HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Canute
Everything posted by Canute
  1. Ted, try dipping the PE into white vinegar. It's a weak acid and makes a decent etchant for cleaning the PE. Rinse with water and let dry.
  2. Harry, hope you have a small powered drill. Doing it with just a pin vice may be excruciating.
  3. I'm in to watch. Too many cars and Model RR operating sessions right now. And Spring is springing right now; a tad early for the Smokies. I had the pleasure of flying in the first Red Flag exercise with the RAF Buccs back in I think '78. Very professional bunch in the Flag Ex, but a riot after-hours.😄 And they seemed as big a jet as my Phantom.
  4. The only break is your sprue attach points are on the sides, away from the linkages.
  5. I flew missions with the Buccs of RAF Sqdn 208 at a Red Flag, Nellis AFB, NV, in 1978 or so. I think a few were painted for desert ops, the rest in the gray and green look. They looked like they were flying right on top of their shadows across the desert. We escorted them to a range up in Utah. Tried to follow them through a mountain range but had to climb up to cross the ridges but still below the ridge tops. Very impressive flying. Always enjoyed working with the RAF; always professional on the job, fun off the flight line. 👍😄
  6. This dio is shaping up nicely. Good work with the brick and stone. I have a kit of Satriale's Pork Store, from the Sopranos TV show some years back. The street face of the building has a coloration like your sea wall, without the heavy weathering. I plan on copying your colors for the store. 👍 The beginnings of your track work look good. Ought to beat up the ties before you lay your rails. Most sidings aren't very pristine and overgrown with weeds.
  7. Tine to break out your favorite filler. Are these styrene or resin?
  8. Interesting build, Mike. These seaplanes are very interesting. I, too, will be following along.
  9. You can add them on to the strains of "Paint it black" by the Rolling Stones.😁 This is coming along nicely. Looks good.
  10. That's a nice hot rod. Fiberglass skin?
  11. Those inside curves look like a real bear to lay your blocks into. You work for P&W?
  12. Get the Gator Grip glue by emailing your request to the address on this website: https://gatorsmodelstudio.com/gators-grip-hobby-glue/ I don't think he sells thru retailers. But I use this, too.
  13. You may also want to look at Canopy Glue for your PE glue. It looks like a thick white glue. Originally for the RC airplane folks to stick their canopies on. I've used it to hold brass and stainless PE to plastic and it holds up if your model moves from warm to cold environments. And it cleans up with water. Should find it in a Hobbytown, since many of them seem to cater to the RC folks..
  14. Mike, very nice dio with the Buffalo. You're working your way up the skill levels with these last few a/c. Like Elmer said, magazine cover quality. 😀👍
  15. Why did they move this in 2 pieces? Was this due to overall weight and pulling capacity of these tow vehicles? Other guns moved as one,unit, didn't they?
  16. Very nice addition to your outdoor kitchen. The wood is beautiful. The Italians call that a pergola. Will nice sitting out under this on a summer night. 👍
  17. Very well done, Gary. I like the tires in this kill. I have several Sylvan fire truck kits and the have rubber tires with plenty of flash to remove. I like the Gallery Glass idea. Have to look them up to enhance my vehicles.
  18. Looking forward to this build. I'm in.
