I'm sure you're probably wondering: which relationship has this message and related images with the Brick I'm building and that headlines this log?
Does it have any relations to the Plating of the Hull?
Yves
Yves
Hi Yves, you are quite close to the true: I'm sure the next images I'll present and discuss in the forum will clarify very well some points related to the real appearence of the copper plating after many years in the salt water . .
Today I'm too busy to post new messages, but I'll come back to this topic ASAP. Cheers, Jack.
Mmmmh... you are making me curious!! ;)
Ciao
Fam
Joint building:
   Brick de 24, 1/48, jointly with Jack Aubrey (POB from Ancre plans)
Works in progress:
   USS Constitution Cross Section, 1:93 (POF bashed from Mamoli kit)
Completed models:
   Santìsima Trinidad, 1/90 (POB heavily modified DeAgostini kit)
   Genoan Pinco, 1/50 (POB bashed from Euromodel plans - my current avatar)
   Viking Knarr, 1/72 (POF from Dusek kit)
Wednesday, May 27, 2015
In these days I finished to install the gunwales and, as a final touch, I also gave a few black coats to them, so that now probably show an almost final appearance, unless new elements will be added in the future.
Now I got to a state where it is no longer possible to stall further the project:
1) proceed with a natural wood finish of the hull and go further with this modelling presentation philosophy, often adopted by several ship modelers, or proceed with the installation of the copper sheating on the underwater surface, opting in this case for a more realistic way of presentation. If I should adopt this second solution I should obviously setup a surface preparation of the hull rather different from the first case. Then we need a strong decision.
Regarding the first solution I had many experience, so it does add virtually nothing to my experiences because this would be a mere repetition of tasks already done.
For the latter, however, it would be the first time that I face such a serious commitment. I did a small experience when I covered the underwater hull of the cross section model of the Santisima Trinidad with copper plates, but it is too simple and small compared to what I'm expecting now. However even this minimal experience with the SST left something to me. More about this later in this message.
In fact it is several days that I'm on this subject by relating with other friends (and other I still have to do) and I also spent hours on the web to see what, how and who has already made similar experiences.
I picked up a good portion of these "discoveries" in a document that describes these methods (a kind of patchwork picked from various sources), but they are still far from my complete satisfaction to have everything right and clear.
Let's start for example from some methods of how to perform copper sheating.
First you need a proper preparation of the ground surface in order to facilitate the application of copper and improve durability.
Then the practice suggests two equally viable paths:
- Use bricks made of copper in proper measure and apply them one by one according to a default scheme or
- prepare copper strips on which are pre-cut more bricks and apply it on the hull in a more efficient way then previously.
The fixing can take place using glue (cyanoacrylate or epoxy) or using copper already equipped with an adhesive film, used in some hobby decorative tasks.
In addition there is the problem of the simulation of the riveting, topic still faced by many modelers with different methods but all quite effective.
The copper support that can be found in commerce is of two types: tape or sheet, both self-adhesive or not. The tape media is very easy to find in its self-adhesive form but is also available in natural form. The real limitation here is that the choice of the height is limited (5,6,7 etc) so if you find the right size to fit is fine, otherwise you have to compromise on the measures.
Even the copper sheet is marketed self-adhesive or not; I think that the sheet allows to make the right measurements of the individual bricks corresponding to the real original size, so I think this solution would be preferable.
Finally, assuming that we have finally achieved to fully cover the hull in one way or the other we are faced now with how to display it. And here it is necessary to make some assumptions.
From my experience with the cross section of the Santísima Trinidad I found that the copper, not treated with paint, left exposed to light and air, with time loses the original reddish brilliant color of the new copper and turns brown, getting darker, up to become almost black. To date, after three / four years, the color of my cross section is yellowish brown.
Treating the copper with a glazing paint fixes permanently the beautiful color of new copper. . but is it realistic?
But how becomes the copper in the absence of air under the water, in particular seawater? To hear somepeople the lack of air should prevent the copper from oxidizing and so the color would not change, others, instead, believe that there is still enough oxygen in the water to produce certain effects, in addition there is also the presence of salt water . . A topic of a forum addresses this topic http://modelshipworld.com/index.php/topic/8972-copper-plating-to-look-like-c-morgan-by-modelshipways/and it seems convincing. .
