Thistle17
Everything posted by Thistle17
  1. Oh the time spent on making these diminuitive parts. Have we all lost our minds? Half kidding and half serious. I do think that such dedication and craftmanship does rival some of the best works of the time. I do hope they are appreciated long after we have "pushed off shore". Great work Rusty. Joe
  2. I have been asked to restore a family's model of a fishing schooner modeled after a Maine vessel of the turn of the 20th century. I am told it was built by the builder of the original vessel. It has suffered the ravages of time and neglect. I need some recommendation of what to do with the sails. They were extremely well done perhaps the most notable execution of all elements. They do suffer from significant yellowing and environmental grime. They seem to be made of a very fine weave fabric and show no sign of rot. Can't tell if they are linen or a very fine weave cotton. Joe
  3. You would think that with all the restrictictions placed upon us of late because of the pandemic that one would have copious amounts of time to work on our Syren models. Well, for me life still gets in the way so I sit and stare at your work like a dear caught in headlights. Incredible work that inspires and motivates us all! Joe
  4. Because of the Covid restrictions ( we are approaching an Orange rating for our county, after having the best state infection rating pre Thanksgiving) our work has slowed dramactically. Yesterday just a bit more advancement with the final fit of the gun tub into the cavity forward of the pilot station. Lots of clean up and fairing left to do topsides as previously stated. Nearly the last thing to do on the gun tub is form and fit the gun carriage supports. A member of our group has volunteered to convert a tub side profile image to a measured drawing for that purpose. Joe
  5. There are plenty to choose from out there. They range in price from under $200 to $1000 or more. Most all are table top. You will want variable speed, good hold down function and chip relief so you can see where the blade is going. Most are slow start so you need to be aware of that. Then it comes to the all important blade types. There are so many that it is too much to include here but you will want to invest in good quality blades for the works you plan. These are not for thick stock cutting and do their best on thin stock. If they have a surface light that is a plus. Joe
  6. I guess I should have mentioned that the DAP product seems to sand easier and leaves no trace when one has to overcoat with either paint or finish. The manufacturer does stress that a minimal amount of adhesive is all that is necessary. I use the small but effective loop adhesive applicators that fit in an Xacto holder and that minimizes most all application problems. There are always caveats aren't there? Joe
  7. I would just add another alternative. I have become quite fond of DAP Rapid Fuse Adhesive. I would characterize it as a CA adhesive but it has one useful capability that others do not have. A plank can be lifted within 30 seconds of application and relaid once again w/o more CA. I found this useful if I didn't get quite the plank to plank abutting that was needed. I have even pulled planks off completely, sanded the CA side and bulkheads (once dry) and reapplied them without incident. The adhesive bonds wood to ABS or similar "plastics". It sets after 30 seconds and cures in about 30 minutes. Joe
  8. Jim your work around for the tilt table to me is one of "why didn't I think of that?" comments! This certainly addresses the work piece falling into the blade if all things being equal and the table saw was sitting upright. I rescind my only criticism of the attachement. Thank you. Joe
  9. We were gifted with a record setting streak of warm weather here along Lake Ontario these past 7 days. And so were able to complete some last minute details prior to priming. To start with I finally decided to wet sand the hull to fair the Nitro Stan glazing compound. I had hesitated earlier as there was still a good deal of bare wood showing and it is a messy process as you auto body folk well know. It was left to dry for 2 days. Once that was done the rub rails were added up to the bow area. That was truncated because I have yet to master the "fair in" of the bow and the rub rail and the bow rub rail has to be specialy cut to fit the bow area as segmented rub rail was not going to traverse the bow. You may also see that a hull detail was added up to that point. It is an artifact, I believe, of the original hull layup as these hulls were intended for both pleasure and fishing craft. It is a simple 1/32" relief under the rub rail that follows closely to the waterline. One last detail was added and that was the trail board attached to the transom. On Mark II versions of the hull this was built directly into the transom. The day this was painted the air was relatively still but the relative humidity was quite low. As a result we were unable to get a full wet coat application on the primed hull. I chose automotive primer for the task so that has added to post priming tasks of a light wet sanding with 400 paper. The topside area is still to be worked to simulate the gullets of a fiberglass molded topsides so that is yet to be treated. Otherwise I am happy to report, in spite of all the applications of fill and glazing compound, the hull ia quite presentable from a fairness standpoint. I am sure the wet sanding will reveal some 'holidays' but for the moment we are go to press on. Joe PS: That sheet behind the model is a weakly veiled attempt to hide a messy counter area more than a backdrop cloth. Who said I had to be neat!
