Ronald-V
Everything posted by Ronald-V
  1. Small review: I purchased some extra wood from boardsponser "Hobbymill.eu" so I have enough other dimensions then the 4mm kit provided pear wood. It would make planking a bit easier I have different width planks. I also purchased some boxwood for the decking. My experience with the owner Vahur ( Wahka_est here on the forum ) was very positive. The guy is friendly and patient in communication. The woods I received were just perfect, I didn't have seen any more perfect cut material in my life, so nice and clean. We also exchanged some photo's of my kit material to get a sort of matching colors of the wood in the kit, so it wouldn't be to much a difference in color. That worked quite well...it's ofcourse not exactly the same color because of screen settings etc...but it is pretty close He also added some extra material of other woods so I could feel and see what he has to offer in his shop. I really appreciated this gift 👍 So this and his reasonable pricing makes it well worth to purchase some wood here Did not include photo's of all the material, but a selection
  2. Sharp eye! Didn't notice that...I wonder if it's only a way to "end" the top and butt planking prior to that drop plank. Not sure if i'm going to add that one, will think about it. I not going to install the top and butt planking, so maybe it's not really necessary to place the drop plank there. Thanks everyone for the comments and likes! Appreciate it
  3. Update: I finished all the gunport linings. I took me a bit longer then I expected, but to get it nice and clean...there needed to be used some filler here and there But i'm happy how it turned out. I painted them right away...I did use some masking tape around the edges to get a clean edge. First I used some clear varnish to seal of any gaps where the red could leak into. That worked quite well. Next step was to install the pre-lasered planks below the gunport patterns, that did go well, not really something I can say more about it. I also added two more planks that should be the base of the lasered wale patterns. I measured them (about 14mm wide) so I covered that area. Now below these planks I can begin with the real test I want to leave the hull in the natural wood color, without the white color. So the planking journey begins from here. First step would be lining off the hull, mark the lines where the joints are going to be etc. In the original planking pattern (you can find it in Blue Ensign's log of his Sphinx) there was a dropplank right under the wales. That would be a cool thing to replicate and makes the rest of the planking also easier. So I'm going to see if I can make that. That's why I found it important to allready plank the area underneath the wale patterns, so the drop plank would rest to the underside of it. Well...in theory
  4. 😔 Wish you and your family a lot of strength and beautiful moments with your 4 legged companion in this upcoming time...
  5. Perfect clean work! Just like your Essex. You are doing great with this kit
  6. Exciting! I'm almost there also...just need to finish the gunport cills...taking forever with those
  7. Yeah you can always take it a bit further when laying the first foundation of planks. The flow of the planks will reveal the spots that aren't faired enough. Especially the bow and stern were for me a point that I needed to correct. But like I said...that isn't to difficult to do it then.
  8. Exciting kit! Will be nice to see how lovely it will turn out in your capable hands
  9. Congratulations with your purchase! This will turn in a wonderfull little cutter
  10. The second layer of pear bends really nice. I think it will be easier to fit the planks. Can't wait to get to that part myself! Daunting but exciting
  11. Will be interesting to see how much difference there will be between the standard supplied blocks and the pear wood set. I have the idea that the items are so small...that I wouldn't really see the difference, but who knows
  12. Thanks for the likes and compliments! Just a small clamping tip regarding the gunport linings. Especially the lower cill was frustrating to properly clamp or push down until the glue would set, but clothespins help with pushing down the cill until it's dry. Just reverse them so they push against the upper and lower side. The side cills could be hold in place with larger tweezer clamps, but the clothespins can be used also for this.
  13. Little update here: I didn't had a lot of time to work on the Sphinx because I was renovating my garden these last few weeks, season is beginning and needed to do quite some work. But these last few days I could do here and there some work on the ship . I have glued the large pear sidepanels onto the hull. Not super difficult, but some concentration is needed to get a good fit. Especcially the lower front pieces I found the most challenging. I do have a small gap here and there between the upper and lower parts, but overall i'm happy with the fit. Those seams are going to be covered anyway so it's not really a problem. The most important thing for me was that I got all the right curves of the hull and the pieces were glued firm against the underlying patterns. I advise to have a sound clamping plan before you begin it takes away a bit of the stress when you apply the diluted pva and the pattern begins to curl a bit. So dry-fitting first helps with this. After that I sanded all the gunports flush with the inner MDF frames and began a test fit with the gunport linings. Used 0.5 pear for this and are quite happy with the first results. They are not too much in your face but distinctive enough to notice. Also the 3 ports with the lids need some extra work, because the underlying pattern didn't lay flush with the MDF inner frames. So I need to fill up or sand down here and there. It's a bit different for each gunport, a little bit of extra work...but that's part of the fun 2 done....18 more to go!