And here enters the USS Constitution. As you have read in my previous messages, this sailing ship was lastly covered with copper plates in 1995 and until a few days ago has always been in water. So if we take for example the images below showing the copper appearance after twenty years we have an unequivocal and indisputable evidence of what happens to copper when it stays in seawater for a long time.
Conclusion? Well, I leave this task to you, maybe, after having a deep look to the images that I propose here below, you will have the answer to the question with which I finished my prev message about Connie: "I'm sure you're probably wondering: which relationship has this message and related images with the Brick I'm building and that headlines this log ?
At first glance, you'll see nothing but, with a little of patience this news, by the way quite recent and do not know how familiar to many people may it be, has veeeeeery muuuuuuch to do with my model under construction. A few patience for now."
y4m7S4xiQA2W8MaUkcdrEE0c_d_5M5ZmvjKcOmgb
y4mfcquVbd96u00Jv7KF-apLi2D45sizfiwoUqSQ
y4mg9cGWAyhGwN1qQ-BWMnRWYs5b0iGAoulORNx2
y4mjN4O3wAk2daYswsBvj9-b-FxXeIGGO163eYon
y4mzbzKiBXkUKjJhY8vWLjoObMDJNyHc8FrNmG2W
y4moKZUZBn2sgxMPU1inW2iIT2ssvvBYAS2OMqa7
y4mNlbi8thECfY7ycSqakCFNJTPdgrNmHdDx5cLq
y4mj79c7Ua_9MZaoDxTJvX39HVJ0wEFkZpWL6ws_
y4mAAHGsf1VAoPBnZmvV7I89M2P0dLB45qmaUZBh
y4mNQqhJcUBZCcYsARxk9Ahm1hfxc0qf942XQRkI
Comments? Other points of view or ideas ? Every comment is more than welcome. Regards, Jack.
Edited by jack.aubrey
Saturday, May 30, 2015
Honestly I expected some reactions/comments to the subject I introduced in the previous messages regarding the appearance of copper plating. . . but probably I was wrong.
Patience.
Meanwhile I finished the activities that were ongoing, including the installation of the gunwales. Now I think I must invent alternative tasks to perform while I'm preparing for the application of the copper. YES, because I decided to proceed in this direction. It's challenging !! I still have to procure the needed materials: I haven't a clear solution so I decided to buy tapes and sheets, self-adhesive and raw, of various thicknesses to do some comparative tests, then I will choose the solution that will give me the better satisfaction.
While waiting I could start something that will be useful for the future, such as ship boats or some superstructures, I need to think about it. Besides, I should definitely level with sandpaper and finish the hull, also preparing the surface of the quickwork that will receive the copper.
01 Brick%20by%20JackAubrey/P1100282_zpsqkbwiaiy.jpg
y4mOzrAb0A0oejY-w8BfFxYK2rNAhvJ7ydpWVlx0
02 Brick%20by%20JackAubrey/P1100280_zpspvzt80my.jpg
y4msyE3qUb1pOIA7G0jNax9b7y6dnbZrqAPA7FJ1
03 Brick%20by%20JackAubrey/P1100279_zps5zl9uvgm.jpg
y4m82opl-4jbNSuDfa9YD249MkMsriDSX8r_veZ_
04 Brick%20by%20JackAubrey/P1100277_zpsdftzvkhe.jpg
y4mlZpxJOLITPRBJO9A_1mApdd9bI_CcIqOcoH42
05 Brick%20by%20JackAubrey/P1100274_zpsotprofr3.jpg
y4mV92SF7R1fWFgyKuZv1FIqBzkTwqa7N85g6KNb
Further images from different viewpoints will follow . . cheers, Jack.
In the meanwhile your beauty is still missing a couple of sheave blocks, vertically oriented in between gunports 4 and 5 (or 5 and 6, see my Brik)...;-)
Ciao
Fam
Edited by Fam
Joint building:
Works in progress:
Completed models:
Jack,
About the copper.... if you wish to copper her, go for it.  I'm partial to not coppering but then, this isn't my ship.   ;)
You raise a good point about the green patina. I think Constitution's hull should settle that question once and for all. If the model is being depicted purely as built and before launch, than non-green copper would be good.  If it's been in the water, than green is the way to go.
So, go with what you want to do.....
Yes, I know I'm not giving a great answer, but your research is indisputable.
