HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Just had a quick catchup and look through. She is looking beautiful. I am about to restart my endeavour. Just about finished off the Victory. posting pics soon. Mike
Today I fitted the heart and collar for the main preventer stay on the foremast.
I have started making cleats, pretty fiddly because they are so small and I need about twenty four of them
Current Build: HMB Endeavour 1:51 (Eaglemoss part work)
Previous Builds: USS Constitution (Revell plastic) HMS Victory 1:96 (Corel) HMB Endeavour 1:60 (AL)
Hi Steve,
Love the heart and collar, looks great.
How are the 2 ends loops secured to each around the mast?
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Some more "arty" pics
HiSteve,
your Endeavour lookd great,
very nice Fitting out Details, choise of Colors and rigging so far to be seen...
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Steve, can you please tell me what size you used for your anchor and where did you get it from?
cheers Mike
Hello Steve your model is exstremely well done,neat ,coloring is awesome,I'm about ready to plank mine. Thanks for the excellent pictures,they will be a great help.Edwin
cheers Mike
Hi Mike
I made the anchor myself out of brass, I need two bower anchors and have since found that Caldercraft have them at the right size so I bought the second one. I won't be using the stock supplied with the Caldercraft one though, its totally wrong. Here's some pics of the first one unpainted, and compared to the ones supplied with the partwork.
Cheers
Steve
Wow, that is amazing work. I am going to try and find a suitable anchor from caldercraft or similar. I havn't got the tools or equipment to do what you did. Brilliant job!
Thanks, thats the one for me then. I can attack it with my files to thin it where needed. I can live with it being 1mm out.
hi Steve, how did you get the destinctive slight bend in the bowsprit?
Hi Mike
I soaked the wood in hot water then made a simple jig with nails in a block of wood to keep it bent until it dried. I'm not sure now whether the bowsprit was actually curved or the curvature shown on the draughts is just the taper, the AOTS shows it as being curved so I did it like that. Its only a slight curve but it really is noticeable.
I just saw your comments on Banyan's log. I didn't use the wood supplied by Eaglemoss, you're right its too thick. I went to Bunnings and bought some dowel the correct diameter.
Steve
Edited by shipaholic
hi Steve, I have a question - all my rigging references for ships of the Endeavour period shows an open heart for the collars for the stays that rig to the bowsprit (fore stay and preventer) and the AOTS doesn't show what kind of set up ....
I'm now kicking myself as it makes sense, but I can't find an image of it. The replica has closed hearts! Too late for me now anyway.
Greg
Yes Greg I did the same, I used closed hearts on mine because the replica has them. I posted a good photo of the replica bowsprit on Mikes log. I discovered the reason for open hearts when I was researching it for Mike.
Steve
