Thanks, Jan!
As to your question...this model is 10.5 cm across the beam, 8.5 cm from keel to the top of the rail and just over 6 cm fore and aft.
(That's 4.5" x 3.25" x 2.5" for the metric-challenged!)
This is one concentrated headache generator!
LOL,
Gabe
Current builds:  Harvey, Baltimore Clipper - Artesania Latina;  HMS Triton Cross Section, 18th Century Frigate - online scratch build; HMCS Agassiz, WW2 Flower-Class Corvette - HMV - card model
Completed:  Swift, Pilot Schooner - Artesania Latina --- Build log --- Gallery;  Skeeter, Ship-in-Bottle - Ships a Sailin' kit --- Build log;  Santa Maria, Caravel - Artesania Latina --- Build log
Companion SiteHMS Triton log and live feed
Hey there, Jan.
Power tools, yes. Precision, not so much. I wreck a lot of wood before I get it right! Getting these planks to the correct size has been an exercise in frustration! Sand paper has been my most valuable tool!
Have you thought of a ship in a bottle? That's all hand tools. I tried one and I'm sure that I will be building more of them!
Regards,
Gabe
Edited by GabeK
  • 11 months later...
Back at it?
Well, my poor Triton has been sitting idle for almost a year and collecting sawdust from my other addictive hobby - pen-turning. (A dark abyss, but rewarding for the fast results). A victim of this new passtime and the bathroom renovation from hell at my cottage, the deck clamps that I started laying out last January have not been touched in months. I did get a new Proxxon saw blade which I hope will fix my frustrations ripping planks.
So, here is the status on the deck clamps:post-3853-0-33313800-1482941960_thumb.jpeg
Using The Anatomy of a Ship: HMS Diana I planned out the anchor stock design and realized that, because of the angled cuts, it would be easy to make these run crooked. The lines on this paper are exactly the width I need for the clamps so I am able to lay out the planks nice and parallel, keeping them in place with pins as I go.
Nice to see you back in the Triton shipyard
Regards Christian
Thanks for the reply, Christian, and everyone for the likes. Good to be back at the dry dock!
I found a small error in my layout of the deck clamps. While I was carefully reproducing what was in my main reference, AOTS: HMS Diana, I forgot that I was building the HMS Triton! When I was dry-fitting the planks it soon became obvious that there was a problem: the butt ends were hanging between frames! So, I had to rework the measurements and cut several new planks that now go from centre-to-centre on the frames. Good news was that I could still use parts of the first planks.
Cutting the planks accurately was 'interesting'. After carefully marking out the shape I used a CMK resin blade.
I glued up the pieces and clamped them into place. After a few hours I checked them out. I had to fix up a small mistake on one end...a small gap that still doesn't look perfect but I will try to fill it once the glue dries thoroughly. I don't normally say this, but it is something that will not likely be seen by anyone! (Shhhh...it will be our secret!
As usual, I continue to enjoy your log and the way you approach the build. It is very interesting how different model building can be from real ship building.
I came across the restoration of the Pilgrim Brixham sailing trawler, a Cutter-rigged ketch, at
http://pilgrimofbrixham.co.uk/history/
In the video of the build on that page it is quite clear that there's a contrast between the visible imperfections on the internal fittings, and the eventual smoothness of the external and visible finish.
Also, on the deck and hull planking, I really can't see the treenails in the still photos.
Of course, this is a modern restoration, but it made me think about the conventions of the modelling we do.
I suppose this is by way of saying that your build is still great even though you worry about the small imperfections such as gaps that have to be filled or colour mismatches fixed. In real life gaps were filled and paint did a great job.
Tony
  • 2 years later...
OMG!
TWO YEARS HAVE PASSED since I last worked on my Triton!😳
When I was still teaching I remember meeting retired colleagues who said that they were too busy!  I would tell them they were idiots...was not going to be too busy when retire!
So, now I’m the idiot! 🤬🤯
UPPER DECK CLAMPS
However, I finally dusted off the Triton and good thing I took good notes! I had made a measured diagram (over two years ago!) of the upper deck clamps  which were symmetrical anchor stock unlike the lower deck clamps. This was a nice surprise that allowed me to get right to building!
