usedtosail
Everything posted by usedtosail
  1. I finished cutting out and cleaning up the bulwark supports and sanded the inside planks above the frames. To remove the excess wood along the stem and stern posts, I first used a pointed grinding bit in the Dremel tool to hollow out the pieces, then a chisel and knife to clean out the rest of the wood. Of course once the support was gone the plank ends were unsupported, so I cleaned up the ends with an X-Acto saw blade then inserted small strips of wood to close the gaps. I used thin CA glue to hold them all together, then a riffler file to file the wood strips down. The inside planks will hide these wood strips, but I will have to use wood filler on the outside to cover them up. I could now start the interior planking. After some planning on how to attack this, I started by gluing plank strips along the top of the bulwarks in the middle of each side. I then temporarily clamped the plank below so it extended out past each end, which gave me the angle of the top bow and stern planks. I cut planks to fit and glued them in place. As you can see these planks do not go all the way to the stem or stern post, as that would need a very severe edge bend. Instead I am cutting them off where they intersect the top of the bulwarks with a more gentle bend. This will allow the second row of planks to fit flush to this top row. For all of you who celebrate, have a happy Easter.
  2. Nice job on the quarter gallery bases and the stern windows. Those are two very tricky areas to deal with.
  3. I gave the outside hull a course sanding for now. I give it a final sanding later when I am ready to apply the paint. There are still some areas that need some filling but not much. I then started removing the bulwark supports on the inside of the hull, which needs to be down before the second layer of planking can be applied there. I am using a thin X-Acto saw to cut them. I had tacked the first layer of planking to these so they break off fairly easily after they are cut. Once they are all removed, I need to file the cut areas down to make a continuous curve from the central areas of the frames. I also have to remove some wood along the stem and stern posts. Then I can add the second layer from the sheer down to these frames.
  4. Thanks guys. I just spent about a half hour filling some of the larger cracks with wood glue, then sanding over them to fill them with saw dust. It really worked great, as they virtually disappeared. I know I have tried this in the past with poorer results so I don't know what i am doing different now, but what a difference. More pics after I get the whole outer hull sanded and looking pretty.
  5. A small milestone - second planking is on. I will give it a good scraping/sanding before planking the inside bulwarks.
  6. Thanks Popeye. Almost done with the port side planking now. Two rows left to put on, then a bunch of sanding.
  7. I love the Coke delivery truck Popeye. Looks so cool.
  8. Thanks Stevinne, Rich, Popeye, Jonathan, Todd, Capt Steve, K, Dan and the likes. As for heirloom, I hope one of my kids wants this once I am dead and gone. I wouldn't blame them if they didn't, but hopefully they will find a good home for it. Let's hope that won't be a problem for many, many years. K - keep up the great work on your Connie. You are doing a great job on it and your build log is excellent too. Dan - I really enjoyed your articles in the NRG Journal on building QA's Revenge. Your are as talented a writer as you are a modeler. A couple of last pictures that I took last night after dark. I was really curious how the LEDs would look and I was very happy with the result. We started calling this the Museum Room last night.
  9. Thanks Fernando and EJ. Almost done with the starboard side and about half way on the port side. I will be happy to move on to the next phase.
  10. Thanks everyone. Well, now I can say this project is really finished. Here she is in her new home. I am really happy the way the case turned out. My full size woodworking skills leave a lot to be desired, but this project I tried to be a lot more precise. One thing I did over the last few days was to remake the cradle. I had originally made it a few years ago using 3/16" walnut for the supports. In all the moving they suffered a few dings and breaks that looked terrible, so I took them off the base board and remade them in 1/4" walnut. I am much happier with the result. That's it for this project. Thank you all who have followed along through the journey. I have certainly learned a lot and I much appreciate those of you who built this model before me so I could learn from your experiences. I also hope this build log will prove useful for those who build this model in the future. I would highly recommend the experience. Just make sure you have a big enough place to put it when finished.
  11. When I got close to the keel on the starboard side, I started planking down from the keel, so that I could use a shutter plank underneath the hull. This will be whatever width I need to fill the last gap, so I want it to be less noticeable. I am also planking both sides now. The port side is about half way there. On the starboard side I have now got to the point where I need to add two planks to finish the planking. I decided to use two planks that are slightly wider than the 6mm planks I have been using, as tis way there won't be one plank that is a lot bigger than the others. I cut a long strip 8mm wide from the 1mm sheet you see in the photos, and used it to create the last two planks in the middle of the hull. Here is the first one being glued in place. This morning I added the other one, so now I need to add the bow and stern planks in the gap, then tackle the planks at the sheer.
  12. Here is the top almost completed. I made the back frame a little wider than the other frames so I had room to add the LED strip. It has an adhesive backing that stuck to the top very well. I created a groove in the back of the case for the wire to fit into, so when I add the top it will go over the wire. There is a control box that dims the lights and turns them on and off, which will hang down in the back of the case along one side. Adding the top to the sides is the next step.
  13. Thanks for the likes. K - the plexiglas panels are just loose in the channels, no adhesive. Once the panels are set on edge the Plexi doesn't seem to want to move. I suppose if it got breezy in the room they might rattle, but I have made previous cases like this and have not noticed that. The front panel and top panel will just be secured with screws, so I can put the ship in from the front, then screw the front and top in place. The top needs to come off so I can lift the ship high enough to set it on the cradle in the case. I could have secured the cradle to the ship but I like being able to separate them.
  14. I have assembled the top, back, and sides. I used brass screws to hold the half lap joints together after gluing them. They came out sturdier and squarer than I anticipated. I then nailed the back and sides to the display board and each other. I am assembling the case on the table that the case will sit on when done, so I don't have to move it later. I am now in the process of making the top.
  15. I used a Cognac stain on the frame pieces for the front, back, and side panels, and the display board. It has a nice reddish color that matches the table I will be putting the case on. I also put two coats of Tung Oil Finish on these pieces when the stain dried. I have started assembling the side and back panels and should have them attached to the display board in a few days.
  16. I haven't had an update for a couple of weeks but I have been continuing to add planks to one side. I started with a few middle planks then started adding the bow and stern planks from them. I am leaving the top few bow and stern planks until later as these will have to be spieled and probably dropped to fit the space. I was able to use clothes pins as clamps but now I am mostly using the screw clamps, with holes drilled into the first planking strips. I also use medium CA interspersed with wood glue on the middle planks that don't need to bend too much and hold them with my fingers for just a minute.
  17. That was fast work David. I have a different Chris Craft kit I'll probably be building next, so I am looking forward to following along with your build.
  18. I have been spending most of my shop time building the case for the Constitution, but I have done a bit more work on the Santa Lucia. I finished the first sanding of the first planking and added filler in some low spots. This morning I sanded those down with medium grit sandpaper so it is now ready for the second planking. For the second planking the kit provides 1mm by 6mm wood strips. I am going to use 20' scale length planks that at 1/30 scale come out to 8" long. I can use full width planks in the middle of the hull then taper them towards the bow and stern. I'll use a 3 butt shift for the plank ends. Here are a few planks that show what it might look like. I need to figure out the widths and the tapering needed before I can start laying these down.
