Landlubber Mike
Everything posted by Landlubber Mike
  1. Mkmossop, I did the Flemish coils for my gun rigging on my Badger using the technique of coiling the line around a pin on top of painters tape, but thought they looked a little too neat. For the remaining coils, I decided to have coils that looked more like yours. What I did was again use painters tape, this time wrapping the line around a pin, putting diluted PVA on the line, and in one motion, pull the pin and put another piece of painters tape on top -- essentially, as you pull the pin the line loosens and gets messy, but by putting the second piece of painters tape on top, you help freeze the coil in position. I then wait a while for the glue to dry, remove the tape and you have your coil. Now, the coils come out randomly that way, and some you'll end up throwing out, but to me I preferred the result to the Flemish coils.
  2. Very nice work Nils - love your detail work on this model
  3. Ha! I can take some if you want -- my wife might let me come back on this board though
  4. You're right Spyglass - I looked at the plans and the stern does drop a bit. I must have mis-measured a while back.
  5. Haven't cut the holes for the rods. You're right that they would have been a lot easier to fit before adding the bulkheads, but I think I should be able to manage. I needed to order the pedestals, plus, I wanted to get a little further along in figuring out where the stern will end up in order to properly center/position the pedestals. Wish me luck
  6. I received my set of pedestals in the mail recently, so I'm going to fix nuts inside the keel rather than use the wood screws that come with the kit. i had a question though - in looking at the kit plans and plans for other similar ships, it looks like the keel is relatively parallel to the waterline. Is that typical? The Badger's keel dropped lower as you approached the stern, so I used a taller pedestal for the fore area and a shorter pedestal in the aft area. Given that the keel seems to be more parallel, It looks like I'll need to use pedestals that are the same height. It looks like from Spyglass' Pegasus pictures that he used pedestals of a similar height, so it's very likely that the Pegasus keel is parallel to the waterline as well. Second question - I plan on using boxwood for the decks. Should I use boxwood for the false lower deck? It seems like I could get away using different wood given that the lower deck will be mostly covered with gratings and the ladder for the companionways (and I might cover the waist with small boats), but I figured I would ask. I haven't yet made a decision on whether to build the model as the Unicorn or the Lyme. I ordered the Lyme plans from the NMM, so once I see the transom and other decorations, I can figure out which looks nicer, and probably more importantly, which I am more likely to successfully pull off From what I can tell looking at the Chapman plans against the NMM Lyme online plans, aside from the beakhead versus rounded bow, and some minor cosmetic things like railings and numbers of portholes, the ships are pretty much identical.
  7. I made a little more progress the last few days, installing the remainder of the first 15 bulkheads. Unlike the Badger where I pretty much glued them all to the keel in probably the span of an hour, I took my time on the Unicorn as there was more play with the keel that I cut, and I didn't appreciate the importance of squaring things with the Badger So, I glued one bulkhead at a time, using squares, levels, etc., and letting the glue dry at least an hour before moving on. Probably a little on the cautious side, but I figured it's more important to get it right and square. Since I plan to frame the stern, I won't be using bulkhead 17, at least where the kit would have you add it. The kit has you add it to the very end of the stern, and then attach the cast metal stern to it. Instead, I'm going to sit bulkhead 17 right up against the after face of bulkhead 16, and cut notches into it to seat the stern frame extensions. This should work well because bulkhead 17 is the lateral width of the stern (not including the transom), so by seating the outer extensions into the two sides of the bulkhead, I should be able to frame the end of the ship for both the transom and the planking for the sides of the ship. Here are some pictures, including some with the false lower deck and upper deck dry fitted. Despite the plans being all over the place and not consistent with the kit parts, the kits parts fit very well together. Next I plan to add some bulkhead supports to maintain the squareness of the bulkheads, especially since the plywood used for the bulkheads is a bit on the flexible side.
  8. Thanks Ian for that info. Interestingly, I came up with a height of 30mm between the two decks as well but by the lazy way in readjusting items on the Corel plans to fit Chapman and then measuring the distance. Amazing that I got as close as I did. That step up is very nice!
  9. Looks great Jason. That's also what I did on my Badger. Kester tells you how it really should be done, but I don't know that I could have done that as more and more deck details started getting in the way. One approach that Hubert recommended on his website was to connect the belayed points first, then run the lines to where they should start. That seems like a good way to avoid all the difficulties with belaying lines when the deck starts filling up, but I wonder how easy it is to attach the lines to blocks, etc. and get the proper tension. It seems like you would be just substituting one difficult task with another.
