P_Budzik
Contact Methods
  • Website URL
    http://paulbudzik.com/contact.html
  • Gender
    Not Telling
  • Location
    California
1,520 profile views
  1. This should give you a little more complete "picture"
  2. As a dentist who has spent a half century using rotary hand tools, I have my preferences. But here are my reviews of other hobby alternatives ... I hope this gave you a little more information. Paul
  3. Here is a fairly complete discussion about depth of field for photographing scale models and there is a step by step instruction for using HelioFocus for focus stacking ... https://www.youtube.com/watch?v=yXOsZVbclPI
  4. This is multipart video build log backdating the 1/72 Revell PT 579/589 kit to PT 489. Paul
  5. He covers a number of scenarios as well as soldering to white metal. https://www.youtube.com/watch?v=oTL6VLHNW1U&t=0s https://youtu.be/oTL6VLHNW1U
  6. Having grown up with film and large format, I can understand the nostalgia and romance. But especially for images destined for the net, I think a good dslr or mirrorless is more than adequate. For focus stacking, I like Heliofocus over Photoshop. The final image from Heliofocus can be easily squared up in Photoshop The last segment of this video shows the automated features of Heliofocus ... https://youtu.be/yXOsZVbclPI Paul
  7. Hubac: Thank you Wefalck: I don't build any more primer than I would normally, but you do need to have a light touch. Just do a little practice, but honestly, it really turns out to be very easy and fast. You also need to do a little playing around with how fine a point you put on your scribe. Paul
  8. The technique that I have been using for a fine scribed line is to scribe though the final finish layer into the underlying primer. These two scratch built aircraft were done using this technique: I describe the technique in this video: https://www.youtube.com/watch?v=vRnKEwsQSaQ
  9. This video will give you a good explanation of how to get the smoothest finish possible. These are the tools used by all the model production companies to achieve those great finishes.
  10. This may give you a few more operating tips ...
  11. In the past I've always used just Unimat, both the SL and Unimat 3. The old 3 with a cast bed and ways is far superior to the SL. I now only use a pair of 3's and an SL head mounted on a home made mill. I wouldn't recommend going with an older machine that is no longer manufactured because of the limited availability of parts and accessories. Last year I bought a Proxon 250 because I wanted something a little bigger. It is a terrific machine. You get an actual geared power feed and real compound. Gears are metal and the machine is made in Germany. It bears a striking similarity to my Unimat construction. I called the company and was told that one of the design team came from Unimat. It is a beautiful little machine. It would be my current first choice for a small lathe. Paul
  12. I had a long history with Floquil. It was the only hobby paint I used. Awhile back I put up a web page just about Floquil. I have a PDF of the original "little red book" that Floquil published explaining their paint and how to use it. I also have the original railroad color chart up as well. The web page is here: http://paulbudzik.com/tools-techniques/floquil-paint/floquil-paint.html
  13. The twisted wire method has always worked well for me.
  14. Here is my solution for adding direct readout to my Unimat 3's ... but the same idea can be applied to other miniature lathes ...
