Everything posted by clearway
Polaris by JDillon - OcCre
clearway replied to JDillon's topic in - Kit build logs for subjects built from 1801 - 1850
there is also a company called Always Hobbies (hobbies.co.uk) which sells various types of stripwood/ metal and Caldercraft fittings - it is where i got the walnut strip for my Terror build. Chris has mentioned Cornwall Model Boats and they are my main go to for a lot of things shippy Keith -
evening/ morning/ afternoon depending where you are😁, have finished making a pedestal for the azimuth compass, when looking at various pics i saw one on a brass tripod stand and thought that will do nice, Took Craigs idea and mounted the legs on an inverted box which sits over the post. Also made a new bridge with stanchions spaced closer and not with one down the centreline. Take care all Keith
Thanks Keith, was just thinking that could have been the last view anyone from the western world would of seen of her and Erebus- gets you thinking. Keith
Thanks for looking in, persistant rain today led to shipyard time. Back in more certain domain with the main sail sheets and tacks rigged before i finally glue the table and azimuth post in place (still need coiled though). Also fitted blackened brass rod to emulate supports for the bridge (might scrap this one and remake without a stanchion in the middle and others re spaced to suit). I read a bit about the wreck where the divers found a small stove in the sickbay in the bows with the flue sticking up through the foredeck and all the bulkheads removed, but suspect this was an impromptu addition so wont include it. Another thing to get sorted before i glue in the table etc is the vent for the safety valves Keith S mentioned in his last post on his log. Take care all Keith
Nice to see you back with her Keith, i agree with you regards the pipe as having seen/travelled behind many steam locomotives the safety valves are built into the boiler and most definitely blow off large quantities of steam when the pressure builds up, so a large diameter pipe would be needed to clear it safely. Beginning to think it might have been an idea to have held back doing all that rigging in the waist of my build with all the mods i have been doing recently! Keith
- 206 replies
Thanks for the link Craig, anyways there is an Azimuth compass going on the post 😁. As regards the bridge will stick with the plans and add iron supports either side of the centreline made from brass rod blackened and most likely on the bridge wings leading to the outer bulwarks or capping rail. Keith
as a guide for the plating i used the kit supplied veneer and ran it diagonally downwards towards the bows (there is a pic somewhere early in the logs) which as you needed to shape them to fit the bows it gave a guide for trimming the plates but start at the top and you will get a feel of the run Keith
No problem Keith we all been there😜. if you look at photos of shackletons endurance the bridge was between the main and foremast while the wheel was still at the stern, They set up 3 or four foot long pointer on a post which was basically telling the helmsman which way to steer to avoid the growlers and bergs. Back with terror and i have now got Azimuth compass mark 2. Take care all Keith
That is why i think the navigator on the bridge will get his bearing on the Azimuth and when the helmsman is on course the navigator will shout "mark" and he can use that bearing as a guide with the azimuth being consulted on a regular basis. Found this online regards Polar steering:- 3321. Magnetic Compass The magnetic compass directive force depends upon the horizontal intensity of the magnetic field of the earth. As the magnetic poles are approached, the opposing force on the compass card becomes progressively weaker until at some point the magnetic compass becomes useless as a direction-measuring device. In a marginal area it is good practice to keep the magnetic compass under almost constant scrutiny, as it will be somewhat erratic in dependability and its errors may change rapidly. Frequent compass checks by celestial observation or any other method available are wise precautions. A log of compass comparisons and observations is useful in predicting future reliability. Keith
Thanks Craig, i have heard they would set the azimuth using a celestial body / geographical feature and keep her true using that bearing. Keith
Don't forget Keith the Azimuth compass on the post came into play when they got towards the pole and normal compasses were as much use as a chocolate fireguard! So the azimuth would be used to set the course with the navigator correcting the helmsman till he was steering true. As for the "normal" compasses i think one like what keith S and i were talking about a year or so ago would have been mounted either on a binnacle in front of the helmsman or more likely on top of the skylight. Craig i think you could be on the right lines as on the Owen drawings there is no obvious sign of it sticking that far out. Keith
thanks for the likes and comments everyone. Now i have the compass post in place i thought i would try making an impression of the Azimuth steering compass (best i can do in 1/75) measures 4mm square and still need to sort a lid and a stand. Also trial fitted the bridge on the lowered supports.... to carry on my original dilemma before we sorted the compass post i still cant decide whether to go with the full width bridge off the plans or shorten it slightly (as we now know some unrecorded changes were made on the final refit)? psssst Keith notice i now have camber on the skid beam 😁. Take care all Keith
Yey we both have it at last Keith! Jeez nearly two years we were waiting m8.... woooosh! Keith
- 206 replies
Thought your log needed brought into our Terror group hug Keith😁 Keith
- 206 replies
To be honest Hake you dont have to go as in depth as Keith S and myself to create a better model, even just reorganising the fife rails around the foremast, moving the massey pump supports and replacing the mizzen mast fife rail with a spider band + of course adding the deck houses will bring her into a league of her own. Whichever way you steer as always just ask us fellow Terrorites😁. Keith
Thanks again guys, couple of shots showing the new navigating table/post and lower skid beams (when viewed from astern and compared tothe stern elevation in Matthews book the old height mistake stood out like a sore thumb)! Take care everyone, and if you have a bank holiday today enjoy. Keith
Coming along Daniel, yep can get a bit daunting when you see exactly how many fittings are on a yard (at least the topgallant doesnt have any battens in the middle and less blocks)! If following Keith S and myself with the azimuth compass post through the table and the confounded bridge i would get the base for the post sorted but still leave the bridge supports off once made to ease access to the mainmast pin rails (main reason you see the funnel and capstan missing from when i was rigging there). Keith
Coming along nicely Phil..... feel myself twitching at thoughts of making bridges😁. Keith
Thanks for likes, comments/ hints /tips / suggestions, measurements everyone, have re made the table and re used the old legs, while in redux mode i removed the port side stern deckhouse so i could panel the doors to match the starboard side (was thinking should i remove the forward facing door and move it to beside the other door but thought na i like it)! While doing that i tackled another job that needed remedial work which is the skid beams were around 5 mm too high, so removed the posts and skid beams and moved the knees to their new height.... i was going to move the post back but thought best not as i super glued the brackets in and will probably rip the capping rail off😱 (sometimes best not to push your luck). In the pic you will see the new table beside the old table top for comparison. Take care all Keith
I can vouch Keith it is repaired as i was on the 10.58 train from Carlisle (diesel unit though unfortunately) which crossed it before pulling into the station, it is still single track though (in fact every time i go to the steam railway at Keighley {actually pronounced Keithlee} you have to go over it😁.... bloody fantastic)! Keith
yeah, problem with Cutty Sark is she was altered in one way or another with rig changed and deck house alterations etc. Back to terror and i am thinking that navigation table is too big on the model so will salvage my carved walnut legs and rebuild it slightly smaller. Today i had a day off work so took my son down to Ribblehead to see the Yorkshire three peaks and the magnificent hand built Victorian viaduct (been over it loads of times but never got off at the station to have a look from below.. till today😁). the pics really dont do it justice! 20220826_125715[1].mp4 Take care all Keith
Yeah Craig.... Keith S and myself have been saying for two years if only they had panned this way or that way! some of the Juicy detail we need is soooooooooooo close (hey Keith have you organised a dive down to the engine room yet)! It was interesting in my last update when reading the stuff about Cutty Sarks compasses in the link about compasses from Keith B how her Azimuth compass was also between the skid beams. was not 100% about the post but in the end i got my (wait for it).........bearings! Keith
