cobra1951
Everything posted by cobra1951
  1. That HobbyZone stuff is quite good stuff for the price of it. I have few of their things myself
  2. Hi Ian The bluff bow certainly makes the planking a bit easier as the amount needed to taper planks is shorter because the bend in them starts a lot further toward the bow
  3. Thanks John Sanding is my least favourite part of a build but one of the most important, so i do my best to get it right
  4. Great job But can I survive for 3 or 4 weeks
  5. This is the time in a build when you need a trained Octopus
  6. Plus from what i have read in your log the Dusek kit is supplied with better woods
  7. You have done the planking with the same method i use, to me it looks great nice neat joints without looking overcrowded with them
  8. Hi Don Those new little additions you have created look awesome
  9. You will have a nice solid framework to support you planking when your done
  10. Hehe Carl Make sure the heating is on as it gets a bit drafty down in the bilge area
  11. Thanks Don It took a day and half but i cut down the work involved by using the same method i used to fair the frames on my defunct Bounty. Get a belt and using double sided tape stick some sandpaper to it, you can then wrap the belt round the bow and along the edges of the hull and just pull it backwards and forwards. Altering the pressure either side as needed keeps it all even
  12. Thanks Per Yep, waiting made me more in the mood to get on with it once they arrived
  13. Received my replacement bow filler blocks yesterday As you can see the replacements are quite a bit bigger than the supplied ones Fitted them in place and shape the bluff bow
  14. My own builds can sit around for ages without getting anything done, but when i get interested in someone else's build i can't wait
  15. That's a good reason not to rush a build An hour here and there has it's upsides Your fore top is very neat indeed
  16. I hung my hammocks on the 2 hooks furthest away from the cannon tools and i made the ropes a bit longer so they hung lower away from the gun port rigging. That way i was able to leave them all in the open position as the look better to me open and they did not foul the tools
