Everything posted by Canute
Back in days of yore, one of my additional duties as a Phantom flyer was to pull Range Control Officer for a day, every so often. I'd spend the day at the range, controlling flights of fighters and helos. Strafing was always fun. The Marine helos came and parked/hovered at the foul line and blazed away with whatever they loaded up that day, usually 7.62 mm. Buzz saws at work. Most fighters has 20mm cannon, so that was OK. Bigger buzz saws. The A-10s couldn't shoot at the regular targets; rip 'em to shreds. We had a supply of good old M113 APCs for them to shoot at. Lots of fire, smoke and noise. And they'd turn the APCs into Swiss cheese.
Didja ever see a Herc do a combat assault landing. Almost looks like a fighter pitching out to land. They are only limited by the bank angles allowed, shallower than what a fighter would use. The newer C-130Js may be allowed steeper bank angles and higher G loading. Most big jets are limited to 2.5 G. Fighters are somewhere north of 8.5 G, although that's in combat maneuvering. Landing pattern G loads are in the range of what a Herc would pull.
Of the 2 guys in the cab yes. There's a guy in the caboose, called a Conductor, who's the real boss, but many an engineer will argue that. Gene, nice work all around. The General looks very good.
Craig, most iron bombs, whether live or inert shapes were a khaki green. Live ordnance would have a yellow band next to the front fuse, inert ordnance would have a blue band. Laser kits were khaki, too. Cluster bombs were similarly painted. AIM-9 Sidewinders have a metallic green forward section. White behind. And yellow or blue stripes near the fuse section. Sparrows and AMRAAMs were white, except the radome/front section was a white ceramic. 12 years as a Weapons Officer did leave some imprint.
The corporate suits at Testors/Rustoleum feel that solvent paints are passe. I liked the early Floquil, which was lacquer based. Great on any model except the plastic parts (unless you used Floquil Barrier). Good luck with your use of solvent based paint. I bit the bullet and switched to acrylics. My airbrushing technique needs some work, but I can brush paint without putting on a chemical mask. I still mask up airbrushing, due to the particulates.
Henke, it's one of the better reproductions of HMS Hood. See this site of the HMS Hood Association for more details: http://www.hmshood.com/hoodtoday/models/trumpeter/trumpeter350.htm The site is very thorough, as you would expect fro the Association. References pro and con, photo-etch, other reviews. It will keep you occupied for a while, absorbing all the info.
- 20 replies
- prince of wales
- tamiya
All too true. Your health first. We can wait.
- 52 replies
- artesania latina
- titanic
Henke, nice work. As to rigging sequence: bottom to top, middle to outside.
- 20 replies
- prince of wales
- tamiya
Thanks for the suggestions, folks. Kurt, I don't think I'll be plating anything. I mostly want to get my PE clean and ready for blackening. I have an old Sheepscot Scale Products rail marine pile driver kit. The gantry for the pile driver has a lot of PE, which I intend to blacken.
Great thread, thanks. I have a pickling pot enroute. I have a question, though. How do you handle small brass PE bits. Once cut from their thin frets, is the copper tongs fine enough to pick up thin disks used to make up pulley sheaves. Or should you pour everything off through a sieve and put the whole thing into a baking soda bath. What metal should be used for the sieve?
Bill, his kits all make up into gems. Yours looks great. 👍 One of my local club members has a number of those FSM kits on his layout. He just had a visit from Model Railroader (MR) magazine doing a photo spread. It may show up in 2-3 years, the way MR puts layouts into print.
- 1 reply
- pile driver
- fine scale models
Like Lou says, look for fairly fine grained track ballast. I saw a model of a New England area pier a few weeks back. The builder said he used a light grey ballast, forgot the scale, but it was pretty fine. Top parts he left gray, the bottom two thirds were algae colored (wet, green shade). My camera died or I'd show you some pictures.
Check Klingspor https://www.woodworkingshop.com/product/ls25070/ Been using them for a few years. Cheaper than MicroMark,
- 52 replies
- artesania latina
- titanic
Jan is correct. Light cars should trail the loco and usually are limited to pretty low speeds. The Germans hauled AAA cars, but I seem to remember they were behind the loco. Looked at a lot of WWII gun camera film from my F-4 unit in Germany way back when. They flew P-47s during the war and shot up a lot of stuff. Winter weather in the Eifel being what it was, we had a lot of non flying days to watch historical movies. A good shoot em up was always fun.
Lou, I was out of town, so didn't have my loco cyclopedia to refer to. No misstating of info to add any confusion, by pulling an answer out without checking. I've been off, hobnobbing with other prototype railroad modelers. And a fine time was had by all. Learned a little about improving my airbrushing techniques. 😁 Craig, lots of work prepping the house. Local chore is blowing the leaves off the driveway. Threats of snow with that crud underneath should be avoided. Driveway will be as slick as owl poop with leaves and snow on it. 😧
