Everything posted by TBlack
Michael, After all the help you gave me on my Vinal Haven build, I’m a huge fan of yours. Any post you make (ships, railroads, masons, etc.) I follow with great interest. Tom
- 2,207 replies
“The material is fixed into place using a method I learned from model railroaders. I mixed up a solution of 50/50 water/PVA with a couple of drops of surfactant to break surface tension. I use a dishwasher rinse agent for this, but windshield washer fluid works great also – or even liquid soap. sounds like you have to be a bit of a chemist to pull this off!
As I’ve mentioned before, Toni’s explanations are complete and easy to follow. But there’s more: she has also instructed us in the correct terms for the various parts. Thank you, Toni!
- 80 replies
- rigging/masts
- NRG
How did you manage to cut that slot so beautifully? And to respond to this comment: "It felt like every time I put something down on the workbench I had to search for half an hour to find it again. It wasn't as if the bench was particularly untidy, I just seemed to be in the habit of hiding what I wanted under the thing I had just put down." Don't beat yourself up too badly; I do that all the time, except the something is usually in plain sight! Tom
Bro, If it's any comfort, your older brother is on the waiting list at the local "home" Tom
Keith, you’re doing great. Keep plowing ahead! Eye sight is an issue, but how about shaky hands?
Much better. On the Vanguard website you can see a picture of them. Tom
- 95 replies
- flirt
- vanguard models
Walter, You are doing a magnificent job on this ship! You and I have the older version of blocks from Chris. If you look at your #72 post, that’s what they are supposed to look like. Shopping at Chris’s site and Chuck Passaro’s site shows that decent blocks are out of stock. So, we are out of luck. I might try knocking off the corners. I’ll let you know how I do. Tom
- 95 replies
- flirt
- vanguard models
Keith, are you happy with your cooking, or are you relieved that you now have help? Tom
What Keith said is spot on. I find getting those wedge pieces just right a horrible task. Tom
Various spars/yards shaped. Next is to add hardware and paint. I'm going to join several others that thought the PE fittings for the stun'sl booms didn't look right But on closer inspection it turns out that they're perfect.
- 341 replies
- Sophie
- Vanguard Models
Those are the buntlines. If you were to add a sail to the yard, the line (knotted end) would be attached to the sail. Tom
- 95 replies
- flirt
- vanguard models
