davyboy
Members-
Everything posted by davyboy
Hi Maurice,why don't you not just sieze the breeching ropes to the eyebolts before fitting them into the bulwark ? Much easier to do it that way you should have enough slack to slide the rope through the cascabel ring from side to side to do this. Certainly more space to do your siezings there than up against the bulwarks. Just a thought but that's how I'd do it. Dave
Hi Henry,your Dilemma is easily solved. You can fit an item called a deadeye plate,one of these can be seen in Blue Ensign's HMS Pegasus build log part 9, 6th pic down. Dead easy to make,just an eybolt through small circular piece of wood (Slice off a bit of dowel). The bottom deadeye just hooks into it. I had exactly the same problem rigging my Speedwell build. The Mizzen backstay and Main T'gallant backstay and attaching fittings are totally missing on the rigging plan although they can be seen on the NMM model. It was BE who put me in the picture. Hope this is of help, Dave
Thank you Trevor,one always learns something new. At the end of the day however they all serve the same purpose. Dave
- 15 replies
- baggy winkle
- service
Interesting names,Chafing mats or Service. I've always known these by the old name baggywrinkles. Dave
- 15 replies
- baggy winkle
- service
I've never used bits of paper as templates. There is usually a standard distance between Ratlines of 12" to 15" ",I use 12". A piece of wood 1/4" wide (I build in 1:48th) clipped across the shrouds below where the first ratline is to be rigged. Rig the ratline then clip your piece of wood directly above it and rig the next and so on. The beauty of doing it this way is you can ensure good alignment of all your ratlines with out struggling to align them with lines on a sometimes wobbly piece of paper. It works very well for me,try it. I'm sure I read this tip here on the forum years ago. Dave
Hello Wefalk, That practice is called pollarding and is still carried out to a limited degree in England for various reasons. Plenty of information on google and other search engines. Dave
Hi drftrman, Cruizer was my first ship model a long time ago. Don't worry about the bulkhead tops,at a later stage of the build when the hull is planked they're cut off. Just lightly tack glue the gunport patterns to them for that reason after fairing. I found that out the hard way. Have fun with your build,plenty advice on the forum,you just have to ask. Dave
Hi Maurice, She's looking good. These fashion pieces look much better than that shown on the prototype build. The Speedwell has exactly the same arrangement on the lower counter,I suspect that would be fairly common construction practice back in the day on small ships still using the older style square tuck . I'm currently chipping away at the boxwood carved figures of the two ladies ornamenting Speedwell's tafferel,then there are other smaller pieces to be done. Heigh Ho,get there eventually I guess. Dave
Mini Table Saw recommendations
davyboy replied to captainscott's topic in Modeling tools and Workshop Equipment
Have you tried sticking it to a backing piece of thin (1/8" or so plywood) I can't speak for styrene but I successfully cut 0,015" copper and brass sheet doing that on my Proxxon KS 230 saw using their thin fine toothed # 28020 50mm blade. Just take it slowly so you don't melt the styrene plastic. Dave -
Not a good idea,think about it. Throwing a towel over a rotating chuck or for that matter any rotating object Dave
Zero Clearance for Table Saws
davyboy replied to DelF's topic in Modeling tools and Workshop Equipment
Simply done. I just run a length of aluminium tape on both sides of the blade when I use their 0,5 mm blade. When I use their wider blades I simply remove the tape. Dave- 12 replies
- Zero clearance
- table saw
It works perfectly,I've been doing that for ages on my KS230 when using their 0,5 mm blade. Best to remove the splitter then you can tape right to the back. Dave- 12 replies
- Zero clearance
- table saw
That brought back a few memories for me. Back in the 1960's I was in the RAF and stationed in Bahrein our sea angling club used to regularly go on weekend fishing trips on Arab boats. No such luxury as a sponge on a stick there,a packing case hung over the stern with a plank knocked out of the bottom and a bucket on a rope for ones ablutions. No one I knew took bog paper with them Happy days,at least the sea was warm there.
Byrnes Alternatives - Saw and Thickness Sander?
davyboy replied to Jcredding's topic in Modeling tools and Workshop Equipment
Hi there Slowhand, Google Proxxon FET table saw review. There you will find a video and info on the tool,the article is just under the row of adverts. Go for it,it's a good buy,I've had mine for a number of years. Only thing I didn't like was that stupid plastic blade guard,I removed mine straight away. Dave -
My newest Challenge
davyboy replied to James Flynn's topic in Building, Framing, Planking and plating a ships hull and deck
Hi James, FWIW David Antscherl and Greg Herberts books on building a Model of HMS Speedwell 1752 can be obtained from Seawatch Books. You have a choice to build at 1:48th scale a model in solid lift,plank on bulkhead or fully framed, the plans are excellent and fully detailed. There are several build logs of Chuck Passaro's kit of Speedwell at 1:32nd here on the forum in the kit build section,look at these to give you an idea of what's involved with a POF build of a just a small ship. Chuck also has his original build in the scratch build section which is considerably further on than the kit builds. My build of her at 1:48th is POB in Box and Pear which is almost finished after 5 1/2 years and is 85 cm long from Transom to jib boom tip,POF would have taken me much longer. You could of course easily have the plans enlarged,bear in mind if you doubled up you would have a model 1.7 metres long from Transom to Bowsprit tip Thats about the size of a 3 decked first rate at 1:48th with a damned sight less work involved. Anyway I wish you luck in your quest. Dave -
Hi Johann, that is very interesting indeed,one learns something new every day. The English had something similar,the Topsail Tie Block itself was connected by a strop to a Bullseye free to run on the Backstay. I expect it had much the same purpose,however I read it was just to prevent the Tie Block and Halliard falling onto the deck causing damage or injury if the Tie was severed in battle. One shouldn't believe all that one reads I guess. Kind regards, Dave
Hi Johann, You asked in a previous post about the correct attachment of braces to the stays. Karl Marquardt's book 18th Century Rigs and Rigging has on Pages 101 & 102 brace rigging diagrams of English,French and German methods which may be of assistance to you. You may of course have already found an answer but I thought it was worth mentioning anyway. Gruss. Dave