  10. Hi John, It's a bit late here, but I saw your post and wanted to respond. Are you thinking of raising the quarterdeck at the stern so that the line of the upper deck/great cabin would flow into the stern windows? I was thinking of taking a different approach outlined in the link below where the front section of the quarterdeck would be raised, and the aft end at the same level, or perhaps, slightly lowered: http://modelshipworld.com/index.php?/topic/6223-hms-unicorn-by-landlubber-mike-corel-scale-175-1748-1771/?p=202411 Here is a link to Ian's log where he sketched out a similar modification: http://modelshipworld.com/index.php?/topic/515-hms-unicorn-by-ianmajor-corel-scale-175-1748-to-1771/?p=202353 I think the difference, at least in my sketch, is that I planned on the windows being lower on the transom. I was thinking about reducing the height of the windows like you did, but rather than block out the lower section of the windows, I would just essentially cut that bottom section off and move the windows down into the blocked out section (hopefully that makes sense). The alternative would be to take Ian's approach on blocking out the top of the windows, which you can see here: http://modelshipworld.com/index.php?/topic/515-hms-unicorn-by-ianmajor-corel-scale-175-1748-to-1771/?p=205888 I hate to suggest this, but would it be easier (or at least more appropriate) to move the windows down, rather than try to reorient the quarterdeck? You would lose the band on the counter with the name of the ship, but you could always move that down as well for a 2-step counter like in your painting above?
  11. Very cool - this book seems to have been written using the same framework as Robert Gardiner's "The Sailing Frigate" that was published last year, which I really enjoyed. This book on sloops is about double the length of the frigate book Any good details for those of us building sloops, like the Swan class line of ships?
  12. Take a look at the Proxxon DB250. I used it on my Badger and really liked it. It was very well made, stable and easy to use. I sold it after getting my hands on a Sherline, but if you are planning on staying with wood turning, I don't think you can go wrong with it.
  13. Hi John, you're right that I should wait until the second planking is on. Things will be fairly flimsy until then. I'll probably pre-cut the bulkhead uprights to make removal easier. I'm a little torn as to whether to color the bulwarks or not. A lot of the models in the NMM have red painted bulwarks, which I think looks very nice. I have a couple of stains from General Finishes that look pretty nice on walnut - I believe they are Cinnamon and Empire Red. On the other hand, I'm hoping to have as few colors as possible - right now I'm looking at pear, ebonized pear, and boxwood, so red would be a fourth color to add to the mix. Another option I've considered is using walnut for the carriages and deck items, and oiling it. I kinda like the look of darker deck items (like the hatch coamings) against a lighter deck. One thing I'm really hoping to avoid is scratching the gun carriages out of a new wood just for consistency sake - so, I'd probably want the deck items and/or inner bulwark planking to be consistent with whatever I did for gun carriages. That's a really nice picture. The way the stern looks, it could very well be the Unicorn with those windows
  14. Hi Ian, I agree with you on what seems to be a big safety issue. That's one thing that has always made things unsettled for me regarding Chapman's plans and the raised quarterdeck. I couldn't find any other ships that had open portholes like Chapman's Unicorn. And ships that did have a raised quarterdeck either had solid bulwarks or a rail. As a result, I thought there might be a bit of detail missing from his plans - kinda like how the two Lyme plans differ in what details are shown.
  15. Do the Chapman plans show the mizzen below the rail? Looking at the link below, I can see where that is the case on the upper ship plans, but not on the Unicorn plans below. Not that Corel has it right or anything, but Corel has solid bulwarks around the portholes I thought? Looking at the Lyme plans, however, I see what you mean by the mizzen extending below the top rail. That's a very cool look, as you can see more of the details from the profile like the capstan. Interestingly, it also looks like the second of the profile plans shows what might be posts for the swivel guns. Looking at the second of the profile plans, it looks like the portholes have vertical frames to either side to support them - for a minute there, I thought they must have discovered levitation back then Supporting the portholes with vertical frames should make it much easier to add the portholes - I was a bit nervous as to drilling holes of the proper orientation into the bulwarks to cleanly fit the portholes. Thanks for the picture of the Lowestoft. It's one of my favorite models on the NMM site. I love the way the railing looks! Hmm, maybe this is all telling me to go with the Lyme? How do I go about changing the title of my build log?
  16. Ian, thanks for the pic on the lateen rigging of the mizzen. I remember you mentioning this a while back, but this picture is very helpful. John, feel free to borrow away if there is anything that works. That's what's been great about these forums. Frankly, I think I would still be working on my Badger and less far along the learning curve if MSW and all my friends here weren't around I think you've diagnosed maybe what is a subconscious desire to procrastinate on the build. I feel like I've done so much planning and thinking the past few months will little to show for it. Last night felt really good in actually moving the build along. Kester, thanks very much for the kind words. I'm glad you enjoy reading my log. Sometimes I feel like I am a bit wordy and with a tendency to point out issues and questions, rather than posting progress with pictures to make the log interesting Hopefully now that a lot of the planning and structural issues are mostly resolved, I can starting making some progress.