  10. I am pushing to get the hull primed this weekend as the weather is going to be in the mid 60s and I can't spray in the basement. As a result I could not let this setback prevent me from that goal. The rub rail I have found is about 3/8 inch wide in scale (1:6 maybe slightly less). It has a slight taper across the width inboard to outboard. Using bass wood I built a shooting board and tried to add the taper but I quickly found that I was having trouble getting a uniform tapered edge not to mention tearout. I then thought of a more obvious way. On the Byrnes saw I taped a 1/32 inch strip to the base of the saw fence. At this point the rub rail has been purposedly ripped to 1 inch width. Using my shop built ripping guide to keep the stock snug to the fence base and the top edge snug against the fence top (with my push stick) I managed to get a consistent taper These will be ripped to width and given some final detail sanding and attached to the hull/ I anticipate soaking, maybe steaming these strips at the bow to form to the bulbous bow shape. I may even have to segment the rail to get the desired conformance. I now think I have a fair chance of making the milestone. Jim if you are listening I wish there was a tilting arbor retro for this saw. Joe
  11. &*%#! I found a photo of the hull that didn't pixelate too much that displays the rub rail. That is the good news. The bad news is that my interpretation was wrong. I had assumed a more modern style but the picture that is shown in page 1 of this build log exhibits a much different rail that is proud at the stern and through midship but then intergrates itself into a splayed upper bow. I picked up some tapered balsa made for model airplane struts but in experimenting with it I have my doubts that it will suffice. Back to the drawing board! Joe
  12. Thanks Mark, we move on. The hull fairing is nearly complete but still remains tedious. I hated automotive body work in my younger years and this project is no different. Embarrassement of a poor result is all that drives me on. Took a break from that work and made the elements of the rub strib for the hull at deck level yesterday. After finding nothing at the hobby shop of suitable form I decided to make them. Using my 3/8 inch beading bit for my router I machined 3/8 basswood stock with the bit raised to just the bead height. (A smaller radius one is shown). I machined both edges to a bead on the stock and then ripped them at the Byrnes saw. Working with 24 inch stock I will have to join elements. A scarf joint should hide the junction. I haven't got a good close up picture of the rub rail so it may be after some searching the profile will need further hand work to comply. Joe
  13. When I retired I was looking for some satisfying work and happened to join Habitat For Humanity as a site supervisor. As the "newbe" I wasn't always given the prime work of building new houses. I got my fair share of rehabs. One was a 100 year old two story monster. I won't begin to relate the problems with construction and material differences compared to modern times. Everything was a contest and a compromise. Two by fours were really two by four inches (sort of, they had dried out so much they were not quite a full dimension). I can sense what you are encountering. As a home owner I have never resolved the conflict of macro work priorities balanced against the love I have for ship model building. No less that it is a business endeavor!!! Joe
  14. Mark your second reference iis quite helpful and more so supported by your text. Thank you. Joe
  15. I viewed progress on the gun tub carriages and beginnings of the frameworks for mounting the carriages and subsequently for the guns. At this point we have a question for anyone out there that served on a vessel like this. In studying the geometry of the mounting we have come to the conclusion that the carraiges were mounted to the swivel frameworks, not the guns. Our study of the photos we have does not reveal to us how the guns were secured to0 the carriages.We have to assume that the guns were easily attached and removed so how was carriage securing dealt with? While the gun tub work progresses I have decided to start the final fairing of the hull. It has been a hard lesson in construction as we used full bass wood sheet of 2 and 3 inches to "plank" the hull. Even though the bulkheads were fairly benign in terms of contour the result was that the hull has a number of valleys and/or end sheet butting that needs a good deal of fill as well as fairing. Although I have a lead on a product used in fiberglass hull fairing I have been reluctant to buy even a quart to experiment with. In the mean time I have resorted to our standby product Rage, Easy Sand. Its one limiting behavior is that it has an open time of just about 5 minutes so one has to work quickly and in small batches. It is advetised as sandable in just 15 minutes but I find the sanding gums up the sandpaper quicker than if one waits a bit longer. Nitro Stan glazing compound is being used to fill in the smaller imperfections but as related earlier in tends to shrink so multiple applications are needed.