Hi Mark,
I agree with your comment . . the final decision on how to show the model is mine. I wrote about my intention to pursue the copper sheating challenge and this is still my primary idea.
But I need to define the correct method and for this reason I'm preparing to test and evaluate several paths before selecting the best for me. In the worst case, if all the objectives of my tests will fail, I'll can change my mind forgiving copper and adopt the wood finish . . but with a good reason !
For now I'm interested in understanding if the example of the Constitution copper plates may be considered as an accepted proof of evidence or not. If yes, as you have written, this should be my preferred choice: I want to build a Royal Navy french captured brick, so we are speaking about a ship that was in water for some years.
Regarding how to obtain the green copper, it's again a matter of tests but I have at least two ways: a special varnish, I found on the internet, to apply over the copper and a suggestion form a friend of mine that made this experience using winegar and original sea sand. Again further ideas on how to obtain green copper are welcome . . and again thanks for your answering.
Cheers, Jack.
Ciao
Fam
Hi Fam, while I'll perform the hundred tests planned for the copper plates etc I'll surely find the time to add the missing blocks . . Cheers, Jack.
I can't help on the color of the copper, Jack.  You might ask that question in this area:  http://modelshipworld.com/index.php/forum/14-building-framing-planking-and-plating-a-ships-hull-and-deck/   By the way,  I believe Victory had the same color copper when she was last pulled out of the water before going into permanent drydock.
Monday, June 1, 2015
A cordial greeting to everybody.
I thank all the forum users for their comments and advices to my messages concerning the upcoming activities.
Unfortunately, in the absence of further developments "on the field", I come to propose further model images that date back a few days ago.
The fact that I haven't done anything "practical" in the last days does not mean that I have been totally idle, I simply continued my search for an optimal solution of how best simulate the hull plating with copper.
At the end (really ?), after many considerations, surfing the internet here and there and activating some other sources, I come to identify a solution that, if should prove to be viable, would become in my opinion the most valid. Now I am engaged to carry out the necessary checks this idea can be really pursued.
In the next post I'll try to explain better the idea and, in the meantime, I hope to confirm its validity, especially the feasibility. For now, enjoy the pictures. Regards, Jack.
01 Brick%20by%20JackAubrey/P1100276_zpsg9mlx6or.jpg
y4me-agUYmN3hwhGIhe6_v-MisXhB11DNDO5-6wB
02 Brick%20by%20JackAubrey/P1100284_zpsog3lwhn6.jpg
y4mAQ1fga0xneLZzlYWwimdkM25-p_QiFflHAfOO
03 Brick%20by%20JackAubrey/P1100281_zpsdfjdcwge.jpg
y4mj6_NI3TndoU0ywyMuKRsjVEIBkh5lmN9RrxSD
04 Brick%20by%20JackAubrey/P1100270_zpsyq8orfvd.jpg
y4mDdDpx8FOEzAcJi61bolGOHmykKPcTdsf5BVrg
05 Brick%20by%20JackAubrey/P1100271_zpsgjz85psd.jpg
y4mEbWmp0tFFmeZdSEZlr0eHtgs35eXk-KdFErN9
I like that nice fig tree that is in the background. Do you get sweet fruits, Jack?
Yves
Hi Yves, I have several fig trees in the garden (it's not mine but from my motherinlaw) and they produce several fruits . . . But unfortunately they don't ripe: they are all lost during their ripening season. I believe that in order to get some good figs I should graft them with other braches from certified trees . .
If have also a grapefruit tree and this is another matter: every year provides a good production of fruits, lets say from twenty to forty kilos of fruits depending of how good was the season.
Regards, Jack.
Thursday, June 4, 2015
First, I state having nothing new to show and I'm waiting to meet this evening with some other modelers to discuss my idea, so I limit myself for now to show two pictures trying to comment them.
The first image refers to a tool produced by Amati with a clear aim to simulate through punching on material like copper or similar studs the copper plates. It's sold with four pouncing wheels with different pitch in order to be used in different scales. A useful tool even if it should not be difficult to scratch build . . depends more on its costs.
y4m8cBYfoPq_LqBrrXs1bF7PBIM-vGLebhFDsyGx
The second image, instead, makes us goback to the messages regarding the USS Constitution after her entrance into the dry dock. The photo here below shows the appearance of the copper plates when, back in 1995 (see the date on the photo) were completely replaced and shortly before her return to the sea. I think with this last image you can better evaluate the changes intervened during her period in seawater. However it is not polished and reddish copper but tending to brown. Obvious as this is what happens to the air and the 3400 copper plates were certainly not produced the day before, then some kind of oxidation should be underwent.
y4mwTkGBFyiL7bJbSc_hTvxLCWr2TpYW9O_TkOMO
See you soon, Jack.