Rather than cutting partial planks I decided to make a run of full deck clamps that would span over twice the length of the keel. I thought this would make it easier to keep the planks running true.  I realized that to mirror the two sides of the ship I had to flip the beam diagram for the starbooard side.  I measured and laid out the cuts the same as before.
[grrrr! Messed up some how and prematurely posted this!]
[Man, I keep messing up and losing my edits!]
When time came to start gluing I noticed that a couple frames had warped a bit. 😡I moistened them a little, inserted spacers and glued the planks one at a time, allowing a long cure time between pieces (8-10 hours).
3E5284B3-5D4C-48CD-A64D-0110BE4756C3.thumb.jpeg.00f63865d15355592490ed8053c0b688.jpeg3CA0F263-8246-4271-8F5B-19346617435F.thumb.jpeg.ddcde6c1aeba9462d07f5b067b208de2.jpeg
While waiting I began preparing 1.35 mm stock for the “thick" stuff that would be next. Thanks to Bilge Rat's advice to get a slitting blade, I had a lot more success than before.
The planks on my model need to be 0.80 mm!  I was having trouble getting such narrow stock on my saw...but I then remembered right under my bench I had a pizza box full of random veneers! I began rifling through, finding all kinds of goodies but not quite what I needed. 😢Just about to give up, I spotted a piece of 2’x2’ Finnish birch plywood in my wood stores that is...0.8 mm!😳😃 My plank woes are solved! (I hope!)
Clear skies and sharp tools!
Edited by Gabek
Posted accidentally before completing
Good to see you back.  To paraphrase.....  Retirement ain't for sissies.   I seem to have less time now than when I worked also.  Maybe it's a distortion of the space/time continuum that occurs when when we retire?
Thanks, Mark!
I think you’re right about the retired persons' time-space continuum being shifted...the naps don't help! 🤣😜😌
- Gabe
We're entitled to naps???????   Really????
Kindred spirits - so it's not just me!!!
Forced into semi-retirement from a career in teaching by health issues, I had great plans for all that wonderful time I would gain - model ship building in daylight hours (Victory and Triton), re-building my Norton etc.. Fat chance!!! The Boss (Admiral) had other ideas including not only renovating the bathroom but also the sitting room and then the kitchen, and all on top of the usual daily tasks essential to achieve that secret to married bliss ie. anything for a quiet life. I now work in the classroom three days a week 'for a rest'. Naps, naps? no time for such luxuries. So much wood to shape ..... so little time ....
Excellent work, Gabek. I'll be following your progress with interest.
Graham
I hear you, Graham!  I have a house and a cottage...so, basically TWO places going to pieces!  My wife said to me last summer as I was nailing up some interior pine boards, "Gabe, you're making this cottage so cosy."  My reply:  "Dear, you realize that I'm actually building my coffin.  When I kick the bucket, place me in the middle of the floor, light up the place, and build the new one on top of the ashes!"😃😁😂🤣😮😲😵💀👻
Thanks for the comments!
Kind regards,
Gabe
Quick Work!
Before I started the last planking I noticed something off. I dreaded picking up my calipers to measure the space between the thick stuff and prayed it was an optical illusion.  The thick stuff on the port first futtock was 1 mm out, but parallel to the other pieces.  At this scale that millimetre is huge!  The mistake was done well back when I centred the the first pieces of thick stuff on the chocks. Somehow I messed up that placement and it now came up and bit me!
Highlighting the discrepancy in the port and starboard quickwork.
What's coming
So, my planking on the interior hull is not symmetrical.😢BUT, it will almost be unnoticeable once I finish the model in the way I envision.  Of which I think I will now sneak out a few details:  I plan to put the model on a turntable so people can view all sides.  I hope to paint the interior from frame C through frame 1 so someone looking from the bow will see a more realistic view of what the Triton may have looked like.  When viewed from aft, frames 2 through 5 will remain natural wood with perhaps some cuttaway.  I think I will paint one side of the outer hull and leave the other natural (and maybe cuttaway).
