My instructions call for contact glue in laying down the planks over the precut plywood subfloor (deck).  I have worked with this stuff on scrap pieces and it is kind of tricky and a bit messy to coat such narrow and thin surfaces as are the planks.  I've devised a "jig" to lay them all out side by side and clamp down the ends on a piece of cardboard, allowing me to coat all 15 planks at once.  When dried I would then place them one by one onto the deck which poses no problem in coating.  I am wondering though if anyone has used plain ole white glue for this purpose?  It would be much easier to coat the surfaces and any excess is more easily cleaned up.  Only drawback I see is that the planks could slide a bit when being laid down.  But this could be solved easily enough.  Any suggestions or comments?
I'm personally not a great fan of contact cement. Volatile fumes require respiratory protection, no wiggle room in laying the wood down, and so on. Plain ole white glue does it for me. If the pieces to be joined are thin, water content can cause warping, so dampen the unglued sides of the wood to balance out this potential issue.
I use the same as Russ. I purchased a standard size container of carpenter's glue, and so far it has lasted for two builds and sets relatively quickly.
- Bug
I use TIMEBOND contact glue which gives me time to adjust the plank, i just gently lay the plank in position before fully pressing down,
 even then i can still make slight adjutments. As  the regards coating the planks i lay a strip of masking tape on a peice of spare wood
then just briskley coat the plank then immediatly lift up and lay it somewhere where it cannot stick to anythink. Sometimes it helps if you
very slitley thin the glue, but do not overdo this, the masking tape is renewed for every strip but you can lay several strips at a time
you can do a number of planks a time.
                                           regards:janet B
It seems that Timebond is a British product. I have never used it, but when I search it on the web, it sounds interesting. Janet, what do you use to 'thin' it? The rubber based contact adhesives I am familiar with require 'spirits' like acetone.
I also have used carpenters glue not only for modeling but lots of furniture I have build over the years. I bet I must have used several gallons by now.
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
Thank you all.  You've renewed my faith in carpenters glue.  I am right now waiting to look at the results of a test I did a couple hours ago with the white glue -- actually I also have the yellow stuff by Elmers.  I have a feeling it is going to bond just fine.  Thank you Druxey for the tip re dampening the planks....they are extremely thin.  I would think a good way to do this is to do the planking then swipe the whole thing once or twice with a damp sponge.  Thanks again.
Yellowish wood glue works great for me.
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
  • 7 months later...
Janet B
           As regards thinners for TIMEBOND contact adhesive you can buy it from good stocked hardware stores,i get mine from a store in Bournmouth
U-K the shop is called INEXSSES usually when  i vist Bournmouth i usually buy 4 tins so i have plenty in stock. I have seen other makes sell the thinners,
in using it if you thin the glue too much it just soakes into the wood and is not effective so do not overdo the thinners.
                                            Regards Janet B
"DITTO" on the Elmers yellow glue, fast dry time and permanent glue job, rubber contact cement glue can have a limited life span and come apart down the road with time.  Works for me! :)
AL
H.M.S. Triton, 28 gun frigate (Cross Section) 1:18 Scale build in progress
Have used a lot of contact cement on leather, it holds well and is flexible when set. I have let one surface dry and left the other piece wet and quickly placed the parts together. That allowed for some shifting of the upper part if needed. Then rubbing like heck with a door knob or a shaped and polished wood rub stick will get a good bond with leather, modified a bit it should also do well for wood. Also have done it by the book on leather and ply board. Doing it that way I inserted wax paper between the pieces which allowed me to shift everything around until all was lined up. When properly placed I slid the paper back a short way and pressed that small uncovered area together and then clamped or rubbed, that small place well. Doing it that way you end up with an anchor to hold the upper piece in position as the wax paper is slowly removed from the joint as you pull the wax paper from the rest of the joint. Wax paper and planking should work well together, but I think I would use the good old white or newer yellow wood glue instead of contact cement. The contact cement I use is Barge Cement, buy it and its thinner by the gallon.
jud
Edited by jud
I use carpenters glue (PVA).  To keep the plank in place while the glue dries, I place a very small drop (about the size of a pin) of Super Glue (CA) on each end before placing the plank on the deck.  I then rub my electric plank bender over the plank a few times to heat up the plank and accelerate the drying of the PVA.  It's the same technique I use for planking the hull.
