Posts posted by Dimitris71
Hello shipmates, Frank-Mike-David B-Don-Patrick-Jeff-Bob-Lawrence-Edwin-Greg , thank you very much for your kind comments. Really appreciate it!! :D
Waister-Slog-Nils-Nigel and Brian , thank you for stopping by and for your likes.
So the 160 portholes came today from rb-models . I drilled 154 holes on a piece of balsa and put them inside, then i put 1 coat of Vallejo primer...Tomorrow i will painting them white...
Cheers
Dimitris- UpstateNY, thomaslambo, riverboat and 10 others
- 13
Sorry Max, I can't help you with that, due my luck of experience. But in my eyes the red line looks right.
Cheers
Dimitris
Hello again, Jeff and Rik thank you for the very kind comments and for your likes.
Brian-Simon-Patrick-Nigel-Slog-Nigel(NMBROOK)-David thank you all for pushing the like button.
Edwin welcome back to my build log and thank you for all the likes...Nice to hear from you again!! :)
A small update to my build. Almost all the furnitures and pin racks are installed to the bow deck. The stanchions and hand rails painted black..
Kind Regards
Dimitris
Excellent work on the cannons and deck Rik. The wooden mast ring is very nice..
Kind regards
Dimitris
- riksgewijs, Elijah and mtaylor
- 3
Hi Dimitris,
Thanks for your appreciation,
I noted that you had ordered portholes from RB for your AV, I used to Mount RB portholes with flanges as well before...., how is your experience with those, I remember that it was not so easy to fit the "glassings" in, in order that they stay there and do`nt fall out, resp. into the hull afterwards
Nils
I decided to use rb's portholes because i didn't really like the ones included in the AV. Actually i did not find it that hard to install them. Note that I usually paint the portholes first. As soon as the color dries I place the glassing using tweezers and then press it gently with my finger so as to fit in. Lastly i install them on the hull. I hope you'll find it helpful. Feel free to ask anything you might need.
Cheers
Dimitris
- Omega1234, Piet, Mirabell61 and 1 other
- 4
Hi Nils, the color on the dummy section above looks very nice. As far as the tamiya masking tape is concered, i agree with dirk that it is by far the best one...
Kind Regards
Dimitris
- Omega1234, Mirabell61, Piet and 1 other
- 4
She is looking great Mike.. Awsome job on the treenails!!
Cheers
Dimitris
- mikegerber, mtaylor, Omega1234 and 1 other
- 4
Hi Slog,you have done amazing and detailed work on your build. She is wonderful. Looking forward to seeing more!!
Cheers
Dimitris
Hello shipmates, David B-Patrick--Jeff-Nigel (NMBROOK) ,I appreciate your kind words of support .
Nils-Brian-Don-Nigel I do thank you for your visits to my build log and also for your likes.
I was thinking how to simulate the black plates under the eyepins that are placed throughout the deck. So i found these plastic pieces from packaging... I painted them black and i cut them in half . I drilled them, and then put the eyepins inside. 8 are ready, 72 to go... :angry: Also the 2 windlasses on the stern deck are in place.
Kind Regards
Dimitris
- thomaslambo, canoe21, mikegerber and 8 others
- 11
Great and precision work as always Nils!!
Cheers
Dimitris
- Mirabell61, Omega1234 and mtaylor
- 3
Hello shipmates, Lawrence-Brian-Nigel-Mike-Patrick-David-Nigel, I do thank you, for all the likes and comments. The first thing i did ...Fixed my lamp... lol
So.. an update regarding the stanchions and hand rails on the stern deck, I cut the handrails as instructions point, this is the point that the big lifeboat hangs out. After cutting them off, applied one coat of primer and then i painted them white with a brush. Also i have ordered last week the 152 portholes from rb models ...and waiting!
Kind Regards
Dimitris
- Omega1234, Mirabell61, thomaslambo and 5 others
- 8
Hello to all, Simon welcome aboard. David-Mike-Slog-Patrick-Don-Brian-Nigel (UpstateNY)-Jeff-Nigel (NMBROOK)-Bob, I do thank you for all the likes and for your visits to my build log.
So...work on the shipyard continues..The lamp with the magniffying lens above my head explode...And the first thing I thought, after the proper language.. Oh darn !!! the ship... I check the construction and everything it's ok!!
Here are some pictures with the progress of Amerigo... The instructions shows how to make these lines with a pencil..I did not like it ..so i made this.. Then glue the furnitures on the stern deck, then the radar and then I start to place the stanchions and handrails to the stern's cap rail (i hope that this is a term). Sorry about the quality of photos but as i said above the lamp is out..
Kind Regards
Dimitris
- thomaslambo, mikegerber, NMBROOK and 7 others
- 10
- NMBROOK, Mirabell61, SimonV and 8 others
- 11
Hi Dimitris
Darn, she's looking absolutely brilliant! Heaps of details. Lots to look at.
Nicely done!
Cheers
Patrick
Thank you very much mate!!! Really really appreciate it!!
Cheers
Dimitris
- Omega1234 and mikegerber
- 2
I have never used that brand how is it to work with?
David B
When i use it with an airbrush it needs thining with the 71.361 thinner (model air series). On the other hand, the model color series is made for brushes and there is no need to use thinner(distilled water)..It is very easy to use .. This my first time painting so many items with a brush and i'm quite happy about it. Note that these are acrylic paints. They have a very good result without having to breathe dangerous chemicals (I have two kids at home) . The vallejo Primer comes in three colors i think, Grey , black and white (see my post here No 86). Also the Vallejo Premium Series has a fantastic matt varnish, code 62.062. This varnish is also used for protecting helmets against scratches.The bluenose was my first kit, i painted it 6-7 times before I came to understand how the airbrush works ,you know...lol , the thining, pressure and distance,overspray etc... :angry:. I truly hope you'll find this info helpful..
Cheers
Dimitris
Your model is really looking good keep going. What is the color of the paint you are using?
David B
Hello David, for the gold ? Or the brand ? The brand is Vallejo model air for the airbrush and Vallejo model color for the brushes.If you need anything else let me know!!
Regards
Dimitris
HMS Victory by Heinz746 - Caldercraft
Posted · Edited by Dimitris71
Hello Heinz, just came through your build log, ι had never thought until now to build the victory. Now I think about it seriously. Your work is outstanding , clean and precise. I think that the choice not to use colors or copper is excellent.My build is all painted as the real Vespucci is . Now for one more time I say that you have great skills doing such a beautiful work. I like the choice of different wood also....I will definitely follow along!!
All the best
Dimitris