  16. If you go to the Trucolor web site you may find a retail outlet near you. May is the operative word. They do not have a wide distribution. The second problem is that the retailers do not stock all colors. I have spoken to the manufacturer sales department (some time ago) and they will ship. What is needed are some really good color charts with TRUE COLOR which they were considering. Do not have any update on that. Joe
  17. We have advanced a bit farther in the build of the gun tub. Jim our project manager has taken the tub which was outfitted permanently with the modified inner catch/ammo trays. He has been working on the 50 caliber gun carriages. We continue to glean tid bits of information about the Patriots Point PBR. We have been told of late that the guns are not real but apperantely resin cast. No wonder they don't look exactly like our 1:6 scale units. Here is a mockup of the tub with guns.We will be removing the handles aft as they were not "handled" from that point. I would add that the tub now easily supports the scale figures that are planned for the model. Joe
  18. So impressive Rusty. Perhaps you could be persuaded to speak to your advancement at our next video conference???? Joe
  19. Sam your models are exquiste! I have often admired the 30 footer that is exhibited at Rock Harbor in Cape Cod. I have seen that vessel perform in rough surf and am so impressed at the boat's ability to survive broadside heavy waves. And the brave, brave souls who strap themselves in and go out in seas that make one's jaw drop ro save lives. Please let me know of the plans you have for her as she is one special craft that I would like to build. Joe
  20. We have all heard that a picture is worth a 1000 words But to some extent that is failing us and driving some do overs. This has been the case as we advance through the elements of the gun tub. The latest do over has been a modification of the inner tubs/that either hold ammo or catch spent shells. I am in the process of modifing them to make the width about 1/2 inch narrower. The left hand unit has been reduced. What drove this is a more detailed study of the machine gun trunion/mounts (see entry of 9/27). They are the elements that protrude above the tub flange. In our latest study we find that the model guns we have do not mount to the shaft through the gun body. The guns rest in a carrier and that carrier has flanges that support pivot points for both guns. The gun mounts must be spaced to accomadate the trays. We arrived at this by scaling one of the pictures so as the gun profile was the same as our 1/6 scale guns. Had we left the inner tubs at the original width the spacing for the supports in relation to the inner tubs would have been way off. That is probably not very clear possibly this will show up when we get closer to final sub assembly. Joe
  21. Aeropiccola had a kit that had a sail and spar plan. I am not sure of the scale. This kit may no longer be available through normal channels as they may have closed shop under that name. Also I would only use this reference if available as a starting point not as a defacto standard. Joe
  22. As an experienced woodworker for some 50 years I would strongly and I mean strongly recommend that the ripping and crosscut techniques demonstrated in this video not be practiced. This machine is as dangerous as a full size table saw. Always, always use push sticks. Never use the fence as your stop guide for continuous cutoffs! Always allow for any ripping or cross cutting "relief" prior to the infeed side of the blade by using clamped blocks to the fence. I do not want to explain why I write this! Joe
  23. Well Roger my first attempts to locate a copy of the book have failed. It is available on various sources for nearly $100. A bit pricey for our budget. Our county library system does not have it either. So for the moment that reference is not available to us. And yes Mark it is a search light. Last night I "tacked in" a plate that seemed to be of the correct size but after sizing it up against one of the scale 50 caliber guns it is a bit too wide to accomadate the outer support brackets so they end up correctly positioned in relation to the tub rim flange. So out it comes to be modified, reinstalled and readied for the twin gun try out later this week which is being done by another modeler. This "by guess and by gosh" way of modeling is a bit frustrating I must say. We are striving for a fairly accurate rendition but with such scant information at the detail level some interpretation is creeping in. Joe
  24. Mark I am coming around to the same conclusions about in service versus "as delivered and subsequent field changes". Who would know better than the end users of what worked or needed refinement! After I submitted my entry last evening I happened to recall that I had a cell phone picture of a Tamiya PBR. Sure enough it is configured as the Patriots Point gun tub. Just a bit more evidence that makes us feel more at ease about our build configuration. Joe
  25. Dry fit prior to final assembly of the inner trays came out reasonably well owing to the lack of structure stresses of the new substructures. The back rest has also been dry fitted. Without dimensions or scale drawings the juxtaposition of the back rest is almost correct when the photos we were given are compared. The support brackets will have to be adjusted to accomadate the difference. We have had a bit of luck as one of the members working on the model found in his archive of photos an oblique "head on" shot of the gun tub. Much to our surprise there is an added plate in the forward part of the gun tub, at rim level, that supports all the gun brackets and cradles for the 50 calibers. It is just behind the armament plate. We could not clearly see this in any of the other photos nor do any drawings even hint at this. This week we will be testing gun placement to determine the plate size and bracket locations and from then on I think we will be able to move forward with more certainty. Joe