Edited by bogeygolpher
PROWE
If someone says something can't be done, it only means they can't do it.
Building:Shipyard - HMS Mercury card madel
Completed Builds:
Wood Models; AL Bluenose II 1989, Corel Toulonnaise 1995, Corel Flying Fish 2000, AL Scottish Maid 2005,
Sergal President 2010, Mamoli Beagle 2011, Corel Eagle 2013, Mamoli Constitution Cross-section 2014, Victory Cross-section 1/98 by Corel 2015, Occre San Francisco Cable Car 2018, Model Shipways Armed Long Boat 2021
Card Models
Christmas Train by PaperReplika 2012, Yamaha DSC11 Motorcycle 2013, Canon EOS 5D Mark II 2014, WWII Tiger I Tank by Paper-Replika 2014, Wrebbit Mercedes-Benz 500K Roadster 2014, Central Pacific no. 60 Jupiter card model 2015, Mirage III 1/30 converted to 1/33 card model 2017, TKpapercraft 1912 Mercer 2021
Have used the method of coating both surfaces and letting it dry slightly but didn,t heat it , be carefull i finished up with quite a few springy planks ,maybe i just haven,t perfected the method yet but will think twice about using it for long planking again . Used titebond II Am not a fan of super glue ,no time for proper alignment .
Edited by shihawk
Hi All,
I've posted this idea a bunch of times on various forums. It's an old finish carpenters trick. Spread a thin layer of Titebond or Elmer's carpenter glue on one of the pieces to be glued and let dry. Spread another thin layer on the other piece and press together less than a minute.. You get a tight glue joint with finger pressure and it binds like contact cement but still gives you a little bit of work time to align the joint. It even works with end grain. Give it a try, experiment you'll be glad you did.
Best,
Steve
bogeygolpher brings up a good idea. When building model planes, I often apply a thin layer of yellow glue (Titebond) via small paint brush to both mating sides of the wood, i.e. balsa wing sheeting (where the ribs will attach) and the top edge of the wing ribs. I let the glue dry. Then I just place the wing sheeting over the ribs and, using a small ironing tool, I apply heat where needed. The heat activates the glue and I get an instant bond. I would think this technique could be used for planking and other wood bonding while building a ship.Fair Winds,Joe
Hi Joe,
I've actually used that technique for years when attaching veneers and appliqués to various kinds of substrates while furniture building. Usually I've attached large, highly figured, veneers and have used a household iron to heat everything so it didn't occur to me to use this idea for ship building. But I really like your idea of using the kind of iron Tower Hobbies sells for use with mono-cote etc. I'm definitately going to try it.
Best,
Steve
I have found that PVA works well for me when laying decking. It dries quickly enough but still allows for time to move the pieces should I need to. I certainly use CA, or epoxy but for decking I have found PVA to work well.
Bill
Chantilly, VA
Its not the size of the ship, but the bore of the cannon!
Current Build: Scratch Build Brig Eagle
Completed Build Log: USS Constitution - Mamoli
Completed Build Gallery: USS Constitution - Mamoli
In addition to all the good reasons listed here for using PVA, it also wipes off cleanly with a wet rag so that you don't get any marks on your deck after you varnish it.
Tom
Current: Sergal Sovereign of the Seas
Previous builds:  AL Swift, AL King of the Mississippi, Mamoli Roter Lowe, Amati Chinese Junk, Caesar, Mamoli USS Constitution, Mantua HMS Victory, Panart San Felipe, Mantua Sergal Soleil Royal
