Posts posted by sfotinos
Those moldings look great, consider me a purchaser.
Shawn
- FrankWouts, Ryland Craze, mtaylor and 1 other
4
- mtaylor, alde and GrandpaPhil
3
- JeffT and Ryland Craze
2
I’m considering setting all the “tall frames”, and then go back setting the “small frames”.
Or is it best to do the sweep port and gun port frames as I go?
Shawn
On 3/31/2024 at 3:36 PM, Chuck said:
Just a heads up for those building the kit. Jim Rogers caught a error on the labeling of parts. It is now corrected. But you will find that there are two sets of frame parts AF.....The taller set is actually AF. The shorter set is mislabeled. Those are actually 10A. Good catch Jim....thank you. The parts are actually fine. The one set is just mislabeled. So grab your parts and correct the label on the shorter set before you get that far. Label them as parts 10a.
You will find them on sheet "M" of laser cut parts. Those need to be relabeled.
Chuck
So I'm building frame 10A. I had already relabeled mine when you posted this.
I seem to however already have a set of 10A? All 4 match perfectly.
Hopefully I'm good.
Shawn- Jack12477, FrankWouts and mtaylor
3
I for the life of me cannot find any of the pieces to build frame 12a.
Could I ask someone to look at their kits and let me know which billets I should be looking for these.
Thanks in advance.Shawn
- AnobiumPunctatum, Chuck, KentM and 9 others
12
You are way ahead it sounds like, I would like to see your progress.
Shawn
One completed keel assembly.
Still needs finish applied, I may opt just to use sanding sealer. I'm not a huge fan of wipe-on poly.Everything pretty much fell together once things were tweaked just a bit.
Couple of things...- Be very careful with the knee of the head, I sneezed and broke one.
- When trimming the apron blocks, be sure to use a very sharp blade and very small slivers, as I chucked a couple
I popped the first frame out of it's sprues (and yes I think USPS played football with my box, as most everything was detached). I'm going to look like Popeye after sanding all the char off these frames.
I need to probably tackle putting the build board together before I get to far ahead of myself.
Shawn -
On 4/3/2024 at 1:15 PM, Freebird said:
Chuck,
Do you think a group build like the Winnie would be a good idea? Thoughts???
Best Regards ….Rick
Chuck are there enough participants that we can start a group build?
Shawn
Wondering if someone can answer my question.
I'm getting to the end of the keel assembly and noticed this from Chuck's log.
Notice there is gap between the upper apron.However the plans don't show this gap, mine matches the plans?
Another pic from Chuck's log.
I'm curious if I didn't this wrong or if things changed?
Any help is appreciated.
ThanksShawn
Sloop Speedwell 1752 by sfotinos - Syren Ship Model Company - 1:32 Scale - POF Sloop
So I've been stuck with the fairing of Speedwell for several months.
I cannot in my head visualize how to go about this. Should i just go for it? Seems like there is a lot of material to be removed and I don't want to over-fair.
Would I be better off installing the fore cant frames before doing this fairing?
What would you use to complete this fairing? Dremel, mouse sander, by hand with sanding blocks, or another way?
Any suggestions would be appreciated.
