Everything posted by usedtosail
Vossie, if you make the breach lines from a longer length of line, you can thread the line through the ring bolt and seize it to itself with a seizing that you can slide into position, at the same time adjusting the length of the breach line. I used this technique many times for seizings on the Constitution that I had to do in place.
- 714 replies
- lady nelson
- victory models
Thanks Gerty. Your Willie Bennett looks really nice.
- 1,348 replies
- constitution
- model shipways
So this is a supplement to the build log which is a build log of the case for this beast. I was going to wait until Spring to build this, so that I could run the table saw outside, but I managed to arrange the shop so that I can make the case inside and still have room for the table saw. I ordered the plexiglas panels for the four sides and the top back in December. These are 1/8" thick. I will be making frames for the front, back, sides and top panel, but first I worked on the display board. This needs to be 24" wide, so I could have made it up from a few wide boards, but at Lowes I found this made up board that is already 24" wide. I started by adding the guide boards that the front, back and side panels will be attached to at the bottom. These are just 1x2 poplar boards that I split down the middle. I used a battery powered nail gun to attach them to the display board, which I have to say I was pretty impressed with. The nail heads are very small and not very noticeable. I will also be using a pretty dark stain for the case which will make them even less noticeable. With the base done, I then started making the front and back panels. I stared with these because if I screw up any of the frames I can cut them down for the sides. First I cut all the frame boards to length. Those blue panels behind the bench are the plexiglas panels. I had a pretty crappy old small Craftsman table saw that I knew wouldn't be up to this task, so while at Lowes to get the wood I was going to buy a small portable table saw that looked pretty good. Right next to that one they had this Hitachi portable saw that was much beefier and precise. It was originally about twice what I was going to pay for the smaller one, but it was marked down to only about $30 more than the smaller one, so after a bit of thought in the store I bought it. I am really happy with it. I had that small shop vac that is perfect to stick underneath it, but the hose was too small for the fitting on the saw. After searching online there was no adapter that would work, even though there were a bunch that claim to but when you look at the dimensions the outside diameters were too large to fit in the hole. So I chucked a square piece of 1x4 into my lathe and made one, which works great. I also bought a switch that you plug the saw and the vacuum into so that the vacuum goes on automatically whenever the saw starts up. So far that is also working great but there is some question on the longevity of these switches, so we will see how long it lasts. I can also use this set up with my other power tools, like the router table. I am in the process of cutting lap joints into the ends of all the frame boards for the front and back. Once that is done, I will then use a router table to cut the slots in the boards for the plexiglas panels to fit into, then assemble the frames around the plexi. Stay tuned for pictures of that step next.
- 1,348 replies
- constitution
- model shipways
I have completed the first sanding of the first planking, both with rough and medium grade sandpaper. There are a few spots that need a bit more filler, so that is the next step.
- 131 replies
- santa lucia
- panart
Been there, done that Rich. It is a wonderful feeling when it all set back up just the way you like it.
- 1,135 replies
- model shipways
- syren
Thanks Popeye. That is good advice which I will use on the second planking.
- 131 replies
- santa lucia
- panart
Here is where it gets a bit ugly, as I can not for the life of me do a good planking job without clinker planks and gaps. So the first step is to add wood filler on those area that need it, which in my case is much of the hull. Here is another hack that I have been doing. Even though I cut a rabbet at the bow and stern posts, the first planking strips were too thick to be bent enough to fit into it completely, so I just got the ends close while planking, knowing I could use wood filler to get them to curve into the posts better than trying to bend them. So first I used a Dremel with a sanding disk to roughly sand down the plank ends. Then I filled in the gaps with the wood filler. Today I used a flat scraper to scrape down the filler along the posts but don't have a picture of that yet. Stay tuned and the next post will hopefully have a better looking hull as I continue to sand and scrape it down.
