Nils thanks for the information, a very clever idea.
Michael
Build log part 12
Bulwarks on the high deck mounted and also plated
Bow area plating
for plating keel and bottom Areas the ship is removed from the stand
and placed back on it again afterwards
Build log part 13 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Nils you are a amzing.  I am surprised you are not thrown out of the house for spousal abuse. :)  Seriously you are making ecellant progress and your planking is neat and clean.
David B
Build log part 13
plated right down to keel
welldeck bulwarks mounted and plated
highdeck wake protection spoilers
Looks quite OK so far
bow with fitted water stay fastening points
the original Laeisz paint scheme finds its Revival
here the anchor Points for shrouds and backstays are prolonged from welldeck upwards through the pinracks
portholes not fitted yet
have to get used to the new colours in my Hobby room
so far, so good...
Build log part 14 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
That is it I am calling the guys in the white suits.  You must be admitted for chronic ship modeling.  You definately need therapy.  A nice bottle of beer and a good pizza and a good game on TV will fix you up.  Outstanding.  I am turning green with envy.
David B
David,
you should see the smile on my face when I saw your lines, you also have a good senced Humor - Thanks mate-
The bottle of beer Pops up before my very eyes, had a busy day out of house, will head straight for the fridge now...
Nils
Current builds
-Lightship Elbe 1
Completed
Does anybody know
the english Name for that typical White bottle like decor on top of the bow post ??
In german we call it "krulle"
During the owner periods the the Companies put their Initials or their Company logo on it. The last owner "Zerssen & Co" by using Z&Co is shown on my model
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you John,
I asume it is (or was) typical for the Flying P-Liners, for example the 4-mast barque Passat was bearing Initials "F.L." for Ferdinand Laeisz, but this had been specially reconstructed for the todays Museum ship
Nils
Current builds
-Lightship Elbe 1
Completed
....get used to the new colors in your hobby room.........you can keep it in mine,  if you want :D :D :D
you say the plating is like the others.....but I never tire with seeing the detail you put into it.  beautiful work Nils........ :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you B.E.
of course it differs (typewise) from the beautifull historic Swan Class you are doing, but one could say at least also a riveted younger Oldtimer, now also having its place in history
Regards,
Nils
Current builds
-Lightship Elbe 1
Completed
Richard and Popeye
thank you both for your appreciative words
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 14
bow bulwark done before painting it
after paint touchups
Fitting supports for the aft boatracks
bow decor
aft decor
Bow views
replacing dummy catwalks with metal ones
aft welldeck deckhouse with supports
Build log part 15 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
David
the paint I use is from the german crafter chain "OBI-Markt"
These come in 300 gram tins, are of satin type dull-gloss, and in many desired RAL colours. They work out very well covering, dry off to a wonderfull smooth finish within 2 hours and can be applied easily with a regular soft paintbrush (like used for watercolour painting)
The paint is one component resin base solution with detergent, already preset for use. Store closed tin upside down.
Trust this helps....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 15
portholes not inserted yet
portholes attached
working on the catwalks
here can be seen how the hight adjustable supports are fixed
ready for soldering
soldering started, hatch #2 rims (before the highdeck bulkhead)position check
the same with hatch #3 (after the highdeck bulkhead)
hatch rim
Build log part 16 to follow.....
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Build log part 16
This is just a reminder :
In order to avoid anyone in thinking that this build is "online"...., as I already pointed out in my intoduction, the ship is already complete, and put into my Album in Topic "Gallery of completed scratch built models" (the actual building time was full 2 years).
I am gladly postsharing these documented build log sequences with all those mates who are interested in this Tallship and its build
Nils
set auf hatches with removeable covers
Hatchcover with hoisting-eyelets
some white paint put on
nearly time to start doing the boats
upper portions of bow- and highdeck bulwarks paited black
The electric powered winches for Position checking
Build log Part 17 to follow...
Nils
Current builds
-Lightship Elbe 1
Completed
Hey Crackers,
thats great, thanks for your nice Research on this Topic, wonderfull picture, it is excactly what I was looking for, so that White coloured bottle shaped item belongs to Pamir`s "Billet head", learned something new again....
Nils
Current builds
-Lightship Elbe 1
Completed
John
Thanks for clarifying that one...
Cheers
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 17
time to do some winches in scale 1:96
some further painting work done
first prototype of the four electric Motor driven gear-winches (equipped since 1951)
These brass Frames shall be turned into the 3 Jarvis bracing 6-drum-winches
size of two fingers breadth
a few days later...
complete Manual operated bracing winch
checking space requirements for the winches
the poopdeck brace winch has to be shifted to the aft a bit, in order to place 2 watertanks in front of it. For doing so the two small vents also have to be moved a bit
This one fits well
Build log part 18 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 18
eletric Motor cooling ribs made from a small gear pinion
one can already imagine how "crowded" the deck became after the changes in 1951
set of winches (the three hoisting / lowering wormgear winches to verticaly move the Yards follow a bit later on)
here the tanks for cold fresh water and warm water with connected discharge pipes
poopdeck tanks painted
Forward welldeck Davit bearings, pantry`s watertank and compas platform mounted
Nav. light Towers that go to the forecastle deck
Build log part 19 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Am using neighther the one or the other David,
all "lathing" cutting and symetrical shaping to the centerline is done with rotating electronic Speed controlled Handdrill,clamped for horizontal mounting, and a small metal blade handsaw and several differnt shaped files. All cutting out of brass sheet and -plate is done with my good old jig saw, and for all the remaining I use simple key-files, drills and sanding paper. I know it Sounds a Little oldfashioned, but it worked well on all the models I made to date.
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 19
time to think about the booat cradles
Navigation light Towers mounted
the rear Davits (front boat Davit) are mounted to the highdeck bulkhead and go through the welldeck pinrack
looking foreward from above view
here come the self braking wormgear winches for Yard hoisting and lowering
six of those wormgear required, here handwheels mounted, the wormshaft made from a screw with the same pitch as the toothwheel has. Gear reduction 40:1
again the three Jarvis winches
and the Motor winches
I shall probably post the work beginning with the masts and Yards next....
Build log part 20 to follow
Current builds
-Lightship Elbe 1
Completed
all "lathing" cutting and symetrical shaping to the centerline is done with rotating electronic Speed controlled Handdrill, and a small metal blade handsaw and several differnt shaped files. All cutting out of brass sheet and -plate is done with my good old jig saw, and for all the remaining I use simple key-files, drills and sanding paper. I know it Sounds a Little oldfashioned, but it worked well on all the models I made to date.
Nils
You are a glutton for punisment.  I tip my hat off to you
David B
David, please help me along....
why must that poor animal? (glotton) be punished, smile..., I probably did`nt quite get it, I know I need punishment sometimes but thats a different Story...
Nils
Current builds
-Lightship Elbe 1
Completed
