Everything posted by clearway
there is also www.model-dockyard.com based in u.k. but do overseas mail order as well as cornwall model boats.
- 47 replies
- victory
- billing boats
coming along nicely there jesse- nice work. Keith
- 607 replies
- scottish maid
- artesania latina
You should be able to order wood strip from either your local model shop or many of the online model shops. I ordered the extra wood for the wales from my local model shop. Keith
- 47 replies
- victory
- billing boats
strakes= planks, wales are the thicker bands going along the hull and stealers are infill planks. Keith P.S. also read plank on frame models volume 1 by harold underhill
- 47 replies
- victory
- billing boats
also you will need to taper the planks at the bow and most of the stern, as boyd says you can also use stealers- check my log there are shots of bow and stern and a shot of the hull upside down to give you an idea. Took me a couple of weeks tp plank mine. Keith
- 47 replies
- victory
- billing boats
Nice job there,i used the copper tape method for my cutty sark (5mm wide x 15mm length) and ran the top two "runs" parallel to the water line- took something like 3000 tiles to do all the hull- it is the billings 1/75 version. Vowed i would never do it again, but here i am having just ordered 60 metres of tape for my Victory! Keith
Not much advance over the weekend due to nice weather and gardening taking priority! Got the overlays for the prow, keel and sternpost in place, fine sanded the upper hull and opened out the "un-lidded" gunports. Next job is to attatch the wales when the timber on order with local model shop arrives. Will leave final shaping of upper hull till as late as possible as i dont want to weaken the bulwarks on the quater deck too much. Keith
seeing this brings back memories from 17 years ago! I bought my cutty back in 1997 and the packaging for the fittings is a different style so may be 1970's vintage. Mine was just die cut as well- adds to the fun. Are you going to alter the unrealistic anchor deck?- see my post in finished kit built gallery. Keith
- 151 replies
- cutty sark
- billing boats
looking great there, wish i had invested in the caldercraft victory instead of the billings one now! Keith
- 439 replies
- victory
- caldercraft
I find it can take upto 2-3 years to fully finish a ship of this size depending on how many hours a day you can put in. My billings cutty sark took about 3 years (with large gaps due to other models and family commitments) but i also altered and added a lot of alternate or scratchbuilt fittings. Keith
- 413 replies
i purchased the billings cutty sark in 1996 and that still had die pressed ply and seperate fittings, but i bought the st. roch a little later and that was laser cut with fittings included. The kits do take a bit of work and refinement but do lend themselves to improvement/ alteration easier than some other manufacturers. keith
over the bank holiday managed to get the gunports cut to approx size (will be opened out fully later) ,got the gun carriages made and started sanding the hull. even though i'm modelling the lids closed i couldn't resist! will paint them matt white then stain and varnish them. primary rough sanding completed- will use fine grade from now. P.V.A'd all the hull below gunport level to help bind the planking together- this did lead to fun when sanding back though! Keith
looking good m8- also if you only varnish one side you may warp the hull- best do both sides at same time. keith
- 413 replies
the india ink method is messy but worth it especially if you coat the thread with beeswax afterwards. i used an old plastic tub to soak the thread then hung it outside to dry- then spent two hours scrubbing my hands- gloves recommended! Keith
- 104 replies
- victory
- billing boats
thats looking great m8. will take a while to sort but will be worth it in the end. Keith
- 413 replies
new planking fitted around the transom- each strake was removed one at a time and the new one trimmed to fit. thats most of the brass pins removed- will leave the ones in the new stern planking till the glue has had plenty of time to cure. Templates made for marking out the gunports- used the ones on the laser cut ply sheets for measurements. Keith