Friday, June 19, 2015
It's +/- fifteen days that I do not provide any news about this project.
Unfortunately I had other commitments and could not find the time to continue with my idea on the copper plating.
Commitments about matters concerning the condominium where I live, so I was heavily involved and I am just now released.
I also had to undertake the repair of my computer because the two internal harddisks showed signs of being to pass away and I had to recover the situation. As result I spent almost three full days to restore all the data on the new harddisks. Thanks to the fact that I have always had in place an automatic and regular data backup process I did lose practically nothing. But I had to reinstall many software, from Windows 7 Operating System to the application programs I usually use.
It had also a chance to do some housekeeping of all the "garbage" installed in the last five years. Now, thanks to the smart hardware changes, the PC runs like a beauty.
And so, rather than carrying on the copper plates matter, since I was on the computer many hours, I started thinking to get ready to build, at the right time, the brick longboat, the first of the three boats on this ship.
And here I followed the same path that led me to design the hull of the ship some months ago:
1) trace the longboat ANCRE plan with AUTOCAD,
2) correct some more evident errors in the drawing, which, as far as great, was convenient to adjust.
The result can be seen in the first image here below, containing all the hull design elements.
01 Brick%20de%2024%20Plans/v1.0.0.ScialuppaGrandeDisegno1_zpsgtelmm2d.jpg
y4mBKa_PmWj25TJlhp_8lbWu_HHBzmPz90ls8fqO
From the first drawing I then extrapolated some details, as the following views . .
02 Brick%20de%2024%20Plans/v1.1.0.ScialuppaGrandeDisegnoLato_zpsthsqaani.jpg
y4mm5z1dNIifKs_zwFwU3K85oaTE536EYMOlEPnc
Then I cleaned up a few lines that were no longer needed . .
03 Brick%20de%2024%20Plans/v1.1.1.ScialuppaGrandeDisegnoLato_zpsefmj0pri.jpg
y4myP32FxZzYyPnAMEN7mkNVLok2B4dXSTqrjYKo
Until I got the draw of the keel . .
04 Brick%20de%2024%20Plans/v1.1.2.ScialuppaGrandeDisegnoLato_zpsxwvbohjf.jpg
y4mhLIvIqjmy4Lv7u7ZOrWN9OtNTA_E2yMFxmKda
And the bulkheads from midships aft . .
05 Brick%20de%2024%20Plans/v1.1.2.ScialuppaGrandeDisegnoPoppa_zpsewgrx39p.jpg
y4mVzphdiw-mzUvXkwmjsZOJU00LaOMnkWQeFVns
The process continues . .
Cheers, Jack.
Saturday, June 20th, 2015
The last missing elements of the brick longboat plans: the bulkheads from amidship to bow. Now in theory I could start its building using the idle periods of time of the main project.
Cheers, Jack.Aubrey.
01 Brick%20de%2024%20Plans/v1.1.2.ScialuppaGrandeDisegnoPrua_zpssrg1vkjy.jpg
y4mKdM37-RqTA8FSHWLqIyCSDqbuDeFkBHtCTdYy
Sunday, June 28, 2015
Still a long period of inactivity regarding my shipmodeling activities. Too many bad things happened in this month and so I could not continue working on my model.
Only sometimes I could dedicate to it and this exclusively via AutoCAD in designing two of the three ship boats. I have already shown the greatest, the longboat, which should allow me to cut out the pieces to setup the hull and now I could begin its construction. . but i'm not sure this will happen shortly.
Then, I continued with the smaller lifeboat: the same type of work and now I have ready the preliminary project to build it. The thrid boat, the last, is still missing.
Finally, I continued to work on my idea of a "different" solution to the copper plating of the hull.
I reached the conclusion, may be right or wrong but for me should be the one with a better aesthetic result and process, that the best copper plates to be applied to the hull had to be obtained through a process of photoetching combined with a laser cutting.
