Thank you Lukas, the only reason I could do such a kit bash on this model was that I had the superb works by Jean Boudriot to refer to - The Seventy four gun ship. I also bought both the Heller kits Le Superbe, and Le Glorieux and used bits from both of them. I'm not quite sure which wooden beam structures on the Upper Hull you are referring to, can you elaborate? As for tips I'm not sure where I could start, but I am happy to answer any questions you may have on your build. Regards, B.E.
- 126 replies
- le superbe
- heller
I like the approach you are taking with your build, and those repacement tackle blocks on the carronades look so much better. Oversize blocks are one fitting that immediately catch my eye, and I can't live with them either. I've not come across a kit yet that supplies correctly scaled blocks. Cheers, B.E.
- 732 replies
- constitution
- model shipways
Cheers Mark, trouble is the whole log runs for 196 pages with 550 photos, I think it would have become a life's work re-posting it. B.E.
- 126 replies
- le superbe
- heller
Hi Jason that looks excellent, I used a small bulldog clip along the bottom of the keel/rudder to hold the rudder firm whilst I worked on it, fitting the tiller etc; Do the Jotika instructions include any reference to the fitting of rudder chains/pendants? they would usually connect to what is called a spectacle plate fixed just below the hancing on the rudder. B.E.
- 800 replies
- snake
- caldercraft
Hi Frank I think you've really nailed the look of a hard worked vessel and I think you have got the colouring/weathering of the sails just fine. I like the look of her. B.E.
- 389 replies
- supply
- caldercraft
Hello Ian, it may be that swivels were not fitted in that location, do you have a particular class of Frigate in mind. The usual indication of a swivel gun is the stock into which it fitted. there were usually more stocks than swivel guns carried. The only contemporary model with a beakhead bulkhead I have seen with swivel stocks is of a sixth rate 24 gun ship cica 1740. this had stocks for swivels on the foc'sle (two each side) the foremost one aft of the cathead. B.E.
Hi Mike, one of the reasons is that sanding sometimes smears the caulking whereas scraping does not; I always scrape decks. I use an old plane blade out of bullnose plane, but hobby knife chisel blades are good for tight areas. Generally I use the widest blade I can to cover the deck area to reduce the possibility of digging into the deck. Cheers, B.E.
Cheers Steve, I'm glad you like it. The Heller Le Superbe/Glorieux are the only game in town if a medium sized plastic Seventy -four model is wanted. At least it can be fully rigged and displayed without the where are you going to put that ! comment from the Domestic Goddess B.E.
- 126 replies
- le superbe
- heller
Are there any lines that go in front of the sail?
Blue Ensign replied to Modeler12's topic in Masting, rigging and sails
Hi Jay, the leech lines also come across the front of the sail. Don't know if it will be of any help to you but this is a sail rigging plan I prepared when building my heller Seventy-four. This is the fore sail, not as fully detailed as the topsails as it was eventually clewed up. B.E. -
Hi Jason, that's an interesting question. The authentic way varied depending on the purpose of the block, but for attaching to an eyebolt the strop of the block would be seized to the eyebolt, but at model scale this can produce a too heavy look in my opinion. At the scales I usually work at my approach has been to produce a knot as small and neat as possible, and without much regard to authenticity. I have taken the view that an unobtrusive knot is better than an over scale authentic one. On Pegasus I resolved to do better but I have only really rigged the tiller lines so far and I used a false splice method originally explained by Gil Middleton in his Victory build, and also used by Dafi, he did a post on it in the masting and rigging section. Apart from the jeer blocks most of the rigging blocks on Pegasus are of 2mm or 3mm size quite small to replicate the strop and seizing in a truly authentic way without the line overpowering the block. As we have lost all the previous discussion items on the subject, I too would be interested to see how others have tackled the isue, particularly at 1:64 scale. Cheers, B.E.
Thank you Augie for your kind words, the log wasn't there to be aware of until last week as it wasn't on the old MSW. I posted it here from my original forum to bulk up the depleted content on new MSW and add to the range of kits covered. I also repeated my current Pegasus build which I will continue to update now in 'real time' Cheers, B.E
- 87 replies
- pickle
- caldercraft
Hi Augie, I seem to have missed your log the first time around, a fine looking kit and a fine looking build. Nice work. B.E.
- 1,668 replies
- syren
- model shipways
Thank you all so much for your uplifting comments, I'm glad so many fellow ship modellers have found my build enjoyable and informative. It has made my effort in repeating the log on MSW worthwhile. Regards, B.E.
- 87 replies
- pickle
- caldercraft
A magnificent build Gil that I followed on the old MSW. I am pleased to see it back. Your Victory is an inspiration to all builders and I have benefitted greatly from your approach to various aspects of the build. Your false splice is one that comes to mind. Regards, B.E.
- 755 replies
- finished
- caldercraft
Splendid work Jan, I love the sheer lines on that model. B.E.
