Congratulations. Very nice.
Always can be done better, always can be done more!
My builds:
          1.  75 mm Boat  - Master Korabel;
          2.  95 mm Boat  - Master Korabel;
          3.  Double boat  - Master Korabel;
Take good care of her. She's a gem.
Bob
"Even while the storm raged at it's worst, my ship was wholesome and noble." - Captain Joshua Slocum
Current Builds:
L'Hermione 1780 - 1:89 - Artesania Latina   http://modelshipworld.com/index.php/topic/10261-hermione-la-fayette-1780-by-bobstrake-artesania-latina-scale-189/#entry305929<p>
Louise - 1:26 - Constructo  http://modelshipworld.com/index.php/topic/11855-louise-by-bobstrake-constructo-scale-126/?p=360370
Completed Builds:
Carmen 1850 - 1:80 - Constructo - First Build   http://modelshipworld.com/index.php/topic/10398-carmen-1850-by-bobstrake-constructo-scale-180/#entry31137
really nice looking model. A friend of mine built one a few years ago & put a steam engine & R/C gear in her, just a thought!?
a fine looking ship!........very nice detail  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Beautiful model! Very well done! Congratulations!
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
What a great!! looking boat..... beautiful job....... this is the shortest build log I've seen here... 4 pages..... an amazing build.....
You are real good!!! :D :D
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Hello Rod,
congratulation for your marvellous work!
If you want to add a final touch, you can eventually add the radio wires, as in the photo attached.
The Anteo was probably inspired to a series of tugs built in 1935-1937 that belong to the "Porto" (harbour) series.
below the drawing of the Porto Ercole and the photo of the Porto Sdobba and Porto Torres.
in all can be seen the radio wires arrangement.
but probably I arrived a bit late... :)
    Done:          Venetian Polacre http://modelshipworld.com/index.php?/topic/7290-venetian-polacre-by-cristiano-sec-xviii-from-original-drawings/
                              Halifax  http://modelshipworld.com/index.php?/gallery/album/844-halifax/
                              Ranger  https://modelshipworld.com/gallery/album/2175-ranger-revenue-cutter-by-corel/
                              HM Bark Endeavour (Corel kit heavily kitbashed) : http://modelshipworld.com/index.php?/gallery/album/125-hmbark-endeavour-corel-kit-bashed/
                             Venetian Galleon (from scratch) - Pirate Junk - Sicilian Speronara (from scratch)
On the shelf (still packed):     Artesania Le Hussard....
Wow Rod, beautiful tug.... I haven't been on here for awhile and had to check in on this log - excellent to say the least! Thanks also for the winch plan - I will do an adaptation of it on the Sanson Tug I am working on. (slowly, but that's how I roll)
  • 4 years later...
On 6/28/2015 at 4:49 AM, rvchima said:
4 Water Inlets
Any tug boat experts out there? Why would you have 4 huge water inlets on the deck of a tug boat? I sure don't know, but these were fun to make anyway. The bodies are PVC tube and the tops are laser cut ply. The brass hand wheels were rough but I chucked them in my rotary tool and smoothed them with 400 grit wet sandpaper. They screw into little posts made out of a dowel - the same dowel as the mast. Those posts were hard to drill, center, and align, but I got them right after three tries. The kit includes hundreds of little brass hinge posts that are glued into holes that you drill. I was a little apprehensive of them at first, but they work very well. In fact the lids on these water inlets were fully operable until I glued them into place. I figured that I'd never open them and they'd be dangling loose in 10 years.
this are hydrolic control for the winch and kaapstander.
so it can turn left and right by the wheel.
greetings old sailor P. Smit . ;)
  • 5 months later...
Hi Rod
I’m just starting this model myself and have been inspired by your progress reports.  A question, might it be possible to put a small gyroscope in the ship to maintain stability while on the water
I'm afraid that I don't know anything about powered boats. My model is strictly for display.
Somewhere else on MSW I posted that some of the planking on the Anteo cracked with changes in humidity. A little disappointing for a display model, but you would probably have use glass fiber over an operating model.
Rod
It wouldn't hurt on a display model either but is pretty much required on an RC ship of any kind made from wood. The periods of being outdoors and direct exposure to water combined to being placed on the shelf in a relatively warm home environment make for drastic expansion and contraction of the wood medium unless coated and protected.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
  • 7 months later...
Hi, I have made first layer. Pva glue and brass nails. Second layer, how did you made this ?? Did you water the planks before gluing ?? Using CA in dot and pva on the edges ….. or ??
Hi, building one myself - first layer done. How are you building the second layer; are you using water to  wet planks, CA in dots and pva on the edges ???