Air Space
One thing that perplexed me for a long time was how did they handle moisture between the interior and exterior planking?  It wasn’t until I got the Anatomy of the Ship books that I spotted how...there was an air space built into the planking! The size of this airspace seemed to vary considerably.  In HMS Diana it was close to the thickness of the deck planking, in HMS Pandora it was a complete strake, and in the HMS Trincomalee it was perhaps 7-8 inches midship according the photo in the book I have.  So, I incorporated a 0.8 mm air space in my model that I guage is somewhere between Diana and Trincomalee in scale.
And on the HMS Pandora...
What next?
I have a couple of small gaps between my planking that I will address next and I will likely cut back the excess keel and sand the ends of all the planking back to the outside frames.
And I could use some advice from you folks!  I face a couple of conundrums:
a) should I paint and apply a finish to the current planking before I close off the (small) area with the lower deck?
b) Should I work on the gunports and stabilizing the frame tops before the main deck?
Not a lot of space in this model!AAC57F0B-5DF4-4115-8A3A-E4102C1CDFFB.thumb.jpeg.40ba7682099d59aef59732f6ed1b067d.jpeg
Thanks for any advice you can offer.
- Gabe
Gabe ponders...
If it's not going to be accessible, then by all means yes.  If there's going to be various bits and pieces installed in that area, do those and seal before blocking access.
By all means, stabilize the frames.  As for the gunports.. again, it's question of access.  If you're planking the  inside and/or the outside, do them before planking.
A year! It’s been almost a year since I last worked on this model! Sheesh.
One step backwards...
I have some advice for other procrastinators:  go back and read your build logs before you pick up that forgotten model.  It would have saved me half a day of work if I had! When I took my Triton out I was perplexed to find that I had only finished one of the upper deck clamps. So, I began preparing stock and planning to shape pieces when I came across the fully assembled clamp in the bottom of the storage container! Wha'?! Then it all came back to me. I discovered that the frames on one side were not spaced properly and had to painstakingly remove the clamp. I was so disheartened by this backward step that I just boxed up the model in disgust and put it on the shelf!
Good news: I didn’t have to fabricate a new deck clamp and, in no time, I had it glued in place with the frames properly spaced.
542F18C7-1C04-49AF-8878-3E62112DBA03.thumb.jpeg.fad658d78f01b52fa469ddfd9ba0d20b.jpegNew/used upper deck clamp back in place.
Deck Beams
 After mulling over my options I decided that I should build the decks.  This would determine the spacing of spirketting, waterways and interior planking. I was able to prepare some 3.30 mm birch stock, glue on templates for the beams and rough cut them out:
As usual, sanding these small pieces to the correct lines presented some headaches. I tried to do it all by hand, but it was taking so long that I resorted to gingerly taking the "bulk" waste off with my 1” belt sander.  I forgot how nerve-wracking this is! One tiny misstep and I would have to start over again!
B0785442-7A9A-4F52-9149-252DB9669A0D.thumb.jpeg.759502c2034982e02d0bead2e6639838.jpegA study in concentration.
I first tried to do the final sanding with a sanding block but it was taking forever and I was getting frustrated. Birch is beautiful wood to work with but its hardness was working against me. I needed something larger and faster to remove the material before I exploded.
BBCA0612-1F18-4887-BCA8-9BB4C42B202A.thumb.jpeg.b6f36a29a79c7d44ea6c65cc2e30651b.jpegAre we there, yet?!
In preparation for working on the model I rejuvenated my sanding stick with new 100, 150, 240 and 400 grit sanding paper. With a scrap piece I tried out if I could drag and/or push these small pieces across the wider sanding surfaces. And now birch was my friend! These pieces handled the sanding very nicely and in no time at all I had all 8 deck beams to where I wanted them.
11B920C8-A4EE-43B9-9C5B-D3F2676E6B7C.thumb.jpeg.b775124de96fe535113aafd242701509.jpegEasy-peazy sanding!
To eliminate minor differences I clamped the four lower deck beams together and did my final sanding to shape.  I’m too excited to get to the rest of the lower deck that I'll finish shaping the gun deck beams later.
I dry-fit the lower deck beams and I’m happy!😃 (And now I see how little room I have to work with!😳)
2E85A58A-CA70-43FA-B6BD-D68E6941E5A3.thumb.jpeg.0eecd043e4fea90e76d7898a0d8da07b.jpegAEE94347-945F-429E-AFDB-E808A4AAC602.thumb.jpeg.036f351f7e6c165fbf572f1b34b8060b.jpeg
Going to have to do some careful planning from here on.  Particularly because I intend to show the hold with ballast and stores. Any advice would be welcome and appreciated.