In Italy there are several companies that provide this service. I found some time ago one conmpany on the internet that seemed to have the right requisites and I proceeded to contact it. Unfortunately they said that, although it is possible for them, they do not make business with privates and the business aborted.
So now I have to re-initiate a search until I found someone who is willing to do this work.
Meanwhile, given that the whole process of photoetching generally starts from a vector file (can be done, for example, with AutoCAD), I proceeded to draw a copper plate of the correct size with all the nails planned in the original plate, shown here below in a visible size.
01 Brick%20de%2024%20Plans/V1.2.0.PiastraRame_zps6spskkxo.jpg
y4m5Q-k-wPHwkju-MwjItie1boizBrrpLasKAWT0
I then proceeded to prepare the vector file in A4 format including the maximum containable number of plates, both for the right side of the hull than for the left side. Here you can see the result.
Everything should be photoetched and laser cut from a sheet of copper or brass (after year 1800 was no longer being used only pure copper but copper alloys with other less expensive metals) of the proper thickness, to be better defined with the photoetcher, but which should probably between 0.1 and 0.2 millimeters.
02 Brick%20de%2024%20Plans/V1.2.2.PiastraRameA4Lato1_zpstty7dvyx.jpg
y4m0ZJlKFTL_Ynu0r8pUzctshBfqM4Dk-mkXLuSX
03 Brick%20de%2024%20Plans/V1.2.2.PiastraRameA4Lato2_zpsxqelro85.jpg
y4maKXVvKObGN8L5t4qh-09uilTVii1O76c9KMKl
The story is still far from its end anyway, because if I do not find the photoetcher I'm lost.
Does anyone know one in Italy or in Europe ?
Jack,
Contact Dafi via PM here on MSW. I'm not sure who does his photoetch but it's over there on your side of the Atlantic.
First I want to thank Mtaylor and aviaamator for their suggestions: I'm now still looking on the Italian market of photoetching companies but may be your suggestions will become useful if I'll not find an opportunity in my country.
I was inspired for my copper plates solution to Mikhail Bezverkhniy's "Rivoli" and Alex Baranov's "Cumberland", here below an image of the "Rivoli" copper (?) sheating
post-1168-0-23926400-1436186940_thumb.jpg post-1168-0-09721200-1436187016_thumb.jpg
Sunday, July 5, 2015
Still nothing new, except that I progressed the design of the shipboats. In this message I intend to post the plans of the "intermediate" ship boat, which should be installed over the main deck inside the larger one.
In the first image the basic design, obtained by tracing the ANCRE plan with some adjustments where they seemed necessary.
01 Brick%20de%2024%20Plans/v1.0.0.ScialuppaMediaDisegno1_zpsyspa5kvw.jpg
y4m4tHut56BvMPTtIh20GK78Zm6Ktr8Bh8LfiMWj
Then follows the side shapes. .
02 Brick%20de%2024%20Plans/v1.1.0.ScialuppaMediaDisegnoLato_zpsl6kfomk1.jpg
y4myQxZxdAeaW1PXAG-tidSkE_x05YLa91_Nlkm6
The profile of the keel. .
03 Brick%20de%2024%20Plans/v1.1.0.ScialuppaMediaDisegnoChiglia_zpsxe94dntj.jpg
y4mbSUZnaxt5iIrRV2k6vpo4M1xlUHVMj7llkgf1
The bulkheads from amidships to bow. .
04 Brick%20de%2024%20Plans/v1.1.0.ScialuppaMediaDisegnoPrua_zps5iyjtesq.jpg
y4mP-5u1oBJZ6UL3p4xaNoytsmzw8zvGE1mrW-xo
And the bulkheads  from amidships aft. .
05 Brick%20de%2024%20Plans/v1.1.0.ScialuppaMediaDisegnoPoppa_zps4xrw13wd.jpg
y4m06wDo0PHiRh-dymM08LuTQbvvZAtszTT7y0r7
06 Brick%20de%2024%20Plans/v1.1.0.ScialuppaMediaDisegnoPoppa2_zpsexak99kc.jpg
y4m23W-wSY-ExdaIRTbQsymJAlGf4gPRTM6juqbS
The images you see here are not to scale because the forum software resizes them in its own way, but you can download them by clicking on the image and then proceed to its download at 1:1 size.