- 139 replies
- corel
- prins willem
What a fascinating build Foremast, I love the quality of your deck planking and use of hooded planks around the margins. What reference did you use for your decking plan or did you devise it yourself? I don't think I've seen that method of caulking before, looks very scary, but the result is great. Regards, B.E.
Furled , unfurled or no sails -Preference
Blue Ensign replied to Canada Steve's topic in Masting, rigging and sails
I'm rather with Greg on this one, and prefer the bare stick look on stand displayed models, and there is a great precedence for this with contemporary models of the eighteenth century. A ship in harbour for any length of time would have the sails taken down so it's not inconsistent to display a model 'bare stick' The problem with kit provided sails is that the material is mostly way over scale and lacks the detail that sails should properly have such as the reinforced areas. Out of scale stitching and poor reef points can further detract from the overall look. On the other hand fitting sails does allow the modeller to show the function of the running rigging and I do like to see sails on waterline models in a diorama setting, but that's the only situation I would personally fit them. In the end tho' it's all down to personal preference and what individual modellers like. B.E. -
Coloring Basswood
Blue Ensign replied to JPett's topic in Painting, finishing and weathering products and techniques
Hi JP that effect don't look too bad, I tend to stay away from stains on softwoods because of the uneven finish due to differences in the grain texture. I prefer to use water based varnishes which I can alter in shade by adding water based paints. I find it is not always necessary to use a sanding sealer with varnish, and two or three coats rubbed down inbetween give a fairly even finish. Clear or medium oak varnishes are my particular choice with adde ochre where I want to replicate say a boxwood finish. Cheers, B.E. -
Blocks fitted under the mast's top
Blue Ensign replied to dancat's topic in Masting, rigging and sails
Sounds like you could do with a good book on masting and rigging,what ship are you modelling? One on line reference you may find of use is this. http://hnsa.org/doc/steel/index.htm This is the contemporary work by Steel on the subject of masting and rigging, which is the basis of most of the modern works on the subject. Cheers, B.E. -
Hi Dancat, The blocks you refer to are the lead blocks for the Buntlines and Leechlines. The configuration can vary slightly from ship to ship but there were usually two pair each side one pair forward and one pair to the rear. The strops of these blocks passed thro' holes in the top and were secured by toggles. B.E. -
This is an important and wonderful build Gary, and I'm glad to see it back. Regards, B.E.
It's great to see this pretty little cutter again, marvellous work at only 1:96 scale. Although mourning the loss of all the real time logs, in a funny sort of way it's nice to see a clear run of construction photos from frame to ready for masting. Thanks John, nice to see her again. B.E.
Continuing... She will now take her place in the Dining Room to compliment the Naval cutter model that I bashed quite some time ago. They are a good match I think, and more importantly have the full approval of Mrs W Specific reference works I have used during this build I list here. The Naval Cutter Alert - Peter Goodwin (Conway AotS series) The Global schooner - KH Mardquardt The Colonial Schooner - H. Hahn. Rigging Fore and Aft Craft - Lennarth Petersson News of Nelson John Lapenotiere's race from Trafalgar to London - Derek Allen and Peter Hore My thanks to all who have made such supportive comments on this log which I hope will provide a useful reference to those contemplating the build. Regards, B.E.
- 87 replies
- pickle
- caldercraft
Completion Photos This post concludes my log of a nine month build. More to follow B.E.
- 87 replies
- pickle
- caldercraft
The Ensign Staff and Ensign. The Ensign was printed on Modelspan tissue. The advantage of this method is that the exact required size of flag can be obtained with on the model trialling until a size that pleases the eye is found. A disadvantage of the method more specifically to the White Ensign is that the white background which of course is the basic paper colour does not show to the same advantage as the Red and Blue Ensigns. To address the problem I coated the modelspan with diluted white water based paint before printing the flag and then painted over the Union colours using again water based paints. I find that Chisel edged brushes are the best type to use for this action. The modelspan is only coated on one side prior to printing because I found that coating both sides didn’t allow the printer ink to penetrate sufficiently thro’ to the other side. Fixed to the flagstaff the ensign was then subjected to a little steam and was teased into shape using rods of differing thicknesses to hold the flag in a drooping attitude. Matt varnish was then sprayed onto the flag to hold it in position, very light coats are required lest the colours run. The same method was used for the Union Flag at the Jackstaff; the staff itself was made from micro bore brass tubing with a styrene truck, thro’ which holes were drilled to take the Halyard. When I set the Union flag on the jackstaff I hadn't noticed that it was upside down, but fortunately my friend Pete Coleman on his forum where this log was originally posted pointed this out and saved me from further embarrassment. Flying the ensign upside down is a distress signal. The matter was rectified. A brass fret strip was used to make the tabernacle and the assembly was fixed to the aft face of the bowsprit cap using ca. B.E
- 87 replies
- pickle
- caldercraft