Next step: this Canadian goes carling!🇨🇦🥌🤣
I set up my little table saw to make carlings. I’m astounded that I had to make over a metre of 2.6mm x 2.6mm stock for this tiny model! (And there will be way more needed for the ledges!) As I was cutting all the carlings I was mulling over the next steps and realized that I need to deal with the beam arms before anything else. The stock material  was made by resawing some birch left over from the frames.
(Kind of messy job with the spray glue!)
My biggest concern in making these beam arms was to make sure I had the spacing and sizes all consistent.  At thIs scale, just a fraction of a millimetre would be noticeable.  So I devised a plan to mark and shape the pieces so that they all matched.  After I glued on templates I sanded each raw blank carefully to where the beam arms needed to be notched. This allowed me to line up those notches when I clamped all four beam arms together.  I then made the stop cuts for the notches by cutting across all four beam arms at once.
Using a square and knife to mark the notches.
Marking all done.
Using this microsaw to make the stop cuts
I separated the pieces, made several depth cuts in the notched out areas, and used a small chisel to rough cut the material. I concentrated on getting one beam arm completed by filing, sanding, scraping and praying.  This first beam arm would become the template for the remaining ones, which were first rough-shaped on the belt sander and then clamped altogether for final shaping.  Although not perfect, I'm pleased with the end products. It was good practice for when I will do the same for the gun deck.
96630458-8C84-4F64-ABB6-D5A219DFA5A5.thumb.jpeg.0cfdae3b03c08d75cf9b33fa6e433695.jpeg84F094A3-0F34-4356-B106-D40AA06040F2.thumb.jpeg.5c2729baffd4d3a4222e9d1fbad32d30.jpeg
Depth cuts to assist in making the notches
Taking out material using a small chisel.
Filing to the lines.
EA3B39B0-B3A2-4C95-90D4-9338635B541F.thumb.jpeg.cdf17cec47d93394b17a50b35b2966e4.jpegFirst beam arm done.
577FA782-B17E-4D29-97D0-2910CFC07554.thumb.jpeg.8b406fbed4599f6e3c266de6a187497c.jpegThree more to go!
19D281B0-FAD5-4409-96EA-F2D7373C521F.thumb.jpeg.789ca09682028f0725b703141c453cd8.jpegGetting ready for final shaping.
Here are all the tools I used to make these!
One wrong move and...🤬😢😫
The whole time I worked on these I chuckled at how much anxiety they were able to create and how much they reminded me of the wishbone from the Operation game!  And about as big!
Clear skies!
Gabe
Edited by Gabek
Formatting problems
To arms!
I had a clear idea of how I was going to fit the beam arms to the beam. I would need to concentrate on creating notches that lined up, were square and had tight junctions.  Well, easier said than done!  I first trimmed all the planking and sanded the ends on a flat surface. A single coat of varethane was applied to the outer frames to keep dirt off and minimize damage.
I dry fit the beam to determine the proper placement of the beam arms.  Once laid out I used an exacto knife to mark where the notches would need to be made, maintaining a correct alignment of opposite beams arms. The microsaw allowed me to create the stop cuts.  I needed to use the very tip of the xacto blade to carefully chisel out the notches. A slip here and I might have knocked out a giant chip, wrecking all the work...but what’s new?! All of us are in this boat (🤪) together!
EBA4490F-C8A0-443E-B310-ED02EDD2D6CA.thumb.jpeg.d77d71a19632a23188def096d0997a13.jpegD28735D4-FDD1-4B8A-B454-5573C198EFC6.thumb.jpeg.5fbc5645df2b20dc16e53808753ad63f.jpegE7354E73-3F26-4E5D-8C24-9F45BDCE9A47.thumb.jpeg.e93f0e9e49e7a0180a5355bdd7800a65.jpeg
It took a lot of trimming, scraping and cursing to fit the beam arms and, in the end, I had a few unsightly gaps and mistakes.  I then reminded myself that this work will likely never be seen.  Besides, I collected dust from sanding the frames and will be adding it to the glue when the time comes to fill in the voids!😳🤣
960755B6-6197-4A30-BF63-634654BC7F03.thumb.jpeg.bf61aad0df7b346e9ff49588ec749717.jpegEB43B394-4E07-437A-9248-2E3EA764F6FA.thumb.jpeg.d9c2552a66f12a57224b5f0def3d60e3.jpegBEA96CAA-64EC-43A4-B083-D4ED48B0C3F2.thumb.jpeg.2f7b920f17f566793aeac2d14532a88e.jpeg
Clear skies!