- 131 replies
- santa lucia
- panart
Welcome to all those that are now following along. I have spent the last week or so trying to get the last couple of planks right, especially at the bow. I wanted to make sure I had a nice curve from the first frame into the keel. I ended up removing that section a few times and finally was able to make a nice spieled piece that fit well after I curved it with a planking iron. Here are some pics of that process. And the results. So now the first planking is on and I am ready to start getting it smooth for the second planking, which I will show in the next post.
- 131 replies
- santa lucia
- panart
She is beautiful Dave. Try to keep the dust off her though.
- 742 replies
- constitution
- frigate
As promised here are the photos of the drop planks in place. (I have another photo but it doesn't want to upload). You can see I will be adding another drop plank at the top planks. You can also see a spot where the clamps I used forced a plank to bend in too far. I will add some filler there to fix it after the initial sanding of the first planking layer. Here I have soaked the next top plank and clamped it to the frames. I am using a keel clamp to hold the hull when it is right side up. I still have to put in the drop planks at the top and I also have to make and add two spieled planks at the bow, as a single plank all the way across at the very top can't be bent enough to fit right.
- 131 replies
- santa lucia
- panart
Thanks Fernando and for the likes. I am getting close to finishing the first planking. I have the bottom band done, which did not require any dropped or added planks. The middle band is almost done, but there are 4 drop planks to be added, one on each side at the bow and stern. Here you can see how I am doing the drop planks. I am finishing two planks on a frame with 45 degree angles, then filling the remaining gap with a single plank the goes to the bow or stern. Normally I would surround a single dropped plank with two full length planks, going from 3 planks to 2 planks, but to do that on this model the two planks would have to be made from very wide stock. Even with the method used here I had to make two of the single planks from wider stock than the 6mm wide planks supplied with the kit, but they are short pieces so I didn't need much. I have made those single planks and was able to soak them and clamp them to the hull to shape them. I though I might need to use heat with them after soaking because of their length, but that was not needed. I'll add pictures of the completed drop planks in a future post. As you can see I haven't done any scraping or sanding to the hull yet. Once I have the top planks glued on then I will be cleaning everything up in preparation for the second planking.
- 131 replies
- santa lucia
- panart
Cutty Sark by NenadM
usedtosail replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Congratulations on getting your daughter onto her independent life. Both mine are on there own now and I am so proud, but still miss them a bunch.- 4,152 replies
- cutty sark
- tehnodidakta
Thanks Popeye and the likes. Planking is coming along as I am down to just a few planks left in each band. I am going to drop a few planks near the stem and stern in the middle and top bands as the remaining gaps are pretty small there. As usual I am using a variety of different clamps, but as the gaps get smaller the choices get more limited.
- 131 replies
- santa lucia
- panart
Thanks Anthony. I am just glad this model will have a second planking. This one is just the base. Here is a nice planking process picture. I have a plank in the middle band clamped after soaking to get it to shape, another in the bottom band drying after being glued to the keel and frames, and in the background there are two wood strips that have the frame positions marked on them ready to be trimmed for the top band. The supplied wood strips for the first planking are 1.5mm thick and 6 mm wide, and I have found that they only require soaking for a couple of hours and can be manipulated very well after that. I have not had to resort to any kind of heating for these strips. Those clothes pins between the frames reduce most of the clinkering since they clamp the wet plank to the previous one. For the top planks I have flipped the frame over so I can work from the top. You can start to see the shape of the hull coming out. Just more of the same for a while...
- 131 replies
- santa lucia
- panart
Great job on that ladder Dave. A jig of some kind is an absolute must when building them.
- 742 replies
- constitution
- frigate
Thanks Fernando. Its good to know that will work.
- 131 replies
- santa lucia
- panart
Thanks Fernando, Popeye, and EJ. Fernando, I am a bit concerned about the planks that make up the outside of the bulwarks. Did you glue these to the parts of the frames that are to be cut away? I am leaning in that direction and then will clean then up inside when I remove those sections. I guess the second planking will help hold these together but just edge gluing them seems too flimsy to me.
- 131 replies
- santa lucia
- panart
