Everything posted by cobra1951
Nice work Robin I could do with some stain the same colour as the Hennessy for my Endeavour
- 473 replies
- greek bireme
- dusek
HI EJ I could stain it but i have found in the past that the wood does not glue as good as non stained wood. I have replaced wood in the past and almost doubled the price of the kit i was building, and not having a good supplier near me you end up replacing the replacement wood because you cannot tell what you are getting
I liked the use of the different colour woods to represent the striping on Victory they work well together and allow the use of stain to let the natural beauty of the grain to show
- 708 replies
- victory
- constructo
Thanks John . Seem to be good kits, materials are good and so are the instructions. The only little gripe i have is that they use Lime wood instead of Walnut and tell you to paint it to look like Walnut, but as the Occre kits are fairly cheap compared to some others then it's to be expected that they are saving money to keep the cost down
Hi Paul How are you finding the quality of the instructions and materials with Constructo kits
- 708 replies
- victory
- constructo
The keel and bulkheads on this kit are only 4mm thick and after fitting the deck, the joints were a little bit flimsy, so i fitted some strengthening pieces to the joints Lower deck planked and cross beams for the next deck fitted There was no reason to plank this deck at all as none of it will be seen later, so i used some thinner planking and saved the kit supplied planking in case i need it later in the build
Thanks for all the comments and likes, greatly appreciated All Bulkheads glued into place All seems to line up length ways too Used the straight edge on half the lower deck and marked it out for planking Lined up the other half of the deck against it by sticking them down together with double sided tape and then transfered the markings across Carefully removed the two halves from the double sided tape then laid a strip of planks along one edge then fitted and glued both halves to the keel and bulkheads When it's all dried, deck planking will begin Planks have been cut to 100mm in length and will be laid in a 5 butt system in a 13524 pattern
Plumb line. Basically a length of string or rope with a weight on the end, you hang it up and it has no option but to hang in a perfect vertical line
- 701 replies
- phantom
- model shipways
Nice bit of delicate work completed well done
- 701 replies
- phantom
- model shipways
Looking good time to extra care when handling her now
- 214 replies
- agamemnon
- caldercraft