  17. Hi Ian, thanks for the thoughts. A collateral benefit of going the Lyme route and having a unique build is that my build won't be compared to the gorgeous Unicorn builds out there I did see that about the external differences. The rails might be slightly different, with the ends of the railings on the Unicorn slightly more decorative. Interestingly, it looks like big middle stern gallery window might pop up onto the quarterdeck, or end just at it. Also, in the two profile plans, the second has what looks like two portholes in the transom, whereas the first plan, from the transom decoration, doesn't look like it would accommodate two portfolios. On the plans below, do you know what the rail looking thing is that extends above the transom in the stern view? It looks like railings, but I think the bulwark sides of the quarterdeck are solid given that the portholes are shown.
  18. The beakhead is probably the only reason that I'd stick with the Unicorn. Unfortunately, the "Lyme Class" only consisted of two members - the Lyme and the Unicorn. The design was successful however, and there were a number of close descendants of the class, including the Guadaloupe and the Pandora. You can probably build any of those ships off the Corel kit with relatively few modifications.
  19. Hi Jason, Going with the replacement is a good idea. I know some people are able to use the soaking and weighting technique, but I would be very nervous that the keel would have a tendency to warp over time. If you pay good money for a kit, the least you should expect is a flat keel in my opinion. Glad to hear that Caldercraft is standing by their product. Interesting on the by air versus by sea results. On my Unicorn, I bought a couple of sheets of plywood from Micro Mark to cut out a new keel. Both the sheets, even at 5mm, were significantly warped, worse than the kit keel. I then bought a package of 5 sheets from Hobbylinc (maybe Revell brand, I forget), and 3 of the 5 had a decent sized warp to them, and really only one was workable. MDF might be a better way to go.
  20. Thanks Ian. So far everything is working out nicely, but before I get too excited, I have to see how well I pull this all off I posted this on my Pegasus log, but I thought I would post it here as well to get your thoughts and thoughts from others that have been following my Unicorn log. Recently, I've been strongly considering building this kit as the Lyme, rather than the Unicorn. There are a few reasons for this: (1) the stern and galleries would be much easier to execute from scratch I think, and in my opinion, look nicer than that of the Unicorn; (2) the figureheads would take about the same amount of carving and skill, and (3) the quarterdeck bulwarks would be easier to execute with the full portholes, and again, would probably look nicer than the Unicorn. There are some minor differences like the railings, but I think the main consideration is whether I want to build a ship with a beakhead bulkhead (the Unicorn), or go with a rounded bow like the Lyme. I think the beakhead is a cool feature, but I'm not wedded to it as the stern transom and galleries, and the figurehead, are all more interesting to look at. Just curious what you and others think on this change of plans. I still have a little time to think about it, but probably need to come to a decision before the first planking so that I can frame out the rounded bow if I went the Lyme route.
  21. Ian - with the amount of crisp detail on the plans, I might look into buying the Lyme plans. Since I'm pretty much scratch building most of the Unicorn anyway, recently I've been considering converting the Unicorn to the Lyme as: (1) the stern and galleries would be much easier to execute from scratch I think - and in my opinion, look nicer than that of the Unicorn; (2) the figureheads would take about the same amount of carving work and skill; and (3) the quarterdeck bulwarks would be easier to execute with the full portholes, and again would probably look nicer than the Unicorn. There are some minor differences like the railings, but I think the main consideration is whether I want to build a ship with a beakhead bulkhead (the Unicorn), or go with the rounded bow like the Lyme. I think the beakhead is a cool feature, but I'm not wedded to it. If you had the choice, what would you do?
  22. B.E., thanks very much for the recommendation on the plans. They are gorgeous like you say. I'll probably frame mine as well after my build is completed, so if the model stinks, at least I'll have nice artwork that people can look at I'll have to take a closer look at the stern carvings. I remember reading about your concerns over the Norman knights. The figurehead to me looks really wild - I might have to start practicing carving now, so that in a few years, I can carve something similar. Alistair, the plans are really fantastic. I'm not sure what they are printed on, but it's sort of a laminated paper so they are very sturdy. As B.E. notes, they are of nice decorative quality as well and can be displayed as artwork -- although, take my opinion for what you paid for it as my sense of what is "art" isn't all that great I remember seeing someone post the Fly plans on here, and they looked to be just as good as the Pegasus plans.
  23. A little present arrived in the mail today - plans of the Pegasus from the NMM! The plans are really gorgeous and show a lot of detail. I know some people had some issues ordering plans from there, but my transaction went very smoothly. Interestingly, the stern figures as well as the figurehead are quite different than the kit. Not sure what that means for my build, but the figurehead looks pretty wild relative to the kit figurehead. Don't mind my toes in the first picture
