Everything posted by mrcc
And here are some images of the decks with the railings installed, just recently varnished with Humbrol matt varnish. The lighting is perhaps not the best with these images...
- 179 replies
- santa maria
- mamoli
More details to report... Lots of fun adding some of the ornamentation to the ship. I believe the casting are a brass based metal, a soft, easy to bend material. I painted them with a primer and then added the acrylic paint colors according to my own instinct. The recommended color scheme by Mamoli is certainly not to my liking. I must admit that the castings are very well done and in my opinion are looking great on the ship.
- 179 replies
- santa maria
- mamoli
Thanks Popeye, Mustafa for your fine compliments... much appreciated. The stove was the kit supplied stove, unaltered and unpainted. I was debating whether to accent some of the features of the stove with paint.
- 179 replies
- santa maria
- mamoli
- 179 replies
- santa maria
- mamoli
- 179 replies
- santa maria
- mamoli
More time to post some progress... I am very happy how the smaller boats, the pinnace's came out. A few add on modifications compared to how Mamoli set them out to be built...
- 179 replies
- santa maria
- mamoli
Yes Ian, I was going to do Danish or Tung Oil but your finish with Wipe on Poly is stunning... Did you wipe or brush it on?
- 107 replies
- brazzera
- marisstella
Wow, what an amazing job Ian... Very nice! One quick question, how did you do the finish on the hull? Wipe-on Poly? It's perfect!
- 107 replies
- brazzera
- marisstella
Thanks Slideways... do not know if I would say with ease. Cheers!
- 179 replies
- santa maria
- mamoli
Another minor issue once found attaching the stern decoration is that the opening was too big too completely cover with the metal badge so I added some inside trim (would be hidden anyways) and once painted with a brass color (different from the white, blue, and red coloration scheme that Mamoli indicated), I glued it down with CA.
- 179 replies
- santa maria
- mamoli
Here's the close-up... it is offset ever so slightly to the left but not noticeable on the picture. Also I should have placed the top portion of the rudder a little closer as the pintle was not pushed in far enough onto the keel prior to the CA setting. The most obvious issue though is I sanded back too much into the keel board and into the plywood... Any suggestions in how to fix? Laminate a piece of 0.5 mm walnut strip and then sand back I guess...
- 179 replies
- santa maria
- mamoli
Thanks Popeye for the kind words... Here is how it looks... from a distance mind you , it looks good.
- 179 replies
- santa maria
- mamoli
Hi Popeye, Pintles are of a soft metal... the problem of course is the instructions did not provide the "heads up" on an earlier step with regards to tapering the stern board in advance... I found that is the common theme of the Mamoli instructions... Nonetheless with the attachment, it does not look too too bad. I will provide a photo of the finished rudder perhaps tomorrow.
- 179 replies
- santa maria
- mamoli
And here is where all the problems starts... Mamoli in the instructions says simply separate the paired rudder/hinge ends (soft metal) and push onto the hull/keel. Sounds simple until you realize the inside diameter of the hinge is about 3mm and the plywood keel it attaches to is 5mm plus the walnut strip lamination of 0.5mm on each side for a total of 6mm... From the picture below you can see my hack job of getting the rudder attached...
- 179 replies
- santa maria
- mamoli
Thanks Ian , thanks Mustafa... always a good feeling to get compliments... And Ian, yes, I have read your Victory log many times, wonderful craftsmanship! With this post, I also have some progress to report from last weekend... Notched out the voids for the rudder hinges and pins to sit and I set them with a light coat of CA, priming and painting prior of course .
- 179 replies
- santa maria
- mamoli
Thanks for all the likes and of course, Popeye, your kind comments...
- 179 replies
- santa maria
- mamoli
Last weekend I also started working on the rudder by laminating 4 5x5mm walnut pieces and then tracing and sanding/cutting out the profile. Again Mamoli was short in its supply of 5x5mm walnut and I do know that in future I will be short again in supplied wood. Oh well... once again.
- 179 replies
- santa maria
- mamoli
The ship, the kit has two cannons that are partially hidden under the fore deck. I have to give Mamoli credit with this old kit as the cast and metal kit parts are absolutely perfect in appearance. Unfortunately I have used some old Admiral flat metal black paint for the brass cannons and it was quite thick on application and the appearance is less than ideal... but again they are barely visible under the deck. I will dilute this acrylic paint with some water to get a better result in the future. I left the cast pieces unpainted as they look quite good without paint.
- 179 replies
- santa maria
- mamoli
At this point I glued down the Beechwood top railing with the finished look below. I have to yet wood fill and finish some of the outside corners as they are not looking great. I would like to blame the instructions given how vague they are and are never preparing you for the finished appearance as you go through the steps of construction.
- 179 replies
- santa maria
- mamoli
More progress to report from the weekend past... Able to get the stern railing framed out and unfortunately again with this Mamoli kit they were short in the 1x1mm supplied boxwood... I basically laminated 2 strips of the deck planking which I believe is 0.5mm Tanganyika to get my 1mm and then cut a strip of 1mm as you seen in the picture and the variation in color.
- 179 replies
- santa maria
- mamoli
Thanks Zappto for your compliments... the hull is planked with walnut, a light shade certainly. The kit supplied planking wood has been excellent in this old Mamoli kit, very tight dimensions and clean edges. My only critique is how Mamoli was cheap with the quantities of supplied wood. I have run out a few times of the required strips, making do as need be.
- 179 replies
- santa maria
- mamoli
And completed some of the stern deck railings as well... This is all work completed last weekend so hopefully I will be able to provide an update into next week again.
- 179 replies
- santa maria
- mamoli
- 179 replies
- santa maria
- mamoli
