works.
one word OC.........no ;)    awesome paint work........now she looks seaworthy  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks mate:cheers:
OC.
Current builds
Completed works.
Evening folks,  I have spent a good couple of days finishing off the hull paintwork - I painted the other lower hull side, then applied the white/black lower transom relief area, and also did some tidy-up work on the wale,  last I applied the top black on the stem.
So appart from a few tiny adjustments and working on the hull/top bulkhead rails and some decoration, the hull is nearly comlete (on the outside).
Oh - and the rudder and the stem frame work/figurehead/ anchor howser framework,  etc etc.
OC.
Current builds
Completed works.
I agree with Zappto, great work on the painting!
11 minutes ago, zappto said:
Very clean work on the hull, contrast colors makes it shine!
Thank you so much.
OC.
Current builds
Completed works.
Thank you don.
OC.
Current builds
Completed works.
21 minutes ago, Shipyard sid said:
Greetings OC.
              Just found you.   Excellent work, the comments say it all. Just keep enjoying it. Regards.   DAVID
Hi there david,  thank you for looking in,   you should pull up a chair now you are here, lots more to do yet,   hope you are well  regards to glen also.
OC.
Current builds
Completed works.
Looking sharp OC, you can come over and paint my place anytime you like :)
cheers
Pat
cheers
Pat
What  - do you live in a 18th century period ship then?;)
OC.
Current builds
Completed works.
look'in better and better OC  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Fine work on the painting after a fine work on the planking the hull...
IMO although painting the ship makes her accurate, nice and more attractive, it is a bit sad because it closes the all wood workmanship. A contradiction?
But knowing what is under the paint layers is a consolation, a respect to the memory of all that labor on the wood.
And you and us know that... :)
Best Regards…
Ferit KUTLU
Under construction: Frigate Berlin (Brandenburg Navy)
Hope: Frigate Wappen Von Hamburg (Brandenburg Navy)
Thank you my friend.
OC.
Current builds
Completed works.
Very kind words Ferit     Thank You.
OC.
Current builds
Completed works.
OC.
Nope, not yet; you could make it look like one for me ;):)  I am sure the Admiral won't mind too much ;)
cheers
Pat