Gabe
Edited by Gabek
A fantastic job on those beam arms at that scale, I'm going to hang around for the rest of this project if you don't mind!!??👏😃
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Thanks for the compliment, Edward!  And please join in! Great work on your Triton(s) 😃by the way.  I'm really enjoying your log(s)!
Clear skies,
Gabe
Edited by Gabek
Beautiful work, Gabe.  I've been thinking that 1:96 would be impossible but you're doing fantastic.
Thanks Mark!
The beam arms were a real test and I think I'll grade this effort at a “C”. Decent enough job but some mistakes. Hopefully I’ll bring that up to at least a “B" on the gun deck!
On another note...
Reading other logs I'm torn between several paths.
I would like to assemble the deck right on the plans and install the entire assembly.  I plan to make one end of my model realistic which means painting.  Assembling the entire deck off this small model would help in that regard. But, I have already discovered: 1) that the beam templates I used from the frame planes are larger than on the deck plan! 2) the frames on my model aren’t EXACTLY spaced like the plans.  My worry is that I will build a deck off the model that will not fit well when I go to install it. Again, fractions of a millimetre are noticeable and troublesome.
The other choice is to build the deck in place like the shipbuilders would have.  I can correct and shape as I go.  I also think that installing the lodging knees next would also help keep the deck all square.  But, this is a small model and fitting pieces would be difficult.
A third option would be to follow some kind of combination of the above.
Any and all advice is welcome and appreciated!
Clear skies,
Gabe
Edited by Gabek
Hi Gabe, my advice for what it's worth would be to construct the deck frame on the model, because I did mine on the plan and had to make alterations to get it to fit into the hull.  Only minor changes but still changes. Just my opinion!😉
Cheers
Current builds;
Completed:
Gabe.
What Edward said is the best way.  The plans may be 100% spot on but wood breathes and humans's sometimes aren't 100% exact in cutting, etc.
Oh! I thought it was the PLANS that were out, Mark! 😂🤣
Attesting to the nature of wood, I noticed a significant difference in the width between the frames after I varethaned the outside faces. The beams fit very well beforehand but are now too long for the space. The "spring" in the frames is also much reduced, making me wince when I try to dry fit the beams.
I'll be following your and Edward's advice and move ahead with building the deck in place. I’m going to have to carefully plan the painting and realistic touches I intend to add.
Warm regards (it was -34C in Winnipeg today, btw, so I really mean it!🥶)
- Gabe
Wow... that is beyond cold.    I hope everything goes well with the build from here on.  I've noticed that unless I make the air inside more humid, my wood dries out and shrinks.  I'm still shivering over your temperature up  there.
Weak/Week in the Knees
After too much research (I'm cursed by this habit/addiction! 😩) and a week of dithering I decided to alter the arrangement of knees from the simpler, yet elegant, plans. In the AoTS books Diana and Pandora, the lodging knees forward of frame 0 abut to the aft side of the beams, there are knees between the beam arms and there is a transition where there are two overlapping lodging knees or a scarphed pair.
Mess deck of HMS Pandora (Anatomy of the Ship, McKay)
HMS DianaMess deck of HMS Diana (AoTS, White)
[aside: this content editor is giving me grief on my iPad 😡]
I couldn’t visualize the "transition" knees but, lo' and behold, there was a picture in HMS Trincomalee by Davies:
I took ideas from all of these plans.
First, I notched the deck clamp for the beams. In an attempt to be consistent I resorted to scribing the depth of these notches by using dividers from a drafting set my father gave me when I was 12!