Sincerely, Jack.Aubrey
Hi JA
how are you going with this terrible heat? :o  Have you some A/C?
As far as I know, Eduard is a commercial brand producing lot of after-market photoeached sheets for most kit model companies, mainly plastic. I don't think they are available for customized production in small quantities.
Probably you will be more lucky with Dafi's producer, that I don't know if it is a homemade maker or industrial
Have a nice evening
Fam
Joint building:
Works in progress:
Completed models:
I'm trying to survive although it's very difficult . . :cheers: Regarding shipmodeling I'm idle, waiting for better weather conditions.
As far as I know, Eduard is a commercial brand producing lot of after-market photoeached sheets for most kit model companies, mainly plastic. I don't think they are available for customized production in small quantities. Probably you will be more lucky with Dafi's producer, that I don't know if it is a homemade maker or industrial
I visited Eduard website and I found something like more 100 pages of photo etched details, mainly for aircrafts and grey ships. Nothing about period ship models. Anyway I'll try to contact them to understand if they can arrange customized productions. I'm also waiting for answers from some italian companies. How do you plan to arrange the copper plating on your model ? Are you available for a joint venture, provided I'll find a supplier ?
Rgds, Jack.
Hi Jack
it depends on the price... I mean, I already have a reliable method with the sticky copper tape and honestly I am more concerned about finding the carronade barrels than about the copper sheating.
Just let me know, I will consider and give you an answer any way.
BTW
I've got three guns barrels from TheLumberyard, they are quite good quality and correct size, but I'm not sure about blackening, will see how it works or what I can do as an alternative.
Cheers
Fam
Edited by Fam
Joint building:
Works in progress:
Completed models:
. . honestly I am more concerned about finding the carronade barrels than about the copper sheating . .
Hi Fam, it's a matter of points of view.
Personally I prefer to take care of something useful to me tomorrow, like the copper plates, than something that will probably need me, considering my slowness in this hobby, within one o more years.
A house is built starting from the basis, not from the roof . .
Cheers, Jack.
Friday, July 10th, 2015
After a long break due to family problems and, last but not least, thanks the hot weather of these last days where I live, finally yesterday and today I was able to resume activities on the model.
Being for now suspended any task on the brick hull, waiting for news regarding the copper plates, I started the construction of one of the three lifeboats carried by this ship.
In recent days I spent enough time designing plans with AutoCAD and now in theory the three boats are ready to be built. The design method is the same for all, then, to avoid that an error is reflected on all the three projects, I decided to start to build only one for now. Later, if the method will work, I will start the other two, otherwise I will have to correct something before proceeding further.
The choice is obviously fallen on the largest boat: being larger it should be easier to work with. .
The first image shows all the pieces cut and finished, after I glued the AutoCAD printouts on a birch plywood, 5 layers, 2mm. thickness. The metric scale in the background should give a idea of the size of this boat: about 16-17cm.
Shown below is the mounting basement, consisting of a plywood tablet on which has been glued a boat plant. On the centerline is a strip of 5x5mm. intended to keep the bulkheads capsized but aligned.
01 Brick%20by%20JackAubrey/20150709_185229_zpsgbqkmzvn.jpg
y4m0YGv7hVoyfdfaEp2Mjbv_gck3NzECCfq_STET
After removing the paper from all the cutout pieces, I started the actual installation just glueing all the bulkheads. The alignment is obtained with the 5x5 strip on the base. So far everything seems to work well. With a special tool of adequate size, I made me sure to glue the frames perfectly vertical with respect to the base. So far, so good.
The next two images show the work at this point of the installation.
02 Brick%20by%20JackAubrey/20150710_105949_zpsgmkqv3ay.jpg
y4mG4hRumJluqkZTQvpge4vzG6zAzE18JA-5E8Dj
03 Brick%20by%20JackAubrey/20150710_105940_zpsa0kprqd1.jpg
y4mEsn4_z-ZTVLNpXwnQJkg2og4PwGVKp3ufrPZO
The work is still in progress, see you soon, Jack.Aubrey.
Jack,
I don't know a company in Italiy. But do you know "Saemann" It's a German company and they will do PE parts cor customers.
Regards Christian
Jack,
yes, it's the company. If they speak English I don't know.
If not, I would be pleased to help you because my German is much better than my English :D
Regards Christian
