davyboy
Members-
Everything posted by davyboy
HI B:M,if you live outside the UK there is no VAT charge on your purchase/s from there. I'm not sure about the EU countries however. Dave
Arthurs Seat,the Salisbury Crags and the Pentland Hills in the far distance behind Edinburgh Castle. I grew up in Auld Reekie from 1941 to the late 1950's. Your painting brought back quite a few memories. Thanks for that. BTW,love all of your paintings. Dave
I notice that a number of these small logs have a gray marking showing on the cut ends. That looks like the tree they come from had the Boxwood disease. I have the same marking on some of the Boxwood I salvaged from a container of firewood a few years ago. I know this came from a tree that was felled because it had this disease. It's ok to use in hidden or painted parts of structures but I wouldn't recommend it for exposed planking. Dave
Untangling and rerigging or start from scratch?
davyboy replied to Rgpracer's topic in Masting, rigging and sails
Hi Ray,you might also consider Chuck Passaros' (Syren Ship Model co) Revenue Cutter HMS Cheerful It's at 1:48 th scale. A fairly easy POB scratch build. He sells the plans and basic kit timber and also mini kits for all other items if you cant make your own. All building instructions can be downloaded from the Syren site This was my second model after building a kit previously. There are a number of build logs of it in the Scratch build post 1801 section of the forum. The Syren ad is in the RH column on the home page. If or when you do decide to repair your wreck please ditch those dreadful deadeyes,if scaled up they'd be the size of cartwheels. Kind regards, Dave -
Reminds me of an incident with a glove around 50years ago. I was then a SNCO in the RAF,sent one of the men out to do start up crew on our SAR Helicopter (Westland Whirlwind 10) The last check before lifting off (in winter) was the start up crewman had to open the fwd door and check the anti icing hot air was flowing. He did this,took off his cold weather glove to feel and dropped it accidently. Needless to say it was sucked into the engine which stopped with a loud bang. Never saw aircrew moving so fast leaving an Aircraft. Dave
Swan-Class Sloop by Stuglo - FINISHED - 1:48
davyboy replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
Hi.that's an unusual colour of wood. Is it Olive Tree wood ? Dave- 475 replies
Being an old expat Brit I use Imperial measurements as I build models of 18th Century English warships in 1:48th scale. Metric is not really of much use as far as I'm concerned. My Vernier caliper and Micrometer are imperial as are my Rules. To each their own I guess. I still remember my school Teacher saying in (1948 or 49) forget Metric as it's foreign stuff we don't use it 'sic'. Dave
Hi Patrick, The book "The Rigging of Ships in the days of the Spritsail Topmast 1600-1720 by R.C.Anderson may be of much help to you. There are 9 and a half pages in the Yards and Stunsail booms section which should cover some of the info info you seek. Although from a slightly later period much of the info should be relevant to Pelican. There is one copy for sale on Abebooks in the UK for €11,45 at the moment. I can tell you that the Mizzen Yard should be roughly the same length as the Fore Yard. You are making a super job of this build, Dave
- 756 replies
- galleon
- golden hind
Had a good chuckle reading this. Back in the late 1960's I was stationed in Bahrein. Our sea angling club went fishing most weekends on one of the Arab Dhows. The "facilities" were a wooden crate roped to the stern with a couple of planks knocked out of the bottom,a bucket on a rope for performing ones ablutions. At least the sea was warm there Dave
Flags supplied by Amati look to be too big
davyboy replied to DaveBaxt's topic in Masting, rigging and sails
Hi Dave, www.becc.co.uk You may be lucky and find the sizes you require there. I think cornwall model boats also sell becc flags. Happy hunting, Dave -
Hi Cliff, R. C. Andersons' books Seventeenth Century Rigging and The Rigging of Ships in the days of the Spritsail Topmast 1600-1720 will have I'm sure info pertinent to your search. Both books are for sale on Abebooks and cheap. While there are no rigging plans per se there is much info to be found in them. BTW,there is a rigging plan in the 17th Century book but it's for the 96 gun St George of 1701 later than the SoS but may still be of some help to you. Dave
Have you tried heatshrink ? Blue Ensign uses it to great effect. Easy enough to drill a hole into it and glue in an eyebolt. Dave
Tell Me Why This Is A Bad Idea ( If it is )
davyboy replied to Gregory's topic in Modeling tools and Workshop Equipment
Interesting,but why not make your own zero clearance inserts ? I have the Proxxon FET saw,I made my own zero clearance inserts from aluminium strip which is cheap enough. Cut to size and drill and countersink fixing screwholes,fit and slowly raise the blade. Bingo,you have an insert for every sawblade. JMO,but I think it would be a little dangerous using tape for this purpose. Dave -
Deck planking methods
davyboy replied to allanyed's topic in Building, Framing, Planking and plating a ships hull and deck
When I planked the main deck of my POB model of Speedwell I had already made the various hatch and grating coamings,also the mast partners. These were pinned in their correct positions,I then planked from the centre outwards following the planking pattern on David Antscherl's plan. This ensured a very good fit of the planks. They were then removed to allow sanding/scraping of the deck planks. Looks good to me,nothing looks worse than deck fittings sitting on top of the planking. Dave -
I received the wrong book when I ordered The Ketch rigged Sloop Speedwell volume 2 from Seawatch being sent instead volume 1. I have no use for this book having volume1 already and they don't want it returned. Anyone who is interested in acquiring Speedwell volume 1 c/w plans send me a PM. I only ask that the recipient pays the value of my postage from Switzerland in US dollars and donates it to the MSW Forum funds. Thanks, Dave