Dry-fitting the beams
Now on to the lodging knees.  I drew up the additional knees and my rearrangement.  At this time I decided to incorporate a hatchway to the hold and...(gulp)...I'm debating about putting in the well and shot locker 😫😭.  I decided a while ago not to do this because it will obstruct the view into this tiny model, but after recently looking at Ainar's wonderful work I may just have to add these. (Sigh)
I cut some birch stock and glued on templates. Shaping these pieces challenged me and it took me a while to work out exactly how I could do this and maintain consistency. Just holding them was troublesome!  I was most worried that the knees needed to look identical from port to starboard. So, I roughly shaped each knee and then clamped together opposites and fine-shaped them as one piece. I had to use several tools to accomplish this but needle files, diamond files and small rifflers did not work well and I ended up attaching  sandpaper to chopsticks for the final shaping.  Once I had the work flow figured out I could shape a pair in about 10-15 minutes. E40B732D-E265-4988-958F-5565CC58A4C5.thumb.jpeg.2bc3eb547c810b53b560c3649184a198.jpegCFC4FDC1-C531-45AD-B4DD-41C6A637F15E.thumb.jpeg.a856e6059650a335418a0ad51b7c7b7d.jpeg93B93F1F-8757-4261-82FF-40086A8D6E64.thumb.jpeg.cc87443dfd8cd1bd207c74c585ecef23.jpeg0B904E58-48E6-4529-AF24-6E1198592352.thumb.jpeg.8883c1133f0afc2c49ad63b5587d3756.jpeg5C1D99F3-BBA4-4520-80A7-D57333883EE9.thumb.jpeg.6bcda0a5d8994522f370765f1a610864.jpegFC830C86-52F9-49AC-B35E-A85C39B8CBB2.thumb.jpeg.e7d045c753453ef7e95f5f4d76b9cee8.jpeg4FCB5259-4386-4706-8579-9BC8734EFD84.thumb.jpeg.efe6cc73e5451599f8f1a54f9c41de81.jpeg
Now my headaches will be what do I do next?! Once this deck is in place I won’t have easy access to the hold...so I'm going to sit down with a bottle if aspirin and do some more careful planning!
Clear skies!
Gabe
Edited by Gabek
Formatting
Wow! Now there's a challenge!! The knees, lodging and hanging variety gave me headaches at 1:60 scale now you're doing more at a much smaller scale and making it look easy👏👏 I take my hat off to you sir!!
Looking good!!
Current builds;
Completed:
Thanks, Edward! The nice thing about small pieces is that you have very little material to remove.  The bad thing is you have very little material left behind! 😆
NOT looking forward to the hanging knees.  Too much shaping, too little space. Any advice would be welcome!
Regards,
Gabe
  • 1 year later...
Wow, another couple of years has passed! I’m still waiting for all that free time that retirement was supposed to give me…
So, after two years I first had to figure out where I left off and get my brain back in the game of solving the riddle of my "micro Titan" (thanks Ray a.k.a ziled68 for the name!).  After a day of reading all my past logs and advice from you folks I came to a couple decisions:
  1. I will need to finish the hold first: all building, painting and add-ons before building the deck.
  2. build the deck in place and not as a single unit off the model.
One decision I still can’t seem to make yet is to build the well like Ainars Apalais' incredible example.  The shot locker is the sticky point…it would impinge on the space under the main hatch. (Funny thing:  I've been thinking about this for two years and one of the things that occurred to me was to build a cutaway main mast…and I see that Ainars did exactly that! 👏🏼)
So, I set aside building the mess deck and started on pillars:
I cut some 3.3mm square stock from birch and, after cutting to length, I used a knife to chamfer the middle 80% of the corners.  I based this on Anatomy of the Ship: The Frigate Diana and a photo of the hold of HMS Trincomalee.
Pillars in these ships were put in place with square tenons but  I opted to use registration pins. So, I marked the centres on the ends of the pillars and drilled holes for brass wire. I the marked out where on the keelson the pillars were centred and drilled a corresponding hole. It didn’t take long to cut short lengths of brass wire and dry fit the pillars. I need to do some more preparations in the hold before I glue these in place.
And may I introduce “Number One” - a figurine I designed on Heroforge.com and printed at 1/96 scale on my Elegoo Mars resin printer. (Another reason I haven’t been building the Triton. I'll be posting about this in another topic shortly.)
Good to be back in the shipyard!
